Windows 10: My galaxy book 2 has low audio sound whereas test sound is mutch better. Please help
Discus and support My galaxy book 2 has low audio sound whereas test sound is mutch better. Please help in Windows 10 Gaming to solve the problem; My galaxy book 2 has low audio sound whereas test sound is mutch better. Please help... Discussion in 'Windows 10 Gaming' started by prabir roy, May 27, 2023.
  1. My galaxy book 2 has low audio sound whereas test sound is mutch better. Please help
  2. No sound while playing audio and video files.
    I appreciate if you could answer to a few questions to narrow down to the issue.
    • Which is the application that you are using to play the files?
    • Did you try the same on a different player?
    • Did you perform any troubleshooting steps?
    As an initial troubleshooting step, I suggest you to check if the volume is set low or in mute state in Volume Mixer.
    • Right click on sound icon.
    • Open Volume Mixer check for the application that you are playing the files with and increase the volume and check.
    If the issue still persists, I would suggest you to run “Playing audio” troubleshooter to diagnose and fix the issue.
    Follow these Steps to run Playing Audio Troubleshooter in Windows 10.
    1. Type troubleshooting in the search bar.
    2. Select Troubleshooting.
    3. Select View all on the top left corner.
    4. Click on Playing audio.
    Also refer: Fix sound or audio problems in Windows - Microsoft Support
    Hope the information helps in resolving the issue related to the sound issue. Let us know if you need further assistance. We will be happy to help.
    Krishna Prasobh V, May 27, 2023
  3. No sound Audio
    Hi Hubert,
    We understand the inconvenience caused and we appreciate you for trying the troubleshooting steps..
    This issue might occur if some of the sound settings got corrupted.
    I suggest you to try running audio troubleshooter and check if it helps.
    Follow the below steps:
    • Type Troubleshooting in the Search area on the taskbar and select
      Troubleshooting.
    • Select Hardware and Sound.
    • Select Playing Audio under
      Sound
      and follow the on screen.
    For more information, refer to the below link:
    http://windows.microsoft.com/en-us/windows-10/fix-sound-problems#v1h=tab01
    Santosh_Rai, May 27, 2023
  4. fireberd Win User
    Sound Quality
    One thing that sticks out from looking at your "My Computer" specs. You list "ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)" which suggests you do not have the correct sound hardware driver. Your motherboard has Realtek sound and the first step is to install the Realtek sound drivers. My ASUS also came with Sonic Studio 2 which is a sound enhancement package. Check the ASUS install disc to see if you have something similar.
    May not be a speaker problem.
    fireberd, May 27, 2023
  1. My galaxy book 2 has low audio sound whereas test sound is mutch better. Please help - Similar Threads - galaxy book has
  2. sound is very low please support
    sound is very low please support: sound is very low please support https://answers.microsoft.com/en-us/windows/forum/all/sound-is-very-low-please-support/9839e07f-a4e8-4f74-856d-53efa6dca8b5
  3. Galaxy earbuds 2 sound not working
    Galaxy earbuds 2 sound not working: hello, i recently got some galaxy earbuds2, i want to use them for gaming and calling at the same time, but when im in calls, i get no PC sound, only sound from the call.they are connected through bluetooth...
  4. Galaxy earbuds 2 sound not working
  5. Galaxy earbuds 2 sound not working
  6. My galaxy book 2 has low audio sound whereas test sound is mutch better. Please help
    My galaxy book 2 has low audio sound whereas test sound is mutch better. Please help: My galaxy book 2 has low audio sound whereas test sound is mutch better. Please help https://answers.microsoft.com/en-us/windows/forum/all/my-galaxy-book-2-has-low-audio-sound-whereas-test/c6f0c752-160f-4e06-8529-56f8115a6a65
  7. Test Sound
    Test Sound: I started a test sound on my speakers and now I cannot make it stop playing.. https://answers.microsoft.com/en-us/windows/forum/all/test-sound/4fc73092-70e5-4e46-8aab-da0a9012462c
  8. NEEDING HELP WITH GETTING SOUND/AUDIO PLEASE?
    NEEDING HELP WITH GETTING SOUND/AUDIO PLEASE?: I have a HP EliteBook with Windows 10 and I have NO SOUND. I have done troubleshooting and followed other suggestions online and still NO SOUND. CAN ANYONE HELP PLEASE?...
  9. Please help low sound/volume on tablet
    Please help low sound/volume on tablet: hi all. i bought a nextbook flexx 10 tablet and its not bad but the volume is so low on this thing if two people are talking in a room i cannot hear the tablet. is there anything i can on windows 10 to increase the volume? i have tried to go into speaker properties and go to...
  10. No audio on headset. But sound test O.K.
    No audio on headset. But sound test O.K.: Since upgrading to Windows 10, 64-bit, I have no audio on the headset. Also, speakers are not muted when headset is plugged in. Headset checks out O.K. on sound test. HP Pavillion 500-249 Desktop. 14664
