Windows 10: Popup Not Appearing When Device is Plugged into Audio Jack, and No Audio Input Detected...
Discus and support Popup Not Appearing When Device is Plugged into Audio Jack, and No Audio Input Detected... in Windows 10 Gaming to solve the problem; I am using the MI Notebook 14 with the device model XMA1901-DG. I have been using Sony MDR-EX255AP in-ear wired headphones, and usually, when I plug a... Discussion in 'Windows 10 Gaming' started by Suvra Bhattacharjee, Jan 7, 2024.
  1. Popup Not Appearing When Device is Plugged into Audio Jack, and No Audio Input Detected...
    I am using the MI Notebook 14 with the device model XMA1901-DG. I have been using Sony MDR-EX255AP in-ear wired headphones, and usually, when I plug a device into the audio jack, a popup appears, allowing me to select whether it is a speaker or headphones. However, recently, this popup has stopped showing up. Moreover, my laptop is not accepting any audio input, even when I connect this headphone. Interestingly, the headphone microphone is working on other laptops and phones. Could this be a potential issue?
  2. How to get a popup when device is plugged in audio jack?
    DarshanPatwa, Jan 7, 2024
  3. Does Windows log when you plug in / unplug an audio device from a 3.5mm jack?
    When an audio device is plugged/unplugged from the 3.5mm jack, does Windows log that anywhere?
    Not by default. You have to write an app to detect plug in/plug out. Note the jack has to support jack-presence detection.
    See Device Events - Windows applications | Microsoft Docs for more information and sample code.
    You can extend the sample code to log to a file or create a custom user define event in the event log.
    Suggestion:
    • Add code to use your built in webcam to take a photo of the culprit.
    DavidPostill, Jan 7, 2024
  4. Popup Not Appearing When Device is Plugged into Audio Jack, and No Audio Input Detected...
    Windows 10 not detecting devices plugged into 3.5mm audio jack. Please Help!
    My problem with my Dell Inspiron 5558 laptop is that whenever I plug a device in, the computer does not detect anything is plugged in.
    BEFORE ANYONE responds on solutions, let me make sure you understand the problem. I am
    VERY specific. It does not DETECT anything plugged into the audio jack. Most people with issues with their audio jack have an issue where they will plug in headphones in the audio jack, but upon doing so, the audio will continue to
    play through external speakers built into their laptop, and not through the headphones because they were not detected due to a driver issue. That is
    NOT my issue. The headphone jack and all my audio drivers and all my Windows Audio services and related services are all functioning and have ALL been messed with to try to resolve my much weirder issue. For me, all devices plugged
    into the audio jack work fine. It will stop playing audio through my speakers, and go to my headphone or earbuds, and work like it normally should, the problem is it does not KNOW that it is doing that. The computer still thinks that when it cuts the audio
    from the external speakers and starts playing only into the headphones, that it is STILL playing through the external speakers. Why is this an issue? Well, all my audio devices have built in microphones, but unlike the speakers, the compute will NOT switch
    over the microphone from the built-in webcam mic to the one plugged in into the audio jack, because it does not detect anything is plugged into the audio jack, despite playing audio through anything plugged into it.
    One thing I noticed is BEFORE this issue occurred, any time I plugged anything into the audio jack, Windows 10 would prompt me with a notice asking me what I plugged into the audio jack, and those options listed
    "Headphones with Mic" and "Skull-candy Headset" and stuff like that, and the audio BEFORE I select anything from the list would go to my headphones or earbuds, but only after selecting an option that had a microphone on it did the microphone
    get detected and viewable through the available devices on my PC. When I plug something into my PC's audio jack now, it does not ask me that anymore, but still will play audio totally fine through whatever is plugged into it.
    ALL of my drivers have been updated, uninstalled, reinstalled, disabled, enabled, and I have troubleshooted this by going into
    "Services" and stopping and restarting Windows Audio and Windows Audio Endpoint Builder, and restarting my computer after all of these and every combination of these methods, as well as checking to see that the PC's 3.5mm headphone jack is working
    properly with the correct drivers and that it is functioning properly, which it is. I cannot see any reason that this is a hardware issue, it appears to be something related to Windows that is not letting it detect anything is being plugged into the headphone
    jack.
    The PC uses Realtek High Definition Audio, and under "Playback devices", it is labelled as Speakers/Headphones. Under
    "Recording", Microphone - Realtek High Definition Audio is the default device, and all of these are turned on, under properties nothing is disabled, at all. Everything is set to function totally fine.
    What I would like as a solution is not for my microphone to work, I do not want ANY solutions that can fix my problem by explaining how to fix common audio problems for a PC when you plug something in and it does not work. Anything I plug in DOES work, but
    not the microphone, because it does NOT ask me what I plugged in, and I cannot select it is a headphone with a microphone, so it will not switch over from the webcam mic to the headphone mic, nor can I do that manually because when I plug something in it does
    not recognize I plug anything in at all despite properly functioning when I do to be able to do so.
    Any potential solutions at all would be greatly appreciated, and thank you so much for reading.
    Matt Montalvo, Jan 7, 2024
  1. Popup Not Appearing When Device is Plugged into Audio Jack, and No Audio Input Detected... - Similar Threads - Popup Appearing Device
    How to get a popup when device is plugged in audio jack?: when i inserted my itel earphone in my laptop acer, i got a popup and i didn't know what it was. I selected as speaker probably and my mic isn't working from earphone. how to make popup appear again? help.....
  3. How to get a popup when device is plugged in audio jack?
  4. How to get a popup when device is plugged in audio jack?
  5. How to get a popup when device is plugged in audio jack?
    How to get a popup when device is plugged in audio jack?: When I plug in a device to the audio jack, a box used to appear asking me what device is plugged in. Now that box does not pop up when I plug in a device. How would I get it to pop up again?also i tried use Realtek Audio Console but it doesnt do anything, here is the...
  6. How to get a popup when device is plugged in audio jack?
    How to get a popup when device is plugged in audio jack?: I was trying to connect my wired earplugs in but I accidentally clicked Don't show me this again to the usual pop up that comes. I was wondering how do I connect it now or how to get the pop-up back....
  7. How to get a popup when device is plugged in audio jack?
  8. Popup Not Appearing When Device is Plugged into Audio Jack, and No Audio Input Detected...
    Popup Not Appearing When Device is Plugged into Audio Jack, and No Audio Input Detected...: I am using the MI Notebook 14 with the device model XMA1901-DG. I have been using Sony MDR-EX255AP in-ear wired headphones, and usually, when I plug a device into the audio jack, a popup appears, allowing me to select whether it is a speaker or headphones. However, recently,...
  9. How to get a popup when device is plugged in audio jack?
    How to get a popup when device is plugged in audio jack?: How to get a popup when device is plugged in audio jack? https://answers.microsoft.com/en-us/windows/forum/all/how-to-get-a-popup-when-device-is-plugged-in-audio/ad966e6d-7ff4-4b91-9297-2f861a91c0db
  10. How to get a popup when device is plugged in audio jack?
