Windows 10: PLEASE HELP WITH MY WEIRD SOUND SYSTEM PROBLEM !
Discus and support PLEASE HELP WITH MY WEIRD SOUND SYSTEM PROBLEM ! in Windows 10 Software and Apps to solve the problem; Hello everyone, I came across a very weird issue that already has wasted lots of my time and energy, With no luck. I hope you can help me with this.... Discussion in 'Windows 10 Software and Apps' started by Behzad Hodaee1, Oct 14, 2024.
PLEASE HELP WITH MY WEIRD SOUND SYSTEM PROBLEM ! - Similar Threads - PLEASE HELP WEIRD
in Windows 10 GamingPLEASE HELP WITH MY WEIRD SOUND SYSTEM PROBLEM !: Hello everyone, I came across a very weird issue that already has wasted lots of my time and energy, With no luck. I hope you can help me with this. This is what happened :Few months ago my Dell E6420 laptop soundcard IDT/ Nvidia got an issue and stopped playing sounds from... -
MY sound is sounding weird.
in Windows 10 BSOD Crashes and DebuggingMY sound is sounding weird.: So I have an Optiflex 3020 and every time I unplug my headset the sound sounds different afterwards and to fix it every time I have to go to sound settings and disable then re-enable my speakers/headphones. can someone help?... -
sound and system sounds please
in Windows 10 Customizationsound and system sounds please: what is the different between sound and system sounds please https://answers.microsoft.com/en-us/windows/forum/all/sound-and-system-sounds-please/3519c99d-08f5-4ec8-93ce-4f8efc2c1485 -
Weird bug on my system. Please HELP !!
in AntiVirus, Firewalls and System SecurityWeird bug on my system. Please HELP !!: Hi:I have a HP 15" Pavilion laptop with 2.59GHz Intel i7 Core, 12GB RAM, touchscreen laptop running Win 10. It has acquired some sort of bug on the hard drive. It appears randomly, on and off, as round, semi-transparent circles with more opaque concentric spots to the right... -
A weird problem HELP
in Windows 10 Ask InsiderA weird problem HELP: Hello everyone, I have a very rare problem. When trying to play any type of video on my pc after the last windows update my pc stops and I am on the blue screen with the following errors "video tdr failure" "amdkmdag.sys" I looked everywhere and I don't know how to fix it.... -
Weird sound problem
in Windows 10 Drivers and HardwareWeird sound problem: So after some weeks from a clean installation of windows 10 a weird sound problem has appeared. my microphone just stops working after some momments and i can see that it works perfectly. i pluged in another mic to see if it was broken but no, same problem there too.i was on... -
Sound Problem on Windows 10 Please Help
in Windows 10 Drivers and HardwareSound Problem on Windows 10 Please Help: Hi I would like to ask if anyone has the solution to the following sound issue: Upon startup, when I play music Spotify or Youtube or any other app, the music begins loud, but after around a minute, the music becomes softer. This issue only occurs the first time I play... -
Weird sound problem in Windows 10 System sounds not playing
in Windows 10 Drivers and HardwareWeird sound problem in Windows 10 System sounds not playing: I have a strange problem in W10 .. Fall Creators Update... but it is NOT no sound... just many system sounds do not play and will not play out of the Control Panel sound app sound test. The .wav files all play if I go to /Windows/media and select them, but will not from the... -
Some weird sound problem.
in Windows 10 Drivers and HardwareSome weird sound problem.: Basically, everything works, except for voice chat. Whenever Skype is launched, or Teamspeak, or even the Steam calls, it completely crashes the sound of the computer. It's not the output devices, or the automatic volume lowering from communications, it just completely...
