Windows 10: Simple Dynamic Volume Displayed as Two With Same Letter After Extend
Discus and support Simple Dynamic Volume Displayed as Two With Same Letter After Extend in Windows 10 Drivers and Hardware to solve the problem; [img] Is there any way to merge the two "K" volumes / partitions into one? Disk 0 originally looked like Disk 1 (they're broken mirrors actually,... Discussion in 'Windows 10 Drivers and Hardware' started by teebone, May 12, 2018.
Simple Dynamic Volume Displayed as Two With Same Letter After Extend - Similar Threads - Simple Dynamic Volume
Primary Disk Partition Can't extend without making it a Simple Volume
in Windows 10 Software and AppsPrimary Disk Partition Can't extend without making it a Simple Volume: I have made a question before on how to change the Simple Volume back into a Primary Partition and they said I had to format which I did and it is now a Primary Partition but I want to remove that empty space and join it with the 1.6 TB partition but when I do so I get this... -
Problems extending displays to two monitors
in Windows 10 Software and AppsProblems extending displays to two monitors: Hi all,I have a desktop PC that is running Windows 10. I am trying to extend the displays so that my desktop can be shared between my normal monitor and an HDTV. I have ensured that I have the correct cabling, and until about a week ago the displays were extending as... -
in Windows 10 Drivers and HardwareProblems extending displays to two monitors: Hi all,I have a desktop PC that is running Windows 10. I am trying to extend the displays so that my desktop can be shared between my normal monitor and an HDTV. I have ensured that I have the correct cabling, and until about a week ago the displays were extending as... -
in Windows 10 GamingProblems extending displays to two monitors: Hi all,I have a desktop PC that is running Windows 10. I am trying to extend the displays so that my desktop can be shared between my normal monitor and an HDTV. I have ensured that I have the correct cabling, and until about a week ago the displays were extending as... -
Extend and Mirror Displays at the Same Time?
in Windows 10 Ask InsiderExtend and Mirror Displays at the Same Time?: Is it possible in Windows 10 to extend and mirror displays at the same time. Here's what I'm trying to accomplish: mirror laptop screen to external display 1 extend laptop screen to external display 2 Is this possible or am I stuck either mirroring or extending but not... -
How to extend Disk Volume without converting it to Dynamic Disk?
in Windows 10 Ask InsiderHow to extend Disk Volume without converting it to Dynamic Disk?: So my D drive(Storage Drive, OS is installed on C) has 100 GB of unallocated space which I would like to merge with my main partition that has 831 GB. But when I try to do so using the wizard, it tells me that it will convert it into Dynamic Disk. I really don't want to... -
Dynamic Volumes - Unable to add/extend my main disk
in Windows 10 Drivers and HardwareDynamic Volumes - Unable to add/extend my main disk: The main disk where I have my boot and system partition is running out of space. I have an extra disk not used in my computer. In the past, I was able (during installation) to use two disks with stripped partitions (RAID-0-like), now however, I cannot. What I have done... -
Can't create simple volume on dynamic disk
in Windows 10 Network and SharingCan't create simple volume on dynamic disk: Hello I have a dynamic disk (converted from a basic disk) with about 100gb of allocated space. I try to create a simple volume out of the entirety of it (via disk management) but immediately after press "finish" on the New Simple Volume Wizard, an error message shows saying... -
After extend, changed to dynamic and not showing in diskdefrag
in Windows 10 SupportAfter extend, changed to dynamic and not showing in diskdefrag: Hello tenforums, recently I have decided to buy ssd for my laptop. I ended up installing fresh new copy of Windows after failed to 'clone' or 'migrate' it. On a first attempt, when I looking around, i can see my hdd partition on disk defragmenter. For illustration, here is...
