Windows 10: PLS HELP!!! battery charging is stuck at 50% and stops charging although ot's plugged in,...
Discus and support PLS HELP!!! battery charging is stuck at 50% and stops charging although ot's plugged in,... in Windows 10 BSOD Crashes and Debugging to solve the problem; while charging when the battery reaches 50% it stops charging and it's status is (plugged in, not charging) I uninstalled the drivers and removed the... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by nonaelshafei, Aug 9, 2018.
  1. PLS HELP!!! battery charging is stuck at 50% and stops charging although ot's plugged in,...
    while charging when the battery reaches 50% it stops charging and it's status is (plugged in, not charging) I uninstalled the drivers and removed the battery and shut down the laptop ,inserted the battery again and turned it on as the drivers will be automatically installed , but nothing changed.
  2. Battery stops charging at 50%
    I have a Sony Vaio laptop, Windows 10, the battery charges to 50% then stops charging. It displays 'plugged in, not charging'. Any suggestions how to deal with this problem?
    CetinElmas, Aug 9, 2018
  3. Battery stops charging at 50%
    Apparently there is a setting (on Vaios only?) to limit the battery charging to 50% or 80% to increase useful battery life. I changed it to 80%, now my battery charges to 80%. It is also possible to remove this limit altogether so that the battery charges
    to 100%.
  4. simrick Win User
    Battery Not Charging
    Not sure about ASUS, but I do know that Dell use a chip in their chargers now, to make sure you use an authentic Dell charger. These chips go bad, and your laptop will stop charging or charge at a very slow rate - so slow, that the only way to get the thing charged is to shut it down and leave it plugged in overnight.
    And, batteries going bad, will stop charging.
    simrick, Aug 9, 2018
  1. PLS HELP!!! battery charging is stuck at 50% and stops charging although ot's plugged in,... - Similar Threads - PLS HELP battery
  2. Plugged in but not charge the Battery and stuck at 0%
    Plugged in but not charge the Battery and stuck at 0%: I have lenovo ideapad gaming 3 intel i5 gtx 1650 laptop and I update windows 11 24h2 update. I use daily after update and work normally but one day I open laptop and working around 2 to 3 min and suddenly switch off . I plugged the charger and on the laptop . I saw my laptop...
  3. Plugged in but not charge the Battery and stuck at 0%
  4. Battery is plugged in and charging, but stuck in zero and never charges above it.
    Battery is plugged in and charging, but stuck in zero and never charges above it.: I use my laptop updated to windows 10 to all of my online classes. It's quite a bit old, and its battery is nowadays stuck in zero, it says it's plugged in and charging but stuck at zero. I kindly request a solution to this prevailing problem as I'm a student and my laptop is...
  5. Battery not charging. Plugged in, not charging
    Battery not charging. Plugged in, not charging: Hello, I am using HP pavilion 360 , it has been months since the message is reading "plugged in, not charging" and now the percentage has decreased to 75%. I have tried to reinstall Microsoft ACPI- Complaint Control Method Battery but it didn't work. Now what should I do?...
  6. Battery stops charging after plugging in
    Battery stops charging after plugging in: [IMG]BWhem I charge my computer, it stops after 5 seconds or so. Please notice on the battery report how this reflects. I have already tried every solution that there is. Can somebody interpretate my battery report and tell me what’s going on?...
  7. Battery plugged in, not charging
    Battery plugged in, not charging: I have my USB-C charging cable plugged into the charging port of my laptop. However, the batter icon on my bottom right says (when I moused over it) "5% available (plugged in, not charging). Can't solve this issue. Anyone with solution ? I am on Window 10 Pro, ThinkPad X1...
  8. battery plugged in not charging
    battery plugged in not charging: My battery won't charge. Says plugged in not charging https://answers.microsoft.com/en-us/windows/forum/windows_10-hardware/battery-plugged-in-not-charging/88e70d57-e863-4a95-8925-9bf98ee0aa69
  9. battery plugged in but not charging
    battery plugged in but not charging: Status on laptop shows battery plugged in but not charging (battery is at 80%). When I disconnect the mains, the laptop shuts down....
  10. Battery stuck at 80% plugged in but not charging
    Battery stuck at 80% plugged in but not charging: Not sure why I get this message that my PC isn't charging even though it's plugged in. It doesn't matter if I select best battery life or best performance in the slider. It seems to always stop charging at some point lower than 100%....
