Windows 10: Need help to control fire engine engine simulator by kisosoft using key board or mouse
Discus and support Need help to control fire engine engine simulator by kisosoft using key board or mouse in Microsoft Windows 10 Store to solve the problem; Just bought fire engine simulator by skisosoft, do not know how to control game on key board or mouse. there is no user guide. Please help or if need... Discussion in 'Microsoft Windows 10 Store' started by kretire2016, Sep 22, 2019.
  1. Need help to control fire engine engine simulator by kisosoft using key board or mouse
    Just bought fire engine simulator by skisosoft, do not know how to control game on key board or mouse. there is no user guide. Please help or if need game controller, where to buy... Thank you
  2. BossDweeb Win User
    engine 3
    I see the Firmware for this mouse listed in the Legacy section of the Steelseries download page, and
    under Engine 2 Supported Devices the WoW Wireless is on the list.
    Looks like the mouse is not compatible with Engine 3 profiling software ?
    Have you tried using the Status Firmware Update Tool (Win10 ) ? This may be able to update the Mouse to suit ?
    BossDweeb, Sep 22, 2019
  3. LCRT Win User
    search engine
    windows xp advice for a windows 10 query. with registry fiddling. great advice.
    anyway, the answer is very simple:
    http://windows.microsoft.com/en-us/windows-10/change-the-default-search-engine-in-microsoft-edge
    When you enter something in the address bar in Microsoft Edge, you’ll see results from Bing. Microsoft recommends Bing for the best performance with Windows 10. Bing gives instant help for Windows 10 and Microsoft Edge (just like this). And Bing links search
    results with some Windows 10 apps. But Microsoft Edge uses OpenSearch technology, so you can change the default search engine. Here’s how:
    • Enter the search engine’s website and browse to it.
    • Select More actions (...) > Settings and then scroll down to select View
      advanced settings. In the list under Search in the address bar with, choose Add new.
    • Select the website and then select Add as default.
      • Note: Only search providers that support the OpenSearch standard will appear in this list. If they don’t support it yet,here's how
        they can."
  4. Need help to control fire engine engine simulator by kisosoft using key board or mouse
    changing default search engine to google from Bing in IE Edge
    To change the default search engine on Windows Edge.
    Step One: Open Microsoft Edge
    Step Two: type in the search engine into the browser address such as (www.google.com)
    Step Three: Click on the three dots top right below the x (close button)
    Step Four: Click on settings
    Step Five: Scroll and click on Advance Settings
    Step Six: Scroll to Search in the address bar with click within the box
    Step Seven: Click on Add NEw
    Step Eight: Your search engine should be listed Click on it
    Final Step: select your choice of:
    Add as default
    Add
    Rico Novice, Sep 22, 2019
  1. Need help to control fire engine engine simulator by kisosoft using key board or mouse - Similar Threads - Need help control
  2. I'm engineer
    I'm engineer: I'm engineer https://answers.microsoft.com/en-us/windows/forum/all/im-engineer/c67d9a02-37db-4d72-9c24-d31e05839477
  3. Malfunctioning key on the key board. Need help!
    Malfunctioning key on the key board. Need help!: Since last month one of the keys in my laptop keyboard is repeating its function again and again. It is the delete key. Whenever it occurs I cannot stop it without clicking another key more than once. It is hard for me to complete my work when this problem occurs. Whenever I...
  4. Malfunctioning key on the key board. Need help!
  5. Malfunctioning key on the key board. Need help!
  6. Microsoft engineer name REPORT: "Christine A" WARNING -> don't help and need be fired!
    Microsoft engineer name REPORT: "Christine A" WARNING -> don't help and need be fired!: Also i need to report here some of your workers that DID NOT HELP in my problems in windows 10 as they say in the "feedback hub" that: my "windows have reached end of service".... And i have latest update 21H1!! So they pretend to work!!!! there is the link from "feedback...
  7. Flight Simulator 2020 Aircraft Engine Upgrade
    Flight Simulator 2020 Aircraft Engine Upgrade: I think that the downforce of the aircraft has become unreactic, will this be improved or will it remain so? https://answers.microsoft.com/en-us/windows/forum/all/flight-simulator-2020-aircraft-engine-upgrade/cc033c20-1dca-4c98-b489-130b693b2cc8
  8. Mouse and key board out of control
    Mouse and key board out of control: While in a game like world of tanks blitz every once in awhile my mouse loses control of the tank and my keyboard starts printing the same letter over and over. When i go to device manager it shows a yellow mark on the graphics card yet it says its working properly. I have to...
  9. I need help with search engines in my laptop
    I need help with search engines in my laptop: I have an ASUS laptop, it is a little old, but it does has Windows 10. The problem is that my info isn't getting saved in the search engines. For example, I log in my gmail account, I close the tab and I have to log in again, even if I put "remember info". I thought it was a...
  10. search engine help
    search engine help: just got a new comp with windows 10. don't like edge so I am using explorer how do I get rid of bing and use google search 117451
  1. fire engine simulator use keyboard and mouse
