Windows 10: Samsung Odyssey OLED G9 (G95SC) — No Display, Flashing Power Red LED, Rear RGB Sometimes...
Discus and support Samsung Odyssey OLED G9 (G95SC) — No Display, Flashing Power Red LED, Rear RGB Sometimes... in Windows 10 Graphic Cards to solve the problem; Whenever I plug in my Samsung Odyssey OLED G9 (model G95SC), the red power LED starts flashing every few seconds. If I try to turn it on (either with... Discussion in 'Windows 10 Graphic Cards' started by iKokomo, Jul 7, 2025.
Samsung Odyssey OLED G9 (G95SC) — No Display, Flashing Power Red LED, Rear RGB Sometimes... - Similar Threads - Samsung Odyssey OLED
No display, RGB on
in Windows 10 Software and AppsNo display, RGB on: Every time I turned on my computer there is "no display" and keyboard's and mouse's lights aren't on though it usually is still on even after my computer is shutted off even though headphones' lights and RGB are on, and the fans are moving? What do I do to fix it?... -
No display, RGB on
in Windows 10 BSOD Crashes and DebuggingNo display, RGB on: Every time I turned on my computer there is "no display" and keyboard's and mouse's lights aren't on though it usually is still on even after my computer is shutted off even though headphones' lights and RGB are on, and the fans are moving? What do I do to fix it?... -
No display, RGB on
in Windows 10 GamingNo display, RGB on: Every time I turned on my computer there is "no display" and keyboard's and mouse's lights aren't on though it usually is still on even after my computer is shutted off even though headphones' lights and RGB are on, and the fans are moving? What do I do to fix it?... -
Issues with Easy Setting Box ESB on Samsung Odyssey G9
in Windows 10 GamingIssues with Easy Setting Box ESB on Samsung Odyssey G9: Hey Community,I'm experiencing a bit of a hiccup with my Easy Setting Box ESB on my Samsung Odyssey G9 monitor. Maybe some of you have had similar experiences and can lend me a hand.Everything runs smoothly when I initially start ESB. I can tweak all the settings, and it... -
in Windows 10 Software and AppsIssues with Easy Setting Box ESB on Samsung Odyssey G9: Hey Community,I'm experiencing a bit of a hiccup with my Easy Setting Box ESB on my Samsung Odyssey G9 monitor. Maybe some of you have had similar experiences and can lend me a hand.Everything runs smoothly when I initially start ESB. I can tweak all the settings, and it... -
Whole interface is zoomed in upon startup with Odyssey G9.
in Windows 10 GamingWhole interface is zoomed in upon startup with Odyssey G9.: Recently purchased an Odyssey G9 monitor. Every time I start/boot it up it immediately zooms in, making the computer almost inoperable. Manually changing the resolution temporarily fixes it but again, every time I turn it on it defaults to zooming back in. I’m using an NVIDIA... -
in Windows 10 Software and AppsWhole interface is zoomed in upon startup with Odyssey G9.: Recently purchased an Odyssey G9 monitor. Every time I start/boot it up it immediately zooms in, making the computer almost inoperable. Manually changing the resolution temporarily fixes it but again, every time I turn it on it defaults to zooming back in. I’m using an NVIDIA... -
Samsung Odyssey G9 and G7 Gaming Monitors are Now Available
in Windows 10 NewsSamsung Odyssey G9 and G7 Gaming Monitors are Now Available: [img] 2020 Odyssey Gaming Monitor – G9 Samsung, the global leader in gaming monitors², pushes the boundaries of display technology to deliver a radically different gaming experience. Unveiled this year at CES, Odyssey gaming monitors combine the deepest, most... -
Windows Explorer not loading properly and flashing red H.D.D LED.
in Windows 10 SupportWindows Explorer not loading properly and flashing red H.D.D LED.: So around about 4 months ago my BIOS corrupted somehow and I didn't know how to fix my BIOS. I tore apart my computer and boxed it up since I thought it was a motherboard issue and it couldn't be fixed. Around about a week ago I found out that I need to reset the CMOS battery...
