Windows 10: pc been crashing/freezinf for a while now need help solving the problem
Discus and support pc been crashing/freezinf for a while now need help solving the problem in Windows 10 Gaming to solve the problem; my pc freezes too much you cant do anything for 1.5 hours without it freezing i have the sys and app logs of last 24 hours from event viewer ready to... Discussion in 'Windows 10 Gaming' started by Albert Basnet, Dec 6, 2024.
  1. pc been crashing/freezinf for a while now need help solving the problem
    my pc freezes too much you cant do anything for 1.5 hours without it freezing i have the sys and app logs of last 24 hours from event viewer ready to show i really need to fix this.https://drive.google.com/drive/folders/1wYHi6NBnjVMh_4sl5ezNlkxcBxmfjGXL?usp=drive_link
  2. jsmin Win User
    Windows Explorer crashes and thumbnails problem
    Hi, I hope you can help me.
    Windows Explorer is no longer showing thumbnails on files played by Windows Media Player. I've run cmd and regsvr32 shmedia.dll and regsvr32 shimgvw.dll. That seemed to solve the problem...but it created a different one. Now when I try to open a folder on an external hard drive it crashes. I read in an old 2008 post it was an avi file causing the problem and suggested the run cmd regsvr32 /u shmedia.dll. That solved the opening problem but recreated the thumbnail problem. Any help to achieve both functions would be greatly appreciated. Thank you.
    jsmin, Dec 6, 2024
  3. peach1971 Win User
    all games crash!
    I suggest you run rthdribl > http://www.daionet.gr.jp/~masa/archives/rthdribl_1_2.zip
    Increase the window size step by step and watch your vga temps permanently.
    What happens?
    If it crashes, run at stock speeds as suggested before and retry.
    P.S.: When your system locks, does the display signal turn off after a time?
    Stuttering sound or no sound at all when freezing?
    What X1800XT model do you own exactly?
    peach1971, Dec 6, 2024
  4. EarthDog Win User
    1070 Overheat Crash x(
    Yes try it again... lol... we were waiting for that!
    You have steps listed....try to find a another pc to try...try to reset the bios and see if that for some reason would help. But yes, try putting it back in. If not, id say rma time.
    EarthDog, Dec 6, 2024
  1. pc been crashing/freezinf for a while now need help solving the problem - Similar Threads - been crashing freezinf
  2. Need help in solving a disk problem.
    Need help in solving a disk problem.: Hi.I am running windows 10 in 128 GB SSD and I have tried fedora 41 in dual boot. I got some login key error in it. So, I decided to clean install it again. To do that I logged in windows and tried to delete that partition, but can't able to. That partition has only help...
  3. Need help in solving a disk problem.
  4. pc been crashing/freezinf for a while now need help solving the problem
    pc been crashing/freezinf for a while now need help solving the problem: my pc freezes too much you cant do anything for 1.5 hours without it freezing i have the sys and app logs of last 24 hours from event viewer ready to show i really need to fix this.https://drive.google.com/drive/folders/1wYHi6NBnjVMh_4sl5ezNlkxcBxmfjGXL?usp=drive_link...
  5. need help solve this problem
    need help solve this problem: i tried to install windows after i click on any button on activate windows page it get stuck on this page tried pluging usb on a another device it worked.i updated my bios and everything but on this pc it wont go to next page...
  6. need help solve this problem
  7. Need help solving a consistent PC crash
    Need help solving a consistent PC crash: Hi everyone,I've been having this issue recently that seemingly went away for a day or two and just came back today. Primarily when gaming, my PC will crash in 1 of 2 ways, either my display will go black and cycle through differing sources before displaying "no signal" or...
  8. Need help solving a consistent PC crash
  9. Need help solving a consistent PC crash
  10. Need help with solving this weird problem.
    Need help with solving this weird problem.: [ATTACH] submitted by /u/Rare_Many1300 [link] [comments] https://www.reddit.com/r/Windows10/comments/m63jp9/need_help_with_solving_this_weird_problem/
