Windows 10: Realtek Sound Problems in Build 10158, 10159 & 10162
Discus and support Realtek Sound Problems in Build 10158, 10159 & 10162 in Windows 10 Drivers and Hardware to solve the problem; As long as it is set in stereo its fine but try to put it in 5.1 or 7.1 it kills the sound. I then have to uninstall the drivers and reload the windows... Discussion in 'Windows 10 Drivers and Hardware' started by acer54, Jul 4, 2015.
Realtek Sound Problems in Build 10158, 10159 & 10162 - Similar Threads - Realtek Sound Problems
No luck at all trying to get Build 10158/10159 to Show.
in Windows 10 Updates and ActivationNo luck at all trying to get Build 10158/10159 to Show.: i've tried the Slow to fast ring (wait 2 mins restart) method i left it on fast ring for 30 misn still nothing, verified in the registry i'm on the Fast Ring, when i open the Insider Hub shows the latest available is 10130, made sure i verified the PC nada. i know my... -
Builds 10158 & 10159 can't access many network shares
in Windows 10 Network and SharingBuilds 10158 & 10159 can't access many network shares: I have a number of network shares that Win 10 no longer has permission to access. This only occurred in builds 10158 & 10159. The weird thing is that all the shares that can't be accessed are on a single machine, however, there are shares on that same machine that can still... -
Upgrade from 10158 to 10159
in Windows 10 Installation and UpgradeUpgrade from 10158 to 10159: Upgraded my VM and Laptop from 10158 to 10159. Both went perfectly, no problems. Took about an hour each. The VM I did via Windows Update. Then I used ESDtoISO to make the iso and copied it to my laptop. Mounted the iso (right click, Mount) then ran setup.exe from the... -
build 10162
in Windows 10 Installation and Upgradebuild 10162: Where can I get this build from? I am on the fast ring; and i checked wu; but the update is not there for some reason. So where can i get it from(where its a official release?) 7802 -
Upgrade from 10159 to 10162 - no flash or DVD used
in Windows 10 Installation and UpgradeUpgrade from 10159 to 10162 - no flash or DVD used: Upgraded my VM and Laptop from 10159 to 10162. Both went perfectly, no problems. Took about an hour each. The VM I did via Windows Update. Then as before, I used ESDtoISO to make the iso and copied it to my laptop. Mounted the iso (right click, Mount) then ran setup.exe... -
build 10158?
in Windows 10 Installation and Upgradebuild 10158?: I just read in another thread that there is a build 10158? Is this a official build or just a leaked build? 7563 -
build 10159
in Windows 10 Installation and Upgradebuild 10159: trying to update from 10130 to 10159 but for some reason it will not update. Any ideas? 7664 -
build 10159
in Windows 10 Installation and Upgradebuild 10159: build 10159 not activating from microsoft upgrade or iso any ideas 7641 -
Updating to 10158 or 10159 from 10130 fails
in Windows 10 Installation and UpgradeUpdating to 10158 or 10159 from 10130 fails: For whatever reason I can't upgrade to the latest version from 10130 whether it be through windows updates or directly from the ISO. This is the error I get after windows restarts: https://i.imgur.com/mskzk5w.jpg I've tried about 8 times now and nothing works. Help!!!...
