Windows 10: Please help 0xc0000001 and 0xc0000089 error at the same time !!
Discus and support Please help 0xc0000001 and 0xc0000089 error at the same time !! in Windows 10 Software and Apps to solve the problem; I recently decided to restart my pc but this weird repair loop started happening I tried so many things but nothing would work I couldn’t get into my... Discussion in 'Windows 10 Software and Apps' started by Jon6754a, Oct 1, 2024.
  1. Jon6754a Win User
    I recently decided to restart my pc but this weird repair loop started happening I tried so many things but nothing would work I couldn’t get into my pc so I tried something on YouTube and now I get both of these errors and I can’t even reach the normal startup settings I’m crying right now my mom is going to beat my **** after doing the tutorial to fix the blue screen repair loop my pc also turns off every minute someone please I beg you I just want to get back in my pc again : https://imgur.com/a/KwErRUv image proof
  2. Abdul_Malik, Oct 1, 2024
  3. Zam_M Win User
    Error code 0xc0000001
    Tried Andre Da Costa suggestion - at the end of the installation process comes the message "Inaccessible boot device" and it reloop again to try to boot.
    Zam_M, Oct 1, 2024
  4. Please help 0xc0000001 and 0xc0000089 error at the same time !!
    Computer Error (0xc0000001) Windows 10
    Thank you for posting your question in the Microsoft Community.
    I can understand that it must be difficult for you when things are not working as it should. Sorry to know that you are facing this issue.
    Please answer these questions to get more clarity on this issue:
    • What is the make and model of the pc?
    • Did you make any changes to the pc prior to this issue?
    • From which website did you download the repair tools?
    Suggest you to refer to the suggestion provided by “ThofikhAhamad” from this thread to check if that helps.
    Redirecting
    Keep us informed to help you further.
    Srimadhwa B, Oct 1, 2024
  1. Please help 0xc0000001 and 0xc0000089 error at the same time !! - Similar Threads - Please help 0xc0000001
  2. Please help 0xc0000001 and 0xc0000089 error at the same time !!
    Please help 0xc0000001 and 0xc0000089 error at the same time !!: I recently decided to restart my pc but this weird repair loop started happening I tried so many things but nothing would work I couldn’t get into my pc so I tried something on YouTube and now I get both of these errors and I can’t even reach the normal startup settings I’m...
  3. Error code: 0xc0000001 and BSOD Bad_Systrm_Config_Info at the same time
    Error code: 0xc0000001 and BSOD Bad_Systrm_Config_Info at the same time: Hello there, I'm having 2 errors at the same time; error code 0xc0000001 and bsod Bad System Config Info. I'm looking how to fix the issue on the internet, the proven method is using the automatic repair on start up. But, these two error won't let me access it because they...
  4. Error code: 0xc0000001 and BSOD Bad_Systrm_Config_Info at the same time
  5. Error code: 0xc0000001 and BSOD Bad_Systrm_Config_Info at the same time
  6. Windows repair boot loop into error 0xc0000001 [Please Help]
    Windows repair boot loop into error 0xc0000001 [Please Help]: I woke up today after using my pc successfully the other night and found mysf stuck in a boot repair loop, I tried various of things on the internet such as trying to go into safe mode it wouldn't even let me do that and a lot of cmd stuff which didn't work friend said it's...
  7. Windows repair boot loop into error 0xc0000001 [Please Help]
  8. Windows repair boot loop into error 0xc0000001 [Please Help]
  9. Same error appearing constantly. PLEASE HELP
    Same error appearing constantly. PLEASE HELP: [ATTACH] submitted by /u/ameensj [link] [comments] https://www.reddit.com/r/Windows10/comments/k2i6el/same_error_appearing_constantly_please_help/
  10. Error 0xc0000001
    Error 0xc0000001: I am trying to start my pc as usual but i am getting bad system confg info problem. How to login to my pc safely please help me . https://answers.microsoft.com/en-us/windows/forum/all/error-0xc0000001/e363afbf-5952-462d-b8c1-08e1f47c6209
