Windows 10: odd problem : W10 not picking up monitor audio until W10 "troubleshoot Sound problems "...
Discus and support odd problem : W10 not picking up monitor audio until W10 "troubleshoot Sound problems "... in Windows 10 Ask Insider to solve the problem; I have this odd problem that started a few months ago (FYI have auto updates on). When I start up my computer, the audio output is automatically set to... Discussion in 'Windows 10 Ask Insider' started by /u/Existing_Repair5931, Dec 9, 2020.
  1. odd problem : W10 not picking up monitor audio until W10 "troubleshoot Sound problems "...
    I have this odd problem that started a few months ago (FYI have auto updates on). When I start up my computer, the audio output is automatically set to my headphones , instead of usually going to my monitor speaker channel. The weird thing is when I open the volume mixer , the "monitor speakers" channel is nowhere to be found. When i " Troubleshoot Sound Problems", and allow for a "system scan" , all of a sudden my audio is directed through my pc speakers like nothing happened.
    Has anyone else experienced this?
    How would I solve this weird issue?
    submitted by /u/Existing_Repair5931
    [link] [comments]
  2. sttubs Win User
    Odd monitor problem
    Odd monitor problem *NEW INFO*
    I have a monitor (listed in my specs) that sometimes does not turn on when the computer is started or brought out of sleep mode. If I unplug the power cord & plug it back in it works fine, no other problems with it at all. Any thoughts? Is it eminently going to fail, should I RMA?
    sttubs, Dec 9, 2020
  3. Trixx and W10 Problems
    @W1zzard
    What's the deal with trixx these days?
    I mean, with W10 it f*cks with the card and locks the last set clock even though the check box to restore clocks is checked/ unchecked whatever...
    I know its a W10 thing but is there anyway you could fix this or suggest a fix?
    I cant boot once I've set my cards to high.. well it boots then artifacts and then blank screen.
    I used the latest version of trixx and the 635235030956777758 one 4.8.2 me thinks (the trusted one) but even this version screws with the system...
    Any Ideas?
    And also besides the BS wait 2 crashes in W10 to happen just to goto safe mode How can I get there besides waiting for windows to do its 2 times blank screen?
    Even in safe mode and removing the software, the card is locked to the last bad clock, and I've spent some time playing around to get things back to normal but nothing works except a clean OS install.
    W1zzard can you help?
    Thanks man
    fullinfusion, Dec 9, 2020
  4. odd problem : W10 not picking up monitor audio until W10 "troubleshoot Sound problems "...
    at least W10 is fast to do the install lol
  1. odd problem : W10 not picking up monitor audio until W10 "troubleshoot Sound problems "... - Similar Threads - odd problem W10
  2. Activation W10 Problem
    Activation W10 Problem: After motherboard change due to failure, I get error 0xC004F211. W10 seems to be functioning but I get a message on the home screen to Activate. Winver shows I have a valid copy of W10 registered on my computer, but the Activation Troubleshooter says it cannot find a digital...
  3. w10 boot problem
    w10 boot problem: when i select my usb on boot screen and i enter there is a black screen opening and it says a disk error occurredi am used rufus and i dont know the problem pls help my laptop camed pre installed w10when i select uefi in bios in boot screen there is only harddisk option when...
  4. w10 activation problem
    w10 activation problem: I cant activate my window it always telling me this and i already remove kms pico that installed in my pc https://answers.microsoft.com/en-us/windows/forum/all/w10-activation-problem/4288692b-4159-4ea6-a5ac-d3ce87132b2e
  5. W10 Problem
    W10 Problem: so i Got a virus with 20 notifications that i have a trojan or a virus. so i renstalled windows because my cortana search does not work when im trying to download a game launcher it finishes the download at its MB but its stuck on the blue circle. and i cant open any steam...
  6. w10 update problems
    w10 update problems: Hi. I am trying to update my W10. Many times now, i have downloaded it, and it fails during installation, at about the 35% mark. I get an error code of 0x80070002. I have been through trouble-shooting about 3 times now. Can anyone offer advice on this please?...
  7. Mouse with W10 problems
    Mouse with W10 problems: Since installing W10, I cannot resize a window mouse shows the corers & side options, but does nothing, can't grab & drop, and can't highlight text to move or delete. I'm using an M705 Logitech mouse which was working just fine b4 going to W10....
  8. OneDrive problem on W10
    OneDrive problem on W10: On my desktop I run W10 with access to my OneDrive. I suddenly cannot open a huge amount of files on this drive. Default icons for the files are still displayed in Windows Explorer, but when I right click the icons for properties, Explorer says their file sizes on the disk is...
  9. W10 Activation problem
    W10 Activation problem: I am going nuts. I have an Alienware M17x previously running W7 Home. I upgraded to W10 Home last week (V1511). It went well and W10 was shown as activated with a digital entitlement. Great. However, now after a week or so, in the middle of using my machine normally I...
  10. W10 big problem
    W10 big problem: Hello, i have a problem with my computer after installing w10 in games totaly random i get a 0.5s freeze or when i watch movies the video gets blurry/grey for 1sec(still working and playing). 13807
