Windows 10: Problem with RealtekR Audio, after restart and every so often sound stops working
Discus and support Problem with RealtekR Audio, after restart and every so often sound stops working in Windows 10 Software and Apps to solve the problem; My speakers, that work on RealtekR Audio, stop working every so often and after every restart/shutdown and startup. I can temp fix this by uninstalling... Discussion in 'Windows 10 Software and Apps' started by Skectrix2, Dec 2, 2022.
Problem with RealtekR Audio, after restart and every so often sound stops working - Similar Threads - Problem RealtekR Audio
Pc Restarting Randomly every so often
in Windows 10 GamingPc Restarting Randomly every so often: Recently randomly my pc will just quickly reboot then run like normal I have no clue why Processor AMD Ryzen 7 5800X 8-Core Processor 3.80 GHz Installed RAM 32.0 GB Device ID 2E4E7257-6647-44DA-BDC3-27CE182F2433 Product ID 00331-10000-00001-AA791 System type 64-bit operating... -
in Windows 10 Software and AppsPc Restarting Randomly every so often: Recently randomly my pc will just quickly reboot then run like normal I have no clue why Processor AMD Ryzen 7 5800X 8-Core Processor 3.80 GHz Installed RAM 32.0 GB Device ID 2E4E7257-6647-44DA-BDC3-27CE182F2433 Product ID 00331-10000-00001-AA791 System type 64-bit operating... -
Speaker RealtekR Audio works for a few seconds when starting up, then sound stops and...
in Windows 10 Software and AppsSpeaker RealtekR Audio works for a few seconds when starting up, then sound stops and...: So for the past few days now my Omen 15 laptop Windows 10 has been having a problem mainly with sound. For the first few seconds of starting my laptop the sound is fine, I'll go play a video on Youtube and it will work. However, if I rewind the Youtube video then the video... -
[Solved] Problem with RealtekR Audio, after restart and every so often sound stops working
in Windows 10 Gaming[Solved] Problem with RealtekR Audio, after restart and every so often sound stops working: My speakers, that work on RealtekR Audio, stop working every so often and after every restart/shutdown and startup. I can temp fix this by uninstalling the driver and removing the device from Device Manager and then scanning for hardware changes. When I do that the speakers... -
in Windows 10 Software and Apps[Solved] Problem with RealtekR Audio, after restart and every so often sound stops working: My speakers, that work on RealtekR Audio, stop working every so often and after every restart/shutdown and startup. I can temp fix this by uninstalling the driver and removing the device from Device Manager and then scanning for hardware changes. When I do that the speakers... -
in Windows 10 Drivers and Hardware[Solved] Problem with RealtekR Audio, after restart and every so often sound stops working: My speakers, that work on RealtekR Audio, stop working every so often and after every restart/shutdown and startup. I can temp fix this by uninstalling the driver and removing the device from Device Manager and then scanning for hardware changes. When I do that the speakers... -
in Windows 10 GamingProblem with RealtekR Audio, after restart and every so often sound stops working: My speakers, that work on RealtekR Audio, stop working every so often and after every restart/shutdown and startup. I can temp fix this by uninstalling the driver and removing the device from Device Manager and then scanning for hardware changes. When I do that the speakers... -
in Windows 10 Drivers and HardwareProblem with RealtekR Audio, after restart and every so often sound stops working: My speakers, that work on RealtekR Audio, stop working every so often and after every restart/shutdown and startup. I can temp fix this by uninstalling the driver and removing the device from Device Manager and then scanning for hardware changes. When I do that the speakers... -
Explorer.exe (supposedly) restarts every so often
in Windows 10 Ask InsiderExplorer.exe (supposedly) restarts every so often: [ATTACH] So for the past couple months I've been having this issue where my all my windows, browsers, and desktop refresh and reboots. I know it has something to do with the GPU or graphics but I'm not sure what is up. I've reinstalled my graphics drivers but that hasn't...
