Windows 10: Need a PC Audio expert! OBS/Input Jacks/VB Cable?
Discus and support Need a PC Audio expert! OBS/Input Jacks/VB Cable? in Windows 10 Support to solve the problem; Okay, I don't post on forums much, because I'm usually pretty good at researching through the inter-web, however I'm at a loss for wits with this... Discussion in 'Windows 10 Support' started by MolhoMark, Oct 27, 2015.
Need a PC Audio expert! OBS/Input Jacks/VB Cable? - Similar Threads - Need Audio expert
audio jack not working for input whereas working for output even if the audio jack is two...
in Windows 10 Gamingaudio jack not working for input whereas working for output even if the audio jack is two...: my computers front panel audio jack is 2 ways i.e. input and output the output sound is working properly but the input for microphone is not working i have tried everything but my computer is not detecting any input from audio jack i have the latest drivers installed i have... -
how to fix virtual audio cable i'm using VB-Audio Virtual Audio Cable marking Input as an...
in Windows 10 Gaminghow to fix virtual audio cable i'm using VB-Audio Virtual Audio Cable marking Input as an...: I'm on a HP Windows 11, and when i installed a Virtual Audio Cable to add audio from an application, to discord, i installed the driver, and restarted, like it asked, and it had marked the Input for the virtual cable as an Output, and the Input was marked as Output, how do i... -
in Windows 10 Software and Appshow to fix virtual audio cable i'm using VB-Audio Virtual Audio Cable marking Input as an...: I'm on a HP Windows 11, and when i installed a Virtual Audio Cable to add audio from an application, to discord, i installed the driver, and restarted, like it asked, and it had marked the Input for the virtual cable as an Output, and the Input was marked as Output, how do i... -
Audio Jack input/output setting
in Windows 10 GamingAudio Jack input/output setting: Hi, this is just a small question regarding a specific audio setting. This setting was a pop-up for each time I plugged sth into the audio jack and it showed a list of devices that could be plugged into the jack e.g. Mic, Headphones, speakers, etc. I got an external mic but... -
in Windows 10 Software and AppsAudio Jack input/output setting: Hi, this is just a small question regarding a specific audio setting. This setting was a pop-up for each time I plugged sth into the audio jack and it showed a list of devices that could be plugged into the jack e.g. Mic, Headphones, speakers, etc. I got an external mic but... -
in Windows 10 Drivers and HardwareAudio Jack input/output setting: Hi, this is just a small question regarding a specific audio setting. This setting was a pop-up for each time I plugged sth into the audio jack and it showed a list of devices that could be plugged into the jack e.g. Mic, Headphones, speakers, etc. I got an external mic but... -
PC Audio Input jack issue
in Windows 10 Drivers and HardwarePC Audio Input jack issue: Regarding an HP Pavillion operating Windows 10. I am a radio DJ and record from home. I have a mic plugged into a small mixing board. From there, it's an RCA-style audio cord that plugs into input jack at the back of the PC. Suddenly, the jack isn't recognizing anything. I... -
Audio input says cable not plugged in.
in Windows 10 Drivers and HardwareAudio input says cable not plugged in.: I have 2 side by side Dell 9020 SFF computers with i7 4770 and 16 GB memory. Both have SSD drives. Both have WIN 10 Pro. I have a 12" M-M 3.5mm stereo cable from the output of one 9020 to the input of the other using the rear jacks. I keep getting cable not plugged in... -
Virtual (VB Cable) audio issue - kind of :)
in Windows 10 Drivers and HardwareVirtual (VB Cable) audio issue - kind of :): Hi there Hoping someone can help me with this problem. So, I am streaming music to a server and everything is fine from that perspective, high quality, excellent, BUT I am unable to hear the music live from my laptop output (with ear buds) I can only hear via another device...
