Windows 10: Networks issue : How to fix low speed on ethernet connexion ? No issue with wifi interface
Discus and support Networks issue : How to fix low speed on ethernet connexion ? No issue with wifi interface in Windows 10 Gaming to solve the problem; Since this morning, my Ethernet connection is slow 50mbs max instead of 550mbs before. What I've tried : ⇾ Test the ethernet cable with another PC :... Discussion in 'Windows 10 Gaming' started by user-12156, Oct 5, 2023.
  1. Networks issue : How to fix low speed on ethernet connexion ? No issue with wifi interface
    Since this morning, my Ethernet connection is slow 50mbs max instead of 550mbs before. What I've tried : ⇾ Test the ethernet cable with another PC : 600mbs so it works fine⇾ Test with the Wi-Fi integrated to the pc : works well with good speed ~400mbs⇾ Reset network flush dns, restart interface , ... ⇾ Launched the troubleshooting network agent : did nothingInfos : OS : Windows 10 Pro Version 10.0.19045 Build 19045Network card : Realtek PCIe GbE Family Controller
  2. Gino Des Win User
    Issues with network adapters
    Hi Alfonso,
    To resolve this issue, we suggest that you run the Network troubleshooter when you switch from WiFi to Ethernet connection. The Network troubleshooter can help diagnose and fix common connection problems including clearing the network cache to obtain a new
    IP from the new network. Kindly follow the steps below:
    • In the search box on the taskbar, type Identify and repair network problems, and then select
      Identify and repair network problems from the list of results.
    • Follow the steps in the troubleshooter and see if that fixes the problem.
    If the issue persists, kindly try the troubleshooting steps on the following link:
    Fix network connection issues in Windows 10
    We recommend that you try the steps on the Update the network adapter driver,
    Run the Network troubleshooter followed by networking commands, and Use network reset to reinstall network devices sections.
    Let us know how it goes for us to assist you further.
    Gino Des, Oct 5, 2023
  3. I have a network Issue(Need to disable and reenable ethernet adapter after every boot)
    To better assist you, we would like to ask these questions:
    • Have you tried using other device to connect to the same network?
    • Does this issue happened on both WiFi and Ethernet connections?
    Meanwhile, kindly follow the steps given on this link:
    . Please skip the other steps that you've done in the past.
    Let us know the updates.
    Janeane Cru, Oct 5, 2023
  4. Rossolotl Win User
    Ethernet Issues Connecting To Internet
    Hi all,
    I'm hoping someone can help.
    My desktop has been working absolutely fine connected to the router with an ethernet cable. Good connection, good speed and no issues at all. Then a couple of days ago, it was intermittantly connecting to the internet - was connecting to the network but not the internet.
    My partner has a laptop and it's been connecting via Wifi no problems at all. So I switched my desktop to using Wifi and it works but not great - again intermittantly.
    My desktop is currently saying the ethernet connecting is "Unidentified Network - No Network" but I am connected via Wifi.
    When I run the the Windows Network Troubleshooter, it fixed the problem for about 10 minutes then same issue again. The problem was "Ethernet doesn't have a valid IP configuration"
    Any suggestions?
    Rossolotl, Oct 5, 2023
  1. Networks issue : How to fix low speed on ethernet connexion ? No issue with wifi interface - Similar Threads - Networks issue fix
  2. Networks issue : How to fix low speed on ethernet connexion ? No issue with wifi interface
    Networks issue : How to fix low speed on ethernet connexion ? No issue with wifi interface: Since this morning, my Ethernet connection is slow 50mbs max instead of 550mbs before. What I've tried : ⇾ Test the ethernet cable with another PC : 600mbs so it works fine⇾ Test with the Wi-Fi integrated to the pc : works well with good speed ~400mbs⇾ Reset network flush...
  3. Networks issue : How to fix low speed on ethernet connexion ? No issue with wifi interface
  4. Wifi Speed Issues
    Wifi Speed Issues: Hello,I have come across and issue that I have not had before, I am getting less the 5mbps download and up load speed on my desk top. It is a little older desktop approximately five years old with a 1060 graphics card.I have since gotten a new computer but I leave this one at...
  5. Wifi Speed Issues
  6. Wifi Speed Issues
  7. WiFi speed issues
    WiFi speed issues: After a reboot my WIFi speed is fine. if I immediately test the speed again, it has dropped radically.e.g. from 200Gb/s to 30 Gb/s Sometimes a further reboot will return the original speed, sometimes not, but it always drops off immediately. System is desktop Windows 10 Pro,...
  8. WIFI speed issue
    WIFI speed issue: Hi Team, Me facing an issue while using internet with WiFi connectivity on my PC. Me using 2 Mbps speed on my other devices but my PC just provide me max 1 Mbps why? Need your assistance. FYI - Realtek RTL8192CE Wireless LAN 802.11n PCI-E NIC, windows 10 recently...
  9. Windows 10 Networking Issue- WiFi AND Ethernet
    Windows 10 Networking Issue- WiFi AND Ethernet: Hi All, recently my lenovo idea pad stopped connecting to the internet via WiFi. I have tried other WiFi networks and using the ethernet both at home (where the problem initiated) and at work, an it seems my laptop will connect to the routers etc. but no internet connection...
  10. WiFi Speed Issue
    WiFi Speed Issue: I have a Toshiba Satellite with a new 500gb ssd and a clean Win 10 install. Internet download speed when connected to the router via cat 5 in approx. 150Mbps, but via wifi is about 2Mbps. My other laptop, phone and tablet all have no issues when connecting via wifi so this...
