Windows 10: Sound Problems / Headphones and other audio devices not working
Discus and support Sound Problems / Headphones and other audio devices not working in Windows 10 Software and Apps to solve the problem; Hi thereI've had my PC for around 3-4 years and it has worked completely fine in that time. Only recently, for the past 4 months or so I've only been... Discussion in 'Windows 10 Software and Apps' started by ZanderRibbens, Jun 1, 2022.
  1. Sound Problems / Headphones and other audio devices not working
    Hi thereI've had my PC for around 3-4 years and it has worked completely fine in that time. Only recently, for the past 4 months or so I've only been able to use sound through my monitor as trying to plug in headphones or earphones into both my front USB audio and mic jack and the back audio jack do nothing. Checking device manager, no headphone or earphone audio devices pop up or are even recognised. In device manager, under 'audio inputs and outputs' there is my monitor and it's 'high definition audio device' and under 'sound, video and game controllers' there is only 'high definition audio
  2. Audio issues with only the left side of headphones/earphones work.
    Hi Charlie,
    The port of the device could be the culprit why only the left side of your headphones works. A hardware or software changes could also be the reason for this kind of issue. However, let's not assume anything yet until we isolated your concern. We suggest
    that you run the Hardware and Devices troubleshooter in Windows Settings. Simply search for
    Troubleshoot in the start menu. Under Find and fix other problems, click on
    Hardware and Devices. We also suggest that you run the audio test for your headphones in Hardware and Sound. Here are the steps on how to do so:
    • Go to Control Panel, then click on Hardware and Sound.
    • Under Sound, click on Manage audio devices.
    • Click on Headphones, then Configure at the bottom right.
    • Run the test, and see if both sides of your headphones are working there.
    If you think this was useful, feel free to "mark it as an answer" to help those who are facing the same problem.
    Carlos Tin, Jun 1, 2022
  3. no sound in headphones
    Hi Mary,
    If your headphones stops working in Windows devices, you can try solutions below to fix the problem. The issue can be caused by incorrect sound settings, faulty audio drivers, etc. We suggest that you follow below simple instructions to troubleshoot the
    problem.
    • Check if the sound is muted. If it is muted, the headphone won’t have sound.
    • Check the connection. Try unplugging the headphone and firmly plug it back in.
    • Check the port. If you are using a USB headphone, try a different USB port.
    • Try the headphone on another computer. Use your headphone on another computer. If it doesn’t work on that computer, the headphone might be broken. In that case, you need to replace it with a new one.
    We're just here if you have further questions.
    Regards.
    81a3255d-566c-4bba-9244-0173490ea2c5, Jun 1, 2022
  4. Sound Problems / Headphones and other audio devices not working
    No Sound Through Headphones
    Hello! I've already read through many of the similar questions on this forum, however none of the solutions seem to work.
    Sound comes through perfectly fine on my laptop's built-in speakers. However, when plugging my headphones into the 3.5mm headset jack, there is no sound whatsoever. The system recognizes that my headset is plugged in. In fact, the microphone on my headset functions perfectly when plugged in, but the headphones themselves are outputting no sound.
    I tested the headphones on other computers and devices, and they work.
    In Device Manager, the device is listed as "Realtek High Definition Audio". However, the only sound device listed in Control Panel is "DTS Audio Control Panel".
    I've tried uninstalling the audio device from Device Manager, and then reinstalling the driver from Realtek's website.
    However, this is met with the exact same results... no sound through the headphones, and "DTS Audio Manager" is installed in the Control Panel instead of Realtek HD Audio Manager.
    If I navigate to Control Panel -> Sound -> Playback, "Headphones" is not listed as a device. Instead, Speakers/Headphones is listen as the sole device.
    Also, I ran DirectX Diagnostic Tool, and it returned absolutely no errors.
    I have posted screenshots and a few of my system specifications just in case.
    Thank You!
    Model: HP ZBook 17 G2
    OS: Windows 10 Pro 64-bit
    Sound Problems / Headphones and other audio devices not working [​IMG]
    DrummerZack, Jun 1, 2022
  1. Sound Problems / Headphones and other audio devices not working - Similar Threads - Sound Problems Headphones
  2. bluetooth headphone connected as "other devices" and not sound
    bluetooth headphone connected as "other devices" and not sound: When I try and connect my Bluedio headphones to my Windows 10 pc through a generic USB bluetooth connector everything goes as planned and the headphones connect and pair initially as an audio device and then jumps to "other device"...of course I am getting no sound.This...
  3. bluetooth headphone connected as "other devices" and not sound
  4. bluetooth headphone connected as "other devices" and not sound
  5. Sound Problems / Headphones and other audio devices not working
    Sound Problems / Headphones and other audio devices not working: Hi thereI've had my PC for around 3-4 years and it has worked completely fine in that time. Only recently, for the past 4 months or so I've only been able to use sound through my monitor as trying to plug in headphones or earphones into both my front USB audio and mic jack...
  6. Sound Problems / Headphones and other audio devices not working
  7. Headphones shown in "Other Devices" but not in Audio
    Headphones shown in "Other Devices" but not in Audio: I have used my headphones on this computer for a year plus but now it stopped working. I have updated all of my drivers I have updated my computer & Windows 10 I have uninstalled and reinstalled the Headphones to Bluetooth Whenever I connect the headphones, the PC says...
  8. Sound Problem Headphone is not working
    Sound Problem Headphone is not working: About my windows version: Windows 10 Home Version 2004 OS build 19041.388 Laptop: DELL Inspiron 15-3580 Core i7 Problem: I am facing some issues about sound in my Laptop. When I connect headphone/earphone sound does not pass through it rather the sound keeps...
  9. Bluetooth headphones connected as other devices not audio.
    Bluetooth headphones connected as other devices not audio.: When I try and connect my Bluedio headphones to my Windows 10 pc through a generic USB bluetooth connector everything goes as planned and the headphones connect and pair initially as an audio device and then jumps to "other device"...of course I am getting no sound. Device...
  10. Audio sound not working on speakers/or headphones. No sound
    Audio sound not working on speakers/or headphones. No sound: Yesterday my audio worked fine on both my speakers on my laptop (Dell Inspiron/N5110) and headphones. Then all of a sudden they stopped working. I have made sure that all the volumes are not muted. I did a troubleshoot on playing audio and it said low audio device volume...
