Windows 10: No start key - taskbar does not respond to R mouse click + no edge ico
Discus and support No start key - taskbar does not respond to R mouse click + no edge ico in Windows 10 Support to solve the problem; After reading all of the possible steps to fix what appears to be a common situation in Windows 10. I find that none of them work. My computer has all... Discussion in 'Windows 10 Support' started by BlackWindow, Nov 3, 2016.
No start key - taskbar does not respond to R mouse click + no edge ico - Similar Threads - start key taskbar
Taskbar, start key, settings and run not responding
in Windows 10 GamingTaskbar, start key, settings and run not responding: Logged onto my laptop today to find the taskbar and start button completely unresponsive. I can’t use them to open any applications or to type, and there is a loading symbol where my mouse tracker should be when I hover over them. I tried to use windows + I and windows + R to... -
in Windows 10 Software and AppsTaskbar, start key, settings and run not responding: Logged onto my laptop today to find the taskbar and start button completely unresponsive. I can’t use them to open any applications or to type, and there is a loading symbol where my mouse tracker should be when I hover over them. I tried to use windows + I and windows + R to... -
in Windows 10 BSOD Crashes and DebuggingTaskbar, start key, settings and run not responding: Logged onto my laptop today to find the taskbar and start button completely unresponsive. I can’t use them to open any applications or to type, and there is a loading symbol where my mouse tracker should be when I hover over them. I tried to use windows + I and windows + R to... -
Icons in Taskbar not responding to mouse clicks
in Windows 10 GamingIcons in Taskbar not responding to mouse clicks: Not sure how to describe this properly, but it seems others have similar issues. Some applications work as they did with Win10Pro have 11Pro now.Outlook, Calculator, Explorer, Settings; all behave as they did prior. Normal clicking selects the app and makes it active,... -
in Windows 10 Software and AppsIcons in Taskbar not responding to mouse clicks: Not sure how to describe this properly, but it seems others have similar issues. Some applications work as they did with Win10Pro have 11Pro now.Outlook, Calculator, Explorer, Settings; all behave as they did prior. Normal clicking selects the app and makes it active,... -
Apps not responding to mouse clicks.
in Windows 10 Ask InsiderApps not responding to mouse clicks.: Not sure if its a Windows 10 problem or not but, I have had my (pre-built but upgraded) PC for just over a year now and it's great! but for 1, it suddenly started feeling really slow and freezing (I have an m.2 nvme) but, most annoyingly, apps and games will just not respond... -
Mouse clicks not responding
in Windows 10 Drivers and HardwareMouse clicks not responding: Today, I opened the computer. On the lock screen, everything worked as normal, but once it started, no mouse clicks would respond. If I hover over something in the taskbar, it lights up as it should, but clicking on anything does nothing. If I use the touchscreen, the clicks... -
MS Edge does not respond
in Browsers and EmailMS Edge does not respond: I have tried to open Edge from all the "short cuts". The splash will show for a moment, then nothing. Also the "Search the web and Windows" box is non resposive. Neither option has worked since upgrade. 25235 -
R/Click Mouse
in Windows 10 SupportR/Click Mouse: Lately, if I right click on a file to copy or cut, the screen blinks and it goes to my desktop. If i click on the same file again it does OK and the menu comes up. Any ideas? I think but not sure that it started after the last update to 1058.104 41196
