Windows 10: Power and battery Problem.
Discus and support Power and battery Problem. in Windows 10 Gaming to solve the problem; I have a problem in my power and battery section of settings. Whenever I want to check battery usage of last 7 days then no result appears and the... Discussion in 'Windows 10 Gaming' started by Aarush Choubey, Oct 13, 2022.
  1. Power and battery Problem.
    I have a problem in my power and battery section of settings. Whenever I want to check battery usage of last 7 days then no result appears and the settings app gets automatically close. So what is the problem in settings app.
  2. Battery Won't Charge Fully
    Step 1
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    Step 3
    FreeBooter, Oct 13, 2022
  3. Plugged in but battery does not charge
    Step 1
    Step 2
    Step 3
  4. Power and battery Problem.
    Surface Pro 4 Battery issues
    If the laptop works without the battery than the charger is functioning correctly. Take a cloth with a bit of rubbing alcohol on it (or some on-the-go alcohol swabs), and clean the metal contacts that connect your battery to your laptop.
    Install the latest versions of your laptop device drivers you can download the latest device drivers from the device manufacturer or from your laptop manufacturer website.
    Step 1
    6. Under the Batteries category, right-click all the Microsoft ACPI Compliant Control Method Battery listings, and select Uninstall (it’s ok if you only have 1).
    If above suggestions won't resolve the battery charge issue then follow below steps.
    Step 2
    3. Start the laptop with only AC adapter connected to the laptop.
    4. When you log in to Windows OS connect the battery while Windows OS working.
    Step 3
    Hopefully one of the above suggestions will help you resolve the battery not charging problem. If the battery still doesn't charge, you may need to replace your battery.
  1. Power and battery Problem. - Similar Threads - Power battery Problem
  2. Power & battery problems
    Power & battery problems: In the Screen, sleep, & hibernate timeouts section, I can only adjust Turn my screen off after and Make my device sleep after and there is no Hibernate after section. And the funny thing is, it seems that the device still Hibernates after sleeping normally, why does the...
  3. Power & battery problems
    Power and battery Problem.: I have a problem in my power and battery section of settings. Whenever I want to check battery usage of last 7 days then no result appears and the settings app gets automatically close. So what is the problem in settings app....
  5. Battery & Power
    Battery & Power: Hello, So when my laptop battery is low and turns blank, and I charge it before it completely shuts down, the Screen will still remain blank but it's still on....the screen won't come back on even though it's charging...I will have to shut it down with the power button and...
  6. Battery power
    Battery power: I have a Samsung Book S, the battery only charges to 85% power. How can I increase this to 100% charge? https://answers.microsoft.com/en-us/windows/forum/all/battery-power/1edd3839-5467-45c6-967b-5f0a9586885d
  7. power and battery
    power and battery: windows get abruptely off when battery reaches below 70 to 75%. https://answers.microsoft.com/en-us/windows/forum/all/power-and-battery/221b44a1-01e3-4bd6-af2f-e0f9b0e89db3
  8. battery power
    battery power: how much percentage do I charge my laptop battery in windows 10 https://answers.microsoft.com/en-us/windows/forum/all/battery-power/f0cf560f-b076-466c-aa6d-6077921c4469
  9. Battery Power
    Battery Power: Battery power shows 100% but when I unplug, laptop turns off. Replaced battery twice, power cord still does it. Is there a charging malfuntion problem or is there a fixit available?...
  10. Power and battery
    Power and battery: I just had a black screen; all I could see was the mouse arrow. I researched on my other laptop and discovered it's a common problem with Win10. I tried a few recommended things but nothing happened: black screen and mouse. For some reason I got it into my head to remove the...
