Windows 10: No audio output sound on my monitor. Window 11Pro and no connection to my bluetootth speaker
Discus and support No audio output sound on my monitor. Window 11Pro and no connection to my bluetootth speaker in Windows 10 Software and Apps to solve the problem; Device and update on bluetooth... Discussion in 'Windows 10 Software and Apps' started by Rosly Hasan, Mar 21, 2025.
  1. No audio output sound on my monitor. Window 11Pro and no connection to my bluetootth speaker
  2. vsrj Win User
    Internal monitor speakers showing up as audio device but not an audio output option
    I am using a new Dell XPS 15 laptop (Windows 11) connected (via USB-C) to a Dell 4K monitor via a Thunderbolt Dock. I'm keeping the laptop closed and using only the external monitor. However, I cannot play audio through the monitor's integrated speakers. When I go to sound settings in Windows 11, I can only see the laptop's Realtek speakers listed. The monitor, however, is shown as an "audio" device on the devices page. How can I make the speakers inside the monitor show up as an audio output option? I have installed all Windows 11 and Dell XPS updates, including BIOS.
  3. Alx181 Win User
    how to select the output audio speakers
    To change the speaker output on Windows Media Player, you can try the following steps:
    1. Open Windows Media Player.
    2. Click on “Tools” and then “Options”.
    3. Click on the “Devices” tab.
    4. Click on “Speakers” and then “Properties”.
    5. Select the audio device you want to use and click on “OK”.
    6. You may also have to restart WMP for changes to take effect.
    If the above steps don’t work, you can try changing the default sound device in Windows 11. Here’s how you can do it:
    1. Open the Settings app by pressing the Windows key + I.
    2. Click on “System” and then “Sound”.
    3. Under the “Output” section, click on the “Choose where to play sound” setting.
    4. Select the speakers, headphones, or headsets you want to use.
    Alx181, Mar 22, 2025
  4. No audio output sound on my monitor. Window 11Pro and no connection to my bluetootth speaker
    dual monitors stops sound
    Hi David,
    To assist you better, I suggest you to answer the below questions.
    • When will the sound disable, when playing through main monitor or the extended monitor?
    • Did you try enabling the sound from the sound drivers and check if it helps?
    • Since from when are you facing this issue?
    This issue causes because the monitor automatically takes the HDMI sound as the Default input. Disable and enable the speakers and check if it helps.
    I suggest you to try the below steps and check if it helps.
    • Right click on the volume control and then
      Properties
    • When you connect the HDMI it becomes the default output device, even though it has no speakers.
    • You need to change this back to "Speakers" and set as default.
    No audio output sound on my monitor. Window 11Pro and no connection to my bluetootth speaker 277833d1379328243t-hdmi-monitor-no-speakers-no-sound-anywhere-when-connected-sound.png
    Hope this helps. Keep us posted to help you better.
    Sachin Venkatesh, Mar 22, 2025
  1. No audio output sound on my monitor. Window 11Pro and no connection to my bluetootth speaker - Similar Threads - audio output sound
  2. No audio output sound on my monitor. Window 11Pro and no connection to my bluetootth speaker
    No audio output sound on my monitor. Window 11Pro and no connection to my bluetootth speaker: Device and update on bluetooth https://answers.microsoft.com/en-us/windows/forum/all/no-audio-output-sound-on-my-monitor-window-11pro/1fd290df-0371-4d00-af04-052714e271a4
  3. Win 11Pro No output audio device instilled
    Win 11Pro No output audio device instilled: Win 11Pro No output audio device instilled https://answers.microsoft.com/en-us/windows/forum/all/win-11pro-no-output-audio-device-instilled/9a82d243-4bd2-456f-a63e-21ec9300233d
  4. Win 11Pro No output audio device instilled
  5. MY SPEAKERS HAV NO SOUND OUTPUT
    MY SPEAKERS HAV NO SOUND OUTPUT: MY SPEAKERS HAVE NO SOUND https://answers.microsoft.com/en-us/windows/forum/all/my-speakers-hav-no-sound-output/cbf9de7e-aacf-4251-9648-b1023e8f3c66
  6. MY SPEAKERS HAV NO SOUND OUTPUT
  7. MY SPEAKERS HAV NO SOUND OUTPUT
  8. My sound output is automatically switching at a fast pace between my speaker and connected...
    My sound output is automatically switching at a fast pace between my speaker and connected...: https://streamable.com/h9vloehttps://streamable.com/h2fpebHello,I am currently facing an issue whereby connecting any form of audio output headphones [wired + Bluetooth] / earphones show up as a sound output, however, they are constantly being switched between my speakers on...
  9. Microphone output is connected to the output of my speaker
    Microphone output is connected to the output of my speaker: I have been using my computer for almost a year now, just a few days ago I wanted to use my mic in a recording but it didn't work, shortly after I played some audio through my speakers and noticed that my mic is playing it back, I checked the headset and used it in another...
  10. [20H1]Monitor speaker had no sound output after a external monitor is connect to my...
    [20H1]Monitor speaker had no sound output after a external monitor is connect to my...: During using the latest generation intel platform notebook unit, the unit is installed 20H1windows 10 v2004 OS connect a external monitor to the unit by type-c port Then switch the display to monitor onlysecond screen only,it can be found video can be switched to...
