Windows 10: "no audio output/input devices found" problem; no solutions work
Discus and support "no audio output/input devices found" problem; no solutions work in Windows 10 Gaming to solve the problem; I just updated a bunch of drivers on my computer. After the update, audio completely stopped working, and when I went to troubleshoot, it found no... Discussion in 'Windows 10 Gaming' started by INSERTOGNAMEHERE, Aug 7, 2023.
  1. "no audio output/input devices found" problem; no solutions work
    I just updated a bunch of drivers on my computer. After the update, audio completely stopped working, and when I went to troubleshoot, it found no input or output devices. By now, I've updated, uninstalled, and reinstalled my audio devices countless times. I took a screenshot of my device manager before uninstalling, and the NVIDIA Virtual Audio Device wave Extensible WDM didn't reinstall after restarting my computer, which it should have like the other devices. Many fixes don't work because I'm on Windows 11 and most are for Windows 10. Also went to this thread looking for answers, but no
  2. No audio input or output devices found
    After the last update of Windows 10, no audio devices are listed
    Searching in the device manager: all audio devices say it works fine
    The sound setting says: no output or input devices were found.
    JohnPennington3, Aug 7, 2023
  3. No Audio Input or Output Devices found
    After latest windows 10 update no audio devices are listed/
    Looking in device manager - the audio devices all say working OK
    But on bar at bottem of screen get speaker with red cross -- Playing audio - Audio trouble shouter cannot find any problems ..
    Sound settings say - No output or Input devices found.
    Have tried to re-install Realtek audio drivers for motherboard -- installed but no change
    David_Bexhill, Aug 7, 2023
  4. NTN
    NTN Win User
    Problem with input output device
    Right-click on the volume icon in your system tray, then click on “Troubleshoot sound problems”.
    Wait for the troubleshooter to detect issues. If anything is identified, you’ll be able to fix it with the click of a button.
    If you’re experiencing the “No Audio Output Device Is Installed” error, it might be because of your audio drivers.
    Here are the steps to follow to update your audio driver on Windows 10.
    Press the Windows + X keys on your keyboard and click on the Device Manager option from the menu.
    Expand the Sound, video and game controllers menu by clicking on the arrow next to it.
    Right-click on your audio device listed in the menu and choose Update Driver.
    Allow Windows 10 to look for the newest driver on your local computer or online, then follow any on-screen instructions.
    If the update didn’t work, we recommend manually uninstalling and allowing Windows 10 to re-install your audio driver. Here’s everything you need to do.
    Right-click on your audio device listed in the menu and choose the Uninstall device option.
    Restart your computer. Windows 10 should automatically re-download the latest version of your audio device driver.
  1. "no audio output/input devices found" problem; no solutions work - Similar Threads - audio output input
  2. no output or input device found
    no output or input device found: I recently updated laptop asus k513ea and now I cant get any sound or microphone from my laptop.I tried various troubleshooting methods, but I just cant seem to get it working again. I didn't have any issues before the update and my laptop hasn't moved so I'm sure it must be...
  3. Issue of "No audio output/input devices found"; no solutions on the internet works
    Issue of "No audio output/input devices found"; no solutions on the internet works: I have updated several drivers suggested on the Dell Support site, including audio drivers. After these updates, no audio output/input device shows. Audio only works with AirPods. I have tried every possible "fix," and none are working.I discovered that the "Realtek Audio...
  4. Issue of "No audio output/input devices found"; no solutions on the internet works
  5. "no audio output/input devices found" problem; no solutions work
    "no audio output/input devices found" problem; no solutions work: I just updated a bunch of drivers on my computer. After the update, audio completely stopped working, and when I went to troubleshoot, it found no input or output devices. By now, I've updated, uninstalled, and reinstalled my audio devices countless times. I took a screenshot...
  6. Audio Input and Output Device is not working
    Audio Input and Output Device is not working: Few days ago suddenly my laptop internal audio is stopped working . I can use my headphones just fine, but the internal speaker itself is not working. At first I thought it was a problem with the sound , but after going to device manager , I found out that speaker and...
  7. No input device found, output device not working.
    No input device found, output device not working.: Hello, I've recently purchased an Alienware computer and have been been experiencing issues. The audio on the computer doesn't seem to work. I can't hear anything coming out, and the computer cant hear me. I have headphones, with a microphone that needs to be plugged in....
  8. no input or output audio devices found
    no input or output audio devices found: My computer used to play audio and one day it stopped and says no audio playback devices are found on this computer. When I run the troubleshooter it says the update should take care of it and to restart your computer. Which I have done multiple times. Any ideas?...
  9. No audio input or output devices found
    No audio input or output devices found: After the last update of Windows 10, no audio devices are listed Searching in the device manager: all audio devices say it works fine The sound setting says: no output or input devices were found....
  10. No Audio Input or Output Devices found
    No Audio Input or Output Devices found: After latest windows 10 update no audio devices are listed/ Looking in device manager - the audio devices all say working OK But on bar at bottem of screen get speaker with red cross -- Playing audio - Audio trouble shouter cannot find any problems .. Sound settings say...
