Windows 10: power problem laptop won't turn on after sleep or shut down lights power light stays on
Discus and support power problem laptop won't turn on after sleep or shut down lights power light stays on in Windows 10 Performance & Maintenance to solve the problem; power lite and power button lite stay on after shutdown but windows doesn't shut down all the way. I have to press the reset button to get it going... Discussion in 'Windows 10 Performance & Maintenance' started by KellyZisk P.S Gabe Was, Feb 24, 2021.
power problem laptop won't turn on after sleep or shut down lights power light stays on - Similar Threads - power problem laptop
Power light
in Windows 10 Performance & MaintenancePower light: Power light flashing, indicating that my HP laptop is on sleep mode, but when I press some buttons to turn the screen on, it won't turn on and button will continue to flash. I don't know if there is a question out there that is similar or the same. Thanks.... -
Power light
in Windows 10 GamingPower light: Power light flashing, indicating that my HP laptop is on sleep mode, but when I press some buttons to turn the screen on, it won't turn on and button will continue to flash. I don't know if there is a question out there that is similar or the same. Thanks.... -
Power light
in Windows 10 Software and AppsPower light: Power light flashing, indicating that my HP laptop is on sleep mode, but when I press some buttons to turn the screen on, it won't turn on and button will continue to flash. I don't know if there is a question out there that is similar or the same. Thanks.... -
Laptop not turning on but the power light is on how to fix?
in Windows 10 Software and AppsLaptop not turning on but the power light is on how to fix?: My laptop is not turning on but the power light is on.how do you fix?pls help im charging it but its still not turning on.and its really hot.plss help... -
Fan and power lights remain turned on after shutting down PC
in Windows 10 Performance & MaintenanceFan and power lights remain turned on after shutting down PC: When I turn off my computer, the screen goes back as normal, but the lights remain turned on and the fan doesn't stop. If I hold down the power button for 5 seconds, it powers off, but I want to avoid doing so everytime. I've read a lot of similar questions, but none of... -
Power light stays ON after shut down from Windows upgrade solution
in Windows 10 Performance & MaintenancePower light stays ON after shut down from Windows upgrade solution: If you find the power light stays on after a Windows upgrade, these instructions will overcome it: Control Panel Device Manager scroll down to System Devices scroll down to and right click Intel(R) Management Engine Interface > Properties click tab Power Management... -
Mouse light is turn on after shut down :/
in Windows 10 CustomizationMouse light is turn on after shut down :/: Hello. Can you please help me to solve this problem. Mouse light is turn on after shut down. I have one solution. If I turn off FAST STARTUP,mouse light is turn off but then my pc turn on slower. Do you know another solution where I am not going to take damage on startup... -
Light stays on after shutting down.
in Windows 10 Drivers and HardwareLight stays on after shutting down.: Hello there, My GTX Gaming G1 1070 and Corsair H100i v2 Liquid Cooler LED's stay on faintly even after turning off the computer. The GTX 1070 still fades in and out of different colours and the Liquid Cooler contains its white but faint light coming from the Corsair Logo.... -
Power Light blinks before Shutting Down
in Windows 10 SupportPower Light blinks before Shutting Down: When I sign out of my user profile on my 2 Acer laptops and then click shut down, the computer goes black indicating that it is shutting down. However, the power light blinks until it shuts down completely. I don't know if it's a hardware issue or what but when hibernation is...
