Windows 10: Some help with power management?
Discus and support Some help with power management? in Windows 10 Performance & Maintenance to solve the problem; Any reason why i don't got this option under power management Processor performance core parking min cores? I only got: Maximum processor frequency,... Discussion in 'Windows 10 Performance & Maintenance' started by OxtailSnail, Sep 28, 2017.
Some help with power management? - Similar Threads - help power management
Help regarding processor power management in windows.
in Windows 10 GamingHelp regarding processor power management in windows.: Yesterday, I installed ThrottleStop and changed power plan in it to high performance. The processor started running around 4.3 ghz. Then I set it to balanced the processor came back to between 1 to 2.2 ghz. The problem was that now it won't go beyond 2.28 ghz even it is turbo... -
in Windows 10 Software and AppsHelp regarding processor power management in windows.: Yesterday, I installed ThrottleStop and changed power plan in it to high performance. The processor started running around 4.3 ghz. Then I set it to balanced the processor came back to between 1 to 2.2 ghz. The problem was that now it won't go beyond 2.28 ghz even it is turbo... -
in Windows 10 BSOD Crashes and DebuggingHelp regarding processor power management in windows.: Yesterday, I installed ThrottleStop and changed power plan in it to high performance. The processor started running around 4.3 ghz. Then I set it to balanced the processor came back to between 1 to 2.2 ghz. The problem was that now it won't go beyond 2.28 ghz even it is turbo... -
Power Management
in Windows 10 SupportPower Management: My power management is set to sleep/turn off display after 30 minutes of inactivity, whilst plugged in. When I watch catch up TV e.g. QuestTV on dplay.co.uk the laptop goes to sleep (black screen) after 30 minutes, whilst the programme is still running. I do not consider... -
Help: "Some settings are managed by your organization"
in Windows 10 Ask InsiderHelp: "Some settings are managed by your organization": Out of nowhere, this popped up on my updates screen and won't let me update. I noticed some strange things since updating to 2004, maybe it's a coincidence, but here is what has happened thus far: 1) Microsoft Teams magically installed on my computer and decided to boot up... -
Power Management
in Windows 10 Performance & MaintenancePower Management: I have migrated from a company-managed PC to my own now HP Omen - is it possible to close the lid without shutting down the machine? I'd like to continue to use it with wireless keyboard, mouse, and external screen. Is it even a good idea to do this?... -
Power management
in Windows 10 BSOD Crashes and DebuggingPower management: There is a power regulator which has three modes. It disappeared and now I can't find any other way to fix it. How can I restore the power management to get back the power regulator... -
Windows Power Manager or Manufacturer Power Manager ?
in Windows 10 Performance & MaintenanceWindows Power Manager or Manufacturer Power Manager ?: I got to realize windows implemented its own battery power manager , it is set on "Best Performance" while I already have a manufacturer battery power manager that is installed but two years old (Early 2016) that reports being up to date set on "Balance Mode" , now i am... -
Power management?
in Windows 10 SupportPower management?: When I change the power management to never turn the screen off on my desktop the setting is back to 15 minutes when the Pc is restarted. On my laptop I don't have this problem and I can't find a setting in the BIOS which can be the cause? I use build 10586.11 64 bit....
