Windows 10: Right click problem I have problem with right click anywhere on windows 10. It opens right...
Discus and support Right click problem I have problem with right click anywhere on windows 10. It opens right... in Windows 10 Customization to solve the problem; Right click problem I have problem with right click anywhere on windows 10. It opens right click menu & it also open mail why?? I am using wireless... Discussion in 'Windows 10 Customization' started by sreerajrv, Oct 2, 2020.
Right click problem I have problem with right click anywhere on windows 10. It opens right... - Similar Threads - Right click problem
Problem with right click
in Windows 10 Software and AppsProblem with right click: When i press the right click a sound is heard and it starts to drag items selected instead of showing right-click menu and if no items is selected a rectangle is created and select items inside, note that i use the latest update of windows And my laptop model is dell g5 15. i... -
Right-click problem
in Windows 10 GamingRight-click problem: HiWhen I right click on a folder, it loads for a momentIt is clear in the picture belowTnk https://answers.microsoft.com/en-us/windows/forum/all/right-click-problem/9c17b7ba-a510-4a6a-ab81-559f12d021f9 -
Right-click problem
in Windows 10 Software and AppsRight-click problem: HiWhen I right click on a folder, it loads for a momentIt is clear in the picture belowTnk https://answers.microsoft.com/en-us/windows/forum/all/right-click-problem/9c17b7ba-a510-4a6a-ab81-559f12d021f9 -
Right-click Open with problem
in Windows 10 GamingRight-click Open with problem: In the last few days, the right-click Open with... function has stopped working for a specific program - MS Paint. All other choices work fine, MS Paint works fine, when I drag the image onto an already open instance of MS Paint it opens fine, but that single possibility of... -
in Windows 10 Software and AppsRight-click Open with problem: In the last few days, the right-click Open with... function has stopped working for a specific program - MS Paint. All other choices work fine, MS Paint works fine, when I drag the image onto an already open instance of MS Paint it opens fine, but that single possibility of... -
in Windows 10 CustomizationRight-click Open with problem: In the last few days, the right-click Open with... function has stopped working for a specific program - MS Paint. All other choices work fine, MS Paint works fine, when I drag the image onto an already open instance of MS Paint it opens fine, but that single possibility of... -
Right click problem
in Windows 10 Ask InsiderRight click problem: I recently reset my laptop, everything is running fine but the right click menu is taking too much time to open almost 2-5 mins, and its annoying. There is not any extra thing in that menu.. All other features like opening folders, internet etc. works smoothly List of items... -
Right click problems
in Windows 10 Ask InsiderRight click problems: so when I hold right click it cuts out so im aiming in while play call of duty and when I zoom in and looking around it works for a short period of time but it will cut out for a second so I will unzoom for 1 or 2 seconds and I will continue holding right click and it will... -
right click problem
in Windows 10 Network and Sharingright click problem: has anyone experienced a problem when right clicking on a file and windows becomes unresponsive and closes the file /program down if so have you fixed the problem or how did you resolve it...
