Windows 10: Need Help troubleshooting sound output problems
Discus and support Need Help troubleshooting sound output problems in Windows 10 Customization to solve the problem; So when I have my headphones plugged in, no sound is outputted. I know the port is detecting my headphones because I can still use the built-in mic. It... Discussion in 'Windows 10 Customization' started by JaneTran2, May 17, 2021.
  1. JaneTran2 Win User
    So when I have my headphones plugged in, no sound is outputted. I know the port is detecting my headphones because I can still use the built-in mic. It works, but for some reason, I don't hear any sound. I don't know the reason. I've checked to see if it was disabled, but it wasn't. The headphones don't show up in the sounds playback tab either. I've checked if I've had to update drivers and restarted my laptop numerous times.
  2. Sound Troubleshooter
    I request you to try the methods below:
    Method 1:
    Hardware Troubleshoot
    Windows 10 has a built-in troubleshooter to check and fix issues with Sound. I would suggest you to run this troubleshooter to check if the issue is with your Audio.
    Refer these steps:
    • Press Windows key +X, select Control panel.
    • Change the view by option on the top right to Large icons.
    • Click on troubleshooting and click on the view all option on the left panel.
    • Run the playing Audio troubleshooter.
    Method 2:
    Sound problems can be caused by cables that aren't connected properly, damaged drivers, incompatible drivers, sound settings, missing updates, and problems with your sound card.
    I request you to follow the below steps:
    Step 1: Uninstall the Sound card Drivers
    • Press “Windows Logo” + “X” keys on the keyboard.
    • Click on “Device Manager” from that list.
    • Search for the Sound driver from the device list, right click on it and then select “Uninstall”. On the un-installation window, if you have an option: “Delete the driver software for this device” you may select that and then
      remove the corrupted drivers from the computer.
    • Follow the on-screen instructions to complete it and the restart the computer if prompted.
    • After the restart, please go ahead with the next steps to install the latest drivers and check if that resolves the issue.
    Update Driver Software from the Manufacturer’s website.
    Step 2: Go to the Computer or Sound Card manufacturer’s website and search for the latest Windows 10 drivers available for the Sound Card model and then install it by following the instructions given in the website.
    I also request you to follow the below article:
    Fix sound problems
    http://windows.microsoft.com/en-us/windows-10/fix-sound-problems#v1h=tab01
    I hope this helps you. If you have any further query in future, feel free to contact us. We will be happy to help you.
    Amit(Kumar), May 17, 2021
  3. Sound problem
    • Click Hardware and Sound.
    Radney Dri, May 17, 2021
  4. Need Help troubleshooting sound output problems
    window10 sound problems - I need help can you help me do that to fix the sound.
    To assist you better, please provide few details.
    • What all the troubleshooting steps have you tried to resolved the issue?
    • What is the exact issue are you facing with sound?
    • Are you getting any error message?
    • Have you installed all the pending Windows updates?
    I suggest you to follow the below methods and check if it helps.
    Method 1: I suggest you to install all the latest pending Windows updates as below and check if it helps.
    • Go to “settings” and click on “update and security”.
    • Under tab “Windows update”, click on the icon “check for updates”.
    • Then once you find the pending updates install it and check.
    Method 2: I suggest you to follow the steps from the below article and check if it helps.
    Fix sound problems
    Fix sound problems in Windows 10
    Please get back to us with an update on this issue, we will be happy to help.
    Thank you
    Karthicka_R, May 17, 2021
  1. Need Help troubleshooting sound output problems - Similar Threads - Need Help troubleshooting
  2. Need HELP to find the problem/troubleshooting steps
    Need HELP to find the problem/troubleshooting steps: So to be clear. I don't know what the issue is that causing my computer sometimes to freeze momentarily then play two windows sound notification. Can someone help me find a way to find why my computer has started doing this? I fear something may be wrong with my computer and...
  3. Need HELP to find the problem/troubleshooting steps
  4. Sound output problem
    Sound output problem: Hi, my sound output hasn't been working for at least 24 hours but no longer than 4 days. I have tried everything i found onnline but nothing is still working. The default says the speakers are working normal, so i have no idea what is going on. Hope to find some help! Thank...
  5. Sound output problem
  6. Troubleshooting sound problems in Windows
    Troubleshooting sound problems in Windows: my laptop doesnt have sound https://answers.microsoft.com/en-us/windows/forum/all/troubleshooting-sound-problems-in-windows/3628817a-3179-4ce2-986e-f2cd5fb44c0e
  7. Troubleshooting sound problems in Windows
  8. Sound output problem
    Sound output problem: On this day : 2024.07.10 I updated Windows 11. After the update, on discord the others can hear everything that Run on my compturer. Videos, Music etc... I watched a Yt video at 6% sound, and they still heard it. Anyone have some solution ?...
  9. Sound output problem
  10. BSOD troubleshooting Need help troubleshooting
    BSOD troubleshooting Need help troubleshooting: Hi Microsoft Team, On the past 3 days, I have 3 BSOD. Attached is the minidump & MSINFO of my computer: https://1drv.ms/u/s!AqAhNMuZyKrSiCyw3z3Bn0Gex3Mz?e=kVkDP1 Regards, Michael...
