Windows 10: Potential solution to System freeze and audio problem
Discus and support Potential solution to System freeze and audio problem in Windows 10 Software and Apps to solve the problem; This is a potential solution that worked for me in regards to a problem discussed in this thread:... Discussion in 'Windows 10 Software and Apps' started by Orri321, Jan 7, 2023.
  1. Orri321 Win User
    This is a potential solution that worked for me in regards to a problem discussed in this thread: https://answers.microsoft.com/en-us/windows/forum/all/system-freeze-and-audio-problem/1d742809-a22f-492e-b121-e830388a724eI was not able to post my solution to that thread as it is locked so I wanted to create a new thread to help people in the futureThe problem is as follows: Regular computer usage, then there is a sudden freeze for a couple of seconds to a couple of minutes. After the freeze, Realtek High Definition Audio Manager pops up as if you've disconnected some of your audio devices.My so
  2. Audio Problems
    Hi there SimonWildZX, I will be your Independent Advisor for today, I hope we can both resolve your problem.
    May I suggest to completely uninstall all Audio drivers listed in the Device manager including the headset. Please make sure to completely remove.
    Here is how to do it.
    Here the steps to completely remove a Device off your computer.
    Step 1. Use shortcut keys Win + X on Windows 10.
    Step 2. Select Device Manager.
    Step 3. Expand the entry Sound and Audio devices. Right-click the problematic device and select Uninstall device.
    Step 4. You may need to check the option Delete the driver software for this device, and then click the Uninstall button.
    Step 5. Reboot the computer.
    Repeat the steps in all the Audio devices listed.
    Then reboot. then test the headset again.
    FerdinandNanalig, Jan 7, 2023
  3. dalchina Win User
    Windows 10 1709 System Restore problems...
    That seems to be an attempt at Option 2 in the tutorial, which requires you to
    a. Boot to a command prompt (Did you?)
    b. You then seem to be mixing steps 3,4 and 5, thus your command is incorrect.
    I suggest Option 1 is easier.
    If you still have problems, please repost listing each specific step and saying which option from the tutorial you are using. Thanks.
    dalchina, Jan 7, 2023
  4. Potential solution to System freeze and audio problem
    Audio Flipping sides problem
    Welcome to Microsoft Community and we appreciate your interest in Windows 10.
    Let help you to fix the issue.
    To understand the issue better, provide us more information.
    • Is the issue is specific to only export stream videos?
    • Try playing other videos/audio and let us know the status?
    I appreciate the steps you have performed. Let’s try simple steps and check if this helps. Follow the below steps provided.
    Step 1.
    I would suggest you to run sound audio troubleshooter, it will automatically detect the problem and fix it. Follow the below steps.
    • Press Windows key + R and click on
      Control Panel
    • Click on View by: category and click on
      Small icon.
    • Now click on troubleshooting and click on
      Hardware and Sound.
    • Click on Playing Audio and Click on
      Next
      button.
    • Click on Advanced on the Audio troubleshooter dialog box and click on Run as administrator (Enter the credentials if required).
    • Click on Next and follow onscreen instruction complete the Audio troubleshooter.
    If the issue still persist, try the below steps.
    Step 2.
    I suggest you to set the headset as default and check.
    • Right click on the on the sound icon on the Windows taskbar.
    • Click on Sounds and click on Playback
      tab.
    • Click on the headset and set it as default by clicking on the
      Set default button.
    • Now click Apply and OK.
    Hope this helps. Post us with the status we will be glad to help you.
    Billion Debbarma, Jan 7, 2023
  1. Potential solution to System freeze and audio problem - Similar Threads - Potential solution System
  2. Whatsapp Desktop app not starting potential solution
    Whatsapp Desktop app not starting potential solution: I had the problem referenced in this thread: https://answers.microsoft.com/en-us/windows/forum/all/whatsapp-not-starting/f956c2d2-043c-44eb-abab-70d966484e3f. After trying all the steps suggested by John, I gave up. While trying to solve another issue, I discovered that the...
  3. Whatsapp Desktop app not starting potential solution
    Potential solution to System freeze and audio problem: This is a potential solution that worked for me in regards to a problem discussed in this thread: https://answers.microsoft.com/en-us/windows/forum/all/system-freeze-and-audio-problem/1d742809-a22f-492e-b121-e830388a724eI was not able to post my solution to that thread as it...
  5. Potential solution to System freeze and audio problem
  6. Potentially haunted audio
    Potentially haunted audio: Quick rundown: Plugged in headset mic, mic didnt work. Messed around with settings a bit and checked every google search page on the topic on the entire internet, nothing. Eventually plugged in two headsets, one for output and one for input, it kinda works but mic audio is...
  7. Solution for system freezing?
    Solution for system freezing?: Hello to Everyone, I have a HP Envy M4 that came preinstalled with Windows 8.1, which I recently upgraded to Windows 10 H2. It has a 3rd gen i7, 8GB of DDR3 RAM, 1TB HDD with intel HD graphics 4000. Every half an hour, my system freezes and my fans ramp up. This happened just...
  8. System Freeze and Audio Problem
    System Freeze and Audio Problem: I have just purchased a new computer but as i installed programs, a problem was introduced. I think I had seen the same problem on my previous computer, but that is a long story! The effect is that the computer freezes for about 5 seconds and then continues. Associated with...
  9. SYSTEM FREEZE PROBLEM
    SYSTEM FREEZE PROBLEM: My system freezes often when charger is plugged so i have to restart by the power button.so please help me out with that. https://answers.microsoft.com/en-us/windows/forum/all/system-freeze-problem/6889990d-44f6-453f-a5e9-22f55e7a89c5
  10. SOLUTION FOR MY "SYSTEM VOLUME" PROBLEMS
    SOLUTION FOR MY "SYSTEM VOLUME" PROBLEMS: My computer system volume suddenly stopped functioning.. it does not produce ny sounds again.. even the usual system sounds and video players and audio players does not produce any sounds again.. i have tried setting it from "hardware and sounds" section in control panel but...
