Windows 10: Previous Versions does not work on system drive but second drive
Discus and support Previous Versions does not work on system drive but second drive in Windows 10 Performance & Maintenance to solve the problem; Hi There! I have two physical disks in my notebook, one simple partition each, BitLocker encrypted. Drive C:, which is my system drive and drive D:,... Discussion in 'Windows 10 Performance & Maintenance' started by ernst, Jan 7, 2016.
Previous Versions does not work on system drive but second drive - Similar Threads - Previous Versions does
Thumbnails Do Not Work On Second Hard Drive
in Windows 10 Network and SharingThumbnails Do Not Work On Second Hard Drive: I recently installed a new hard drive in my PC, however and images that are saved there do not have a thumbnail. I have already tried unchecking the "Always show icons, never thumbnails" which was already unchecked and clearing thumbnail cache. Is there any way to fix this?... -
in Windows 10 GamingThumbnails Do Not Work On Second Hard Drive: I recently installed a new hard drive in my PC, however and images that are saved there do not have a thumbnail. I have already tried unchecking the "Always show icons, never thumbnails" which was already unchecked and clearing thumbnail cache. Is there any way to fix this?... -
in Windows 10 Software and AppsThumbnails Do Not Work On Second Hard Drive: I recently installed a new hard drive in my PC, however and images that are saved there do not have a thumbnail. I have already tried unchecking the "Always show icons, never thumbnails" which was already unchecked and clearing thumbnail cache. Is there any way to fix this?... -
Drive Unexpectedly Not Working on System
in Windows 10 Network and SharingDrive Unexpectedly Not Working on System: So last night and all the days I've owned my PC before, nothing terrible has happened and I had not fiddled with anything in relation to my second D: drive. I woke up this morning, and when I went to open my file explorer, the drive and it's contents were inaccessible. I saw... -
Second hard drive contains system files?
in Windows 10 Network and SharingSecond hard drive contains system files?: I have two hard drives. The first is a 256GB SSD that holds my Windows installation. The second is a 2TB drive that just holds data. I was trying to create a system image of the windows drive so I can transition to a larger drive. When I try to create the system image, it... -
Bitlocker working on OS drive, not on second drive fixed data drive
in AntiVirus, Firewalls and System SecurityBitlocker working on OS drive, not on second drive fixed data drive: I am running W10 pro, 19041. I have had to do a fresh install of W10 and since then I cannot switch bitlocker on on the D: drive. The disk is not even shown on the Bitlocker Drive encryption settings page. The C: drive has bitlocker enabled and is encrypted. Have been... -
version 1903 just installed, Network drive does not work.
in Windows 10 Network and Sharingversion 1903 just installed, Network drive does not work.: version 1903 just installed, Network drive does not work. I deleted it and tried to map it again. no luck, get message Insufficient system resources exist to complete the requested service. Is there a fix for this??.... -
Indexing of a second drive
in Windows 10 SupportIndexing of a second drive: Hi There, I am having indexing problems in that only my C: drive gets indexed and my data drive D: gets ignored. This means that none of the data on D: is included and as this is where my Outlook files are stored, they too don't get included. I have tried rebuilding the... -
Restore Previous Versions of Files, Folders, and Drives in Windows 10
in Windows 10 TutorialsRestore Previous Versions of Files, Folders, and Drives in Windows 10: How to: Restore Previous Versions of Files, Folders, and Drives in Windows 10 How to Restore Previous Versions of Files, Folders, and Drives in Windows 10 [img] Information If you can't find a file on your computer or you accidently modified or deleted a file, you can...
