Windows 10: Storage spaces issues, help required
Discus and support Storage spaces issues, help required in Windows 10 Drivers and Hardware to solve the problem; I want to set up a drive with Raid 5 or parity. Rather than using a hardware raid card i decided to use the storage space option in win 10. My... Discussion in 'Windows 10 Drivers and Hardware' started by Cineman, Jan 1, 2018.
Storage spaces issues, help required - Similar Threads - Storage spaces issues
Storage Space Issue
in Windows 10 GamingStorage Space Issue: Since updating to Windows 11 22H2 half my storage space is now read-only, anyone knows how to resolve this? https://answers.microsoft.com/en-us/windows/forum/all/storage-space-issue/c65e2f89-c5e4-49d3-bd8b-72f557297df5 -
Storage Space Issue
in Windows 10 Software and AppsStorage Space Issue: Since updating to Windows 11 22H2 half my storage space is now read-only, anyone knows how to resolve this? https://answers.microsoft.com/en-us/windows/forum/all/storage-space-issue/c65e2f89-c5e4-49d3-bd8b-72f557297df5 -
Storage space issue
in Windows 10 Ask InsiderStorage space issue: So, my SSD is showing that out of 111gb, 56gb has been used, and 54 is free space. but when i select and check properties of the files inside, it shows the files are 40gb in total. What is occupying the 14gb space? submitted by /u/Loose_Information_64 [link] [comments]... -
Are these Storage Spaces issues showstoppers?
in Windows 10 Network and SharingAre these Storage Spaces issues showstoppers?: Hello, Issue #1: "The following drive might contain files. If you use a formatted drive with a storage pool, Windows permanently deletes all the files on that drive. You can't recover the files by using the Recycle Bin." I could work around that, but it would be painful,... -
Storage Spaces Error/issue
in Windows 10 Drivers and HardwareStorage Spaces Error/issue: Windows 10 Enterprise Ver 2004 I have created a parity storage space with 4x 4TB SATA Drives. (D: drive) Formatted REFS Windows said the parity space is 9.67 TB using 14.1 TB pool capacity. That was fine by me as the D: reflected this. [img] I have around 3TB of data on... -
in Windows 10 SupportStorage Spaces Error/issue: Windows 10 Enterprise Ver 2004 I have created a parity storage space with 4x 4TB SATA Drives. (D: drive) Formatted REFS Windows said the parity space is 9.67 TB using 14.1 TB pool capacity. That was fine by me as the D: reflected this. [img] I have around 3TB of data on... -
Issue with storage spaces
in Windows 10 Ask InsiderIssue with storage spaces: hi guys, i had a storage space consisting of 2 1TB drives before i had to format my pc, now i want to re-mount the storage space the same way as before but it gives an error saying that the drives cannot be prepared and to chech the connections and try again, theyre the exact... -
Storage space issue
in Windows 10 CustomizationStorage space issue: Please see the two snap shots below and It seems that there is some problem with disk D and it may affect the performance my Windows 10. Can I increase the size of D taking some space from Disk C? or is there any other work around or solution With regards Dr. Abdul... -
Storage Space Issue
in Windows 10 SupportStorage Space Issue: Hi - I have a low spec notebook with Windows 10 preinstalled. Low spec is fine for my purposes but my 32 GB SSD is almost full and this seems to be stopping Windows from updating. Actually I have 7 GB of free space, which I assumed would be sufficient for the update but...
