Windows 10: Need help with dual monitor sound problems
Discus and support Need help with dual monitor sound problems in Windows 10 Software and Apps to solve the problem; Hello I just added a dual Monitor with a CURA 25inc Monitor 200/180hz and a Spectra F24 75hz as my secondary, as soon as they were both set up my... Discussion in 'Windows 10 Software and Apps' started by Adam Pittman, Aug 30, 2024.
  1. Need help with dual monitor sound problems
    Hello I just added a dual Monitor with a CURA 25inc Monitor 200/180hz and a Spectra F24 75hz as my secondary, as soon as they were both set up my primary monitor doesnt have any sounds and is only using a DP cable and the other monitor is HDMI, when I switch sounds for output the second monitor has sounds but when I switch back to my main theres no sounds, can anyone help?
  2. dual monitors stops sound
    Hi David,
    To assist you better, I suggest you to answer the below questions.
    • When will the sound disable, when playing through main monitor or the extended monitor?
    • Did you try enabling the sound from the sound drivers and check if it helps?
    • Since from when are you facing this issue?
    This issue causes because the monitor automatically takes the HDMI sound as the Default input. Disable and enable the speakers and check if it helps.
    I suggest you to try the below steps and check if it helps.
    • Right click on the volume control and then
      Properties
    • When you connect the HDMI it becomes the default output device, even though it has no speakers.
    • You need to change this back to "Speakers" and set as default.
    Need help with dual monitor sound problems 277833d1379328243t-hdmi-monitor-no-speakers-no-sound-anywhere-when-connected-sound.png
    Hope this helps. Keep us posted to help you better.
    Sachin Venkatesh, Aug 30, 2024
  3. Dual Monitor Sound Output with 2 HDMI's
    Hello, Im trying to output my PC sound to my dual monitor setup (HP VH240a x2)
    I've tried enabling the stereo mixer in windows and replaying to the second monitor and even used a direct audio jack instead but nothing.
    Also, I tried NVIDIA's Control Panel and enabled surround but it doesnt work
    Pc specs : ROG-STRIX-RTX2060-6G-GAMING
    Intel i5-9600k
    Gigabyte Z390 AORUS PRO WIFI
    UncleDemonTTV, Aug 30, 2024
  4. patrickt Win User
    Dual Monitor Problem
    Overall I'm delighted with Windows 10 but I have one relatively minor problem with my dual monitors. The taskbar on the second monitor won't auto-hide. It just sits there.
    Any suggestions?
    patrickt, Aug 30, 2024
  1. Need help with dual monitor sound problems - Similar Threads - Need help dual
  2. Need help with dual monitor sound problems
    Need help with dual monitor sound problems: Hello I just added a dual Monitor with a CURA 25inc Monitor 200/180hz and a Spectra F24 75hz as my secondary, as soon as they were both set up my primary monitor doesnt have any sounds and is only using a DP cable and the other monitor is HDMI, when I switch sounds for output...
  3. Needing Help With Dual Monitors
    in Windows 10 Graphic Cards
    Needing Help With Dual Monitors: I'm running windows 10 home and I have a hdmi port on my laptop that I connected to my secondary monitor. Display Resolution 1366 X 768 (Recommended) for the laptop resolution. But the secondary monitor is 1920 x1080 full hd. I want to have 2 different wallpapers one for...
  4. Needing Help With Dual Monitors
  5. Need Help With Dual Monitors
    Need Help With Dual Monitors: Hey! I just setup dual monitors using an old monitor I found, but there's a small problem. The old monitor I found is super long vertically, and the bottom of the screen is far below my eyeline. I thought a simple fix for this would be to change the resolution vertically,...
  6. Need Help with dual monitors
    Need Help with dual monitors: I setup dual monitors, and everything is fine except for the fact that when I open a program from my secondary monitor, it displays on my primary monitor and shows the taskbar button on both monitors. Any fix? submitted by /u/Slosshy [link] [comments]...
  7. need help with separate settings on dual monitors
    need help with separate settings on dual monitors: Windows 10 version 1903. Hi, I have a laptop small display (the main one) and an external large monitor (#2). I need to have separate settings for each. I'm having trouble - when I use scaling in display settings, or set icon size in "view", the setting will apply to both....
  8. need help with separate settings on dual monitors
  9. Needing help with dual-monitor wallpaper
    Needing help with dual-monitor wallpaper: Ok, so I have a Dual-Monitor Set up, as i'm sure a lot of people here do. I have 2 separate wallpapers. One for each monitor. They keep changing. I do not want them to change. I have tried registry edits, and looked through the Settings, but can't seem to get it to stay. Can...
  10. Need help with dual monitors
    Need help with dual monitors: Hello. I cannot get a dual monitor setup to work for the life of me. I've made a LITTLE progress though by tweaking the BIOS to load from the Mobo VGA port first on boot, but now the second monitor just stays lit up with the windows 10 logo and nothing else, while the first...
