Windows 10: Pavillion 2023, battery percentage stuck at 13%, AC cable plugged in battery wont charge up
Discus and support Pavillion 2023, battery percentage stuck at 13%, AC cable plugged in battery wont charge up in Windows 10 Software and Apps to solve the problem; I've done all the diagnostic tests for both power battery and adapted both pass, windows version is up to date, I've deleted in device manager the... Discussion in 'Windows 10 Software and Apps' started by Kleiton Aliaj, May 12, 2024.
Pavillion 2023, battery percentage stuck at 13%, AC cable plugged in battery wont charge up - Similar Threads - Pavillion 2023 battery
Plugged in but not charge the Battery and stuck at 0%
in Windows 10 GamingPlugged in but not charge the Battery and stuck at 0%: I have lenovo ideapad gaming 3 intel i5 gtx 1650 laptop and I update windows 11 24h2 update. I use daily after update and work normally but one day I open laptop and working around 2 to 3 min and suddenly switch off . I plugged the charger and on the laptop . I saw my laptop... -
in Windows 10 Software and AppsPlugged in but not charge the Battery and stuck at 0%: I have lenovo ideapad gaming 3 intel i5 gtx 1650 laptop and I update windows 11 24h2 update. I use daily after update and work normally but one day I open laptop and working around 2 to 3 min and suddenly switch off . I plugged the charger and on the laptop . I saw my laptop... -
in Windows 10 GamingPavillion 2023, battery percentage stuck at 13%, AC cable plugged in battery wont charge up: I've done all the diagnostic tests for both power battery and adapted both pass, windows version is up to date, I've deleted in device manager the battery firmware and restarted pc, problem didn't solve please help... -
battery not charging, plugged in
in Windows 10 Network and Sharingbattery not charging, plugged in: battery not charging, plugged in https://answers.microsoft.com/en-us/windows/forum/all/battery-not-charging-plugged-in/88491c52-331c-44b9-b54f-e250c0d5d1e9 -
Battery plugged in, not charging
in Windows 10 Drivers and HardwareBattery plugged in, not charging: I have my USB-C charging cable plugged into the charging port of my laptop. However, the batter icon on my bottom right says (when I moused over it) "5% available (plugged in, not charging). Can't solve this issue. Anyone with solution ? I am on Window 10 Pro, ThinkPad X1... -
Battery plugged in but not charging.
in Windows 10 Drivers and HardwareBattery plugged in but not charging.: I have recently noticed that the battery on my Dell Laptop, which runs on Windows 10. (64 bit) is not charging and displays the note "plugged in but not charging. I have read a number of possible easy solutions, none of which seem to work. The adapter and leads etc seem to be... -
battery plugged in not charging
in Windows 10 Drivers and Hardwarebattery plugged in not charging: My battery won't charge. Says plugged in not charging https://answers.microsoft.com/en-us/windows/forum/windows_10-hardware/battery-plugged-in-not-charging/88e70d57-e863-4a95-8925-9bf98ee0aa69 -
battery plugged in but not charging
in Windows 10 Customizationbattery plugged in but not charging: Status on laptop shows battery plugged in but not charging (battery is at 80%). When I disconnect the mains, the laptop shuts down.... -
Battery stuck at 80% plugged in but not charging
in Windows 10 BSOD Crashes and DebuggingBattery stuck at 80% plugged in but not charging: Not sure why I get this message that my PC isn't charging even though it's plugged in. It doesn't matter if I select best battery life or best performance in the slider. It seems to always stop charging at some point lower than 100%....
