Windows 10: Problem with Bluetooth card not working, wlan card not working, LAN card not working...
Discus and support Problem with Bluetooth card not working, wlan card not working, LAN card not working... in Windows 10 Software and Apps to solve the problem; Hello, I'll start by saying that I solved the problem by browsing dozens of pages about this problem. I was wondering how it happened that I was left... Discussion in 'Windows 10 Software and Apps' started by Mateusz Kania, Jan 18, 2025.
  1. Problem with Bluetooth card not working, wlan card not working, LAN card not working...
    Hello, I'll start by saying that I solved the problem by browsing dozens of pages about this problem. I was wondering how it happened that I was left with a laptop without the possibility of turning on wifi and connecting the internet via an Rj45 cable - no option for communicating with the internet worked, even the Bluetooth module broke down. My router with fiber optic internet is functional and every device in the house uses it, even smart devices like light bulbs. The problem only affected the Laptop with Windows 11. I managed to save it using a PC - which I used to record drivers for inte
  2. werty Win User
    Wlan card upgrade on laptop
    Hi guys, I wanna upgrade the Wlan card on my Inspiron 1545. I know the right size but some of the cards come with Bluetooth and my laptop already has a separate Bluetooth module. Will this be a problem or I have to buy a wlan card without bluetooth integrated. If you already have upgraded can you post which card exactly.
    Thanks!
    werty, Jan 18, 2025
  3. bradleyb Win User
    SD card/SD card reader no longer working
    Hi. New to this so not sure of category.
    I have a Lenovo G70. Windows 10, 64bit
    My SD card reader has stopped working.
    In Device Manager, the SD card is not listed.
    I can't format the card as it is not listed.
    I cannot locate the card at all as it is not listed anywhere.
    I've tried chkdsk and get 'Cannot open volume for direct access'
    I don't even have the icon displaying when micro SD card is inserted.
    It did work previously but I had errors. Scanning and fixing did not help.
    I place the SD card in my Android phone and it works fine.
    Please help!
    Thank you for any assistance.
    bradleyb, Jan 18, 2025
  4. Berton Win User
    Bradleyb, in your Device Manager do you have anything listed in Storage Controllers? I get an entry for MMC/SD. I just checked a 1GB SD card and a 4GB SDHC card, both worked in File Explorer to show their contents.
    Problem with  Bluetooth card not working, wlan card not working, LAN card not working... 271947d1585232223t-sd-card-sd-card-reader-no-longer-working-image.png
    Side note: A caveat for such cards is that if they are to be used in a camera they need to be formatted in the camera, not in Windows.
    Berton, Jan 18, 2025
  1. Problem with Bluetooth card not working, wlan card not working, LAN card not working... - Similar Threads - Problem Bluetooth card
  2. Problem with Bluetooth card not working, wlan card not working, LAN card not working...
    Problem with Bluetooth card not working, wlan card not working, LAN card not working...: Hello, I'll start by saying that I solved the problem by browsing dozens of pages about this problem. I was wondering how it happened that I was left with a laptop without the possibility of turning on wifi and connecting the internet via an Rj45 cable - no option for...
  3. WiFi LAN Card not working
    WiFi LAN Card not working: Hello. I have a problem. My computer has an internet problem and I can't fix it. It says that the MediaTek Wi-Fi 6 MT7921 Wireless LAN Card. It says that I should connect the laptop with an ethernet cable, but my laptop doesn't have the thing to insert the cable into....
  4. WiFi LAN Card not working
  5. WiFi LAN Card not working
  6. Graphics Card Not Working
    Graphics Card Not Working: I recently, accidentally broke my SSD. I got my Win 10 working on the new SSD. But, I can't seem to figure out how to get the video card to work. Its a GeForce GTX 1060. When I remove the graphics card and run HDMI out from the motherboard, it works fine. But, when I install...
  7. Wifi + Bluetooth card Bluetooth not working
    Wifi + Bluetooth card Bluetooth not working: I recently bought a Bluetooth + Wi-Fi PCIE card for my custom build gaming pc to be able to use my crusher evos on, and the Wi-Fi feature works fine, however i haven't been able to get the Bluetooth working. I have already reinstalled the latest drivers and went into...
  8. Wifi + Bluetooth card Bluetooth not working
  9. Wifi + Bluetooth card Bluetooth not working
  10. LAN card is not working
    LAN card is not working: Hello, My internal NIC Card has suddenly stopped and not working anymore. I can see the below error in the event: \VEN_10EC&DEV_8168&SUBSYS_84A7103C&REV_15\4&2eb771be&0&00E4 had a problem starting. Driver Provider: Realtek Driver Date: 11/18/2019 Driver Version:...
