Windows 10: Need help with a BSOD problem DEVICE_POWER_STATE_FAILURE
Discus and support Need help with a BSOD problem DEVICE_POWER_STATE_FAILURE in Windows 10 Software and Apps to solve the problem; Not too sure what's causing it. Was checking on HWINFO64 for abit before the screen froze everything else was running, discord was still connected and... Discussion in 'Windows 10 Software and Apps' started by Michael_LYC, Jul 11, 2024.
  1. Need help with a BSOD problem DEVICE_POWER_STATE_FAILURE
    Not too sure what's causing it. Was checking on HWINFO64 for abit before the screen froze everything else was running, discord was still connected and working. Could be either a problem caused by HWINFO64 or the Integrated GPU.Also "Display driver amduw23g stopped responding and has successfully recovered."Once the device restarted the Integrated GPU driver didn't load, had a yellow exclamation on it. While the Dedicated GPU is just disabled. Disabling and re-enabling the Integrated GPU allowed the driver to load, and for the D-GPU I just had to enable
  2. Senarium Win User
    Weird BSOD problem
    Hi Everyone,
    I have a weird BSOD problem which I cannot solve for a while(it persists still after upgrade to Windows 10 from Windows 7)
    The main strange thing about this is that I get BSOD only after cold boot.
    So it acts like this:
    1. start PC.
    2. Get to Windows Logo Screen
    3. BSOD
    4. Restart
    5. Get to menu where I can try to repair or Start NormallyIf I Choose Repair, it will fail to repair and will try to restoreIf I Choose Start Normally, it will start OK, no BSOD, can work normally, games, browse internet, everything is normal.6. Shutdown PC
    7. Next time when I start is all over again i.e. Go to Step 1
    I have this problem for a while, so what I tried:
    1. Another Windows 7
    2. Another HDD
    3. Only HDD connected
    4. Changed RAM
    5. Tried with built in GPU
    6. Upgraded to Windows 10
    Result is the same as above every time.
    Please suggest what could be the cause.
    Logs collected with DM_Log_Collector, attached.
    Thank you
    PS. This thread is a continuation of this one: Frequent multiple errors BSOD. Solved - Windows 7 Help Forums the only thing changed is Windows 10 now. instead of Windows 7. If that helps somehow.
    Senarium, Jul 11, 2024
  3. DEVICE_POWER_STATE_FAILURE
    One of the many things that does no longer work properly under Windows 10 is now booting. I have become used to the mail program not working properly - with me it is the login account which is hotmail/outlook and, according to Microsoft, cannot be deleted
    and then re-instated - but now, in this vaunted operating system, when I login I get the error DEVICE_POWER_STATE_FAILURE. It does not tell me which device driver is causing the problem but as Microsoft is now installing software without due regard to what
    is already on the system, is probably due to them.
    If anybody has any idea a to what can be causing this problem - DRIVER_POWER_STATE_FAILURE - or how to find out which driver it is I would be grateful to know.
    If anybody has another working mail client which can work with multiple email accounts I would also like to know.
    Many thanks.
    Tony Hartnell, Jul 11, 2024
  4. Need help with a BSOD problem DEVICE_POWER_STATE_FAILURE
    help to remote connect
    not sure how to use both programs u 2 suggested, i need more helpful steps thanks
    Corduroy_Jr, Jul 11, 2024
  1. Need help with a BSOD problem DEVICE_POWER_STATE_FAILURE - Similar Threads - Need help BSOD
  2. Need help with a BSOD problem DEVICE_POWER_STATE_FAILURE
    Need help with a BSOD problem DEVICE_POWER_STATE_FAILURE: Not too sure what's causing it. Was checking on HWINFO64 for abit before the screen froze everything else was running, discord was still connected and working. Could be either a problem caused by HWINFO64 or the Integrated GPU.Also "Display driver amduw23g stopped responding...
  3. Device_Power_State_Failure 9f Bluescreens due to storahci.sys
    Device_Power_State_Failure 9f Bluescreens due to storahci.sys: I've been having constant random bluescreens due to storahci.sys. Not sure how to fix it, please help. dmp file: https://drive.google.com/file/d/1ro55QWPEtq7D2gtdZnQG7xsNKeLPNC97/view?usp=sharing...
  4. BSOD - Need help identifying problem inside minidump
    BSOD - Need help identifying problem inside minidump: Hello,I've attached 2 minidump files from recent BSOD. Can anyone let me know what the issue is, or how I can check these myself if it isnt too complicated.Thanks!https://drive.google.com/drive/folders/1rqT4vL6P8VZbq32S03Sg3-_C5juVd0Ej?usp=share_link...
  5. BSOD - Need help identifying problem inside minidump
  6. BSOD - Need help identifying problem inside minidump
  7. BSOD problem occuring need help fixing it
    BSOD problem occuring need help fixing it: Ive been having a BSOD problem for a while now and its gotten really annoying. Ive looked around for fixes and all that seems to fix it, is people that understand minidumps, which is not me. Some of the dumps arent the same i dont think, so i have posted multiple:They all...
  8. BSOD problem occuring need help fixing it
  9. BSOD problem occuring need help fixing it
  10. DEVICE_POWER_STATE_FAILURE around login
    DEVICE_POWER_STATE_FAILURE around login: Hello, I have updated to Windows 10 when it first came available back in July. Since then, I have been noticing a lot of DRIVER_POWER_STATE_FAILURE BSODs. They all seem to happen every day about 5-6 minutes after booting the computer and after waking the computer from...
