Windows 10: Need help fixing issue when using my computer and using different apps for work after...
Discus and support Need help fixing issue when using my computer and using different apps for work after... in Windows 10 Software and Apps to solve the problem; Hello I have a computer running windows 11 it is a custom computer built from scratch. The problem I am having is that I use it for work most of the... Discussion in 'Windows 10 Software and Apps' started by Cristian Avila1, Oct 28, 2022.
  1. Need help fixing issue when using my computer and using different apps for work after...
    Hello I have a computer running windows 11 it is a custom computer built from scratch. The problem I am having is that I use it for work most of the time and while operating during the day I will have multiple windows at once. Well there is times when having all these multiple windows open at once I try to get say for instance my outlook to the front of the group by clicking it on the icon on my task bar and it will not pop to the front of the screen. If I minimize the screen that is blocking said app you can see clear as day. It does this with alot of random apps and I have reset my computer
  2. [HELP]Image recovery issues
    Guys i am trying to fix my cousins Asus Eee netbook. It has a backup image file that is partitioned on the hard drive but when I go to use it the app will run through a few steps and stop. It is running Vista . Any suggestions?
    Rapidfire48, Oct 28, 2022
  3. zbook Win User
    Programs not working
    In post 26 there were steps listed to fix the operating system corruption.
    Are you able to follow them?
    In post 29 was the suggested dism repair command.
    zbook, Oct 28, 2022
  4. Need help fixing issue when using my computer and using different apps for work after...
    Edge Search Does Not Permit Change of Region
    Step 1:
    Step 2:
    1. Go to Settings.
    5. Click on Finish.
    Step 3:
    hurricane51, Oct 28, 2022
  1. Need help fixing issue when using my computer and using different apps for work after... - Similar Threads - Need help fixing
  2. i need help useing mirosoft apps
    i need help useing mirosoft apps: ive gone and done something to my pc at some point and i think i was tweaking withv something i shouldnt have im pretty sure it was giving myself more permissions to delete certain things on my pc im honestly not sure why but ever since ive gotten this problem with opening...
  3. i need help useing mirosoft apps
  4. Help needed after using DDU
    Help needed after using DDU: First of all I recently built an AMD pc, ryzen 5 5600x and radeon 6800xt, all worked fine until I updated the drivers and some games didn't work, with the AMD integrated program warning me of a failed driver issue, so I decided to roll back the drivers to version 23.5.2 or...
  5. Help needed after using DDU
  6. Help needed after using DDU
  7. Need help fixing issue when using my computer and using different apps for work after...
    Need help fixing issue when using my computer and using different apps for work after...: Hello I have a computer running windows 11 it is a custom computer built from scratch. The problem I am having is that I use it for work most of the time and while operating during the day I will have multiple windows at once. Well there is times when having all these...
  8. I need help connecting to my remote computer at work using my VPN
    I need help connecting to my remote computer at work using my VPN: I'm so beyond frustrated.. I have spent close to 4 hours now trying to do this. I have the VPN connected properly now, and I need to remote access my work computer. I know that that computer is set up correctly to be remote accessed because the guy I am working under has been...
  9. my computer crashes when using pokerstars app
    my computer crashes when using pokerstars app: how do i download new video card/ graphics to help with game https://answers.microsoft.com/en-us/windows/forum/all/my-computer-crashes-when-using-pokerstars-app/cf14cbb7-95af-44c0-b963-381c90276f09
  10. Need Help fixing my computer
    in Windows Hello & Lockscreen
    Need Help fixing my computer: My Hp Pavilion Gaming laptop won't work after a Windows 10 update. It gets to the sign in Screen and then goes black and then back to the sign in screen. Recovery options won't load with F11. Safe mode won't load with F8 and A installation media won't work. It doesn't do...
