Windows 10: So i am having issues with my Boat Airdopes 141's mic while using bluetooth connection.
Discus and support So i am having issues with my Boat Airdopes 141's mic while using bluetooth connection. in Windows 10 Gaming to solve the problem; In bluetooth control panel, under the Boat 141, it says Connected Music, I am getting sound output from the earphone but the mic doesn't seem to be... Discussion in 'Windows 10 Gaming' started by Karthikeyan 077, Dec 9, 2023.
So i am having issues with my Boat Airdopes 141's mic while using bluetooth connection. - Similar Threads - having issues Boat
My Bluetooth device "boat rockerz 255 pro plus" mic is not working when i am connecting it...
in Windows 10 Software and AppsMy Bluetooth device "boat rockerz 255 pro plus" mic is not working when i am connecting it...: But it works with other devices like my mobile. Besides it there is also an option of mic input of 'camo' but its mic is also not working. I shared the image of the mic setting of that Bluetooth device which shows that the mic is not available for the particular device.Please... -
in Windows 10 GamingMy Bluetooth device "boat rockerz 255 pro plus" mic is not working when i am connecting it...: But it works with other devices like my mobile. Besides it there is also an option of mic input of 'camo' but its mic is also not working. I shared the image of the mic setting of that Bluetooth device which shows that the mic is not available for the particular device.Please... -
in Windows 10 Software and AppsSo i am having issues with my Boat Airdopes 141's mic while using bluetooth connection.: In bluetooth control panel, under the Boat 141, it says Connected Music, I am getting sound output from the earphone but the mic doesn't seem to be working.Is there a fix for this problem? For connecting bluetooth I am using a TP Link bluetooth adapter and its drivers are... -
in Windows 10 Drivers and HardwareSo i am having issues with my Boat Airdopes 141's mic while using bluetooth connection.: In bluetooth control panel, under the Boat 141, it says Connected Music, I am getting sound output from the earphone but the mic doesn't seem to be working.Is there a fix for this problem? For connecting bluetooth I am using a TP Link bluetooth adapter and its drivers are... -
Bluetooth problem on Windows 10 boat airdopes 138
in Windows 10 GamingBluetooth problem on Windows 10 boat airdopes 138: HiI am having issues with my bluetooth in Windows 10 . There are lags between the audio every 5-7 seconds although the bluetooth device boat airdopes 138 is working perfect with other devices . I have tried every fix - running troubleshooter , disabling handsfree telephony ,... -
in Windows 10 Software and AppsBluetooth problem on Windows 10 boat airdopes 138: HiI am having issues with my bluetooth in Windows 10 . There are lags between the audio every 5-7 seconds although the bluetooth device boat airdopes 138 is working perfect with other devices . I have tried every fix - running troubleshooter , disabling handsfree telephony ,... -
in Windows 10 Drivers and HardwareBluetooth problem on Windows 10 boat airdopes 138: HiI am having issues with my bluetooth in Windows 10 . There are lags between the audio every 5-7 seconds although the bluetooth device boat airdopes 138 is working perfect with other devices . I have tried every fix - running troubleshooter , disabling handsfree telephony ,... -
unable to connect boat airdopes 451 Bluetooth to windows 10
in Windows 10 Drivers and Hardwareunable to connect boat airdopes 451 Bluetooth to windows 10: Hi,I was using Boat Airdopes 451 with my windows 10 operated laptop smoothly. but post some updates of windows I am no more able to connect them to my laptop. windows now, can not even search them under the Bluetooth device search option.please suggest some way around.... -
Distorted/Cracking Audio on Bluetooth device-Boat Airdopes 138
in Windows 10 Drivers and HardwareDistorted/Cracking Audio on Bluetooth device-Boat Airdopes 138: System DescriptionBrand : DellProcessor : IntelR CoreTM i5-5200U CPU @ 2.20GHzEdition : Windows 10 Home Single LanguageVersion : 21H1Installed On : 21-05-2021Bluetooth Device : Boat Airdopes 138 Problem StatementDistorted/Cracking audio when song is played through this device...
