Windows 10: Store scoops up storage for a game, then starts to chip off of the rest!
Discus and support Store scoops up storage for a game, then starts to chip off of the rest! in Windows 10 Gaming to solve the problem; Hi there, So I want to install final fantasy 15 from game pass on my PC. I have 135 GB left on the drive I want to install it on. I click install,... Discussion in 'Windows 10 Gaming' started by OmairSalman, Feb 29, 2020.
  1. Store scoops up storage for a game, then starts to chip off of the rest!
    Hi there,
    So I want to install final fantasy 15 from game pass on my PC. I have 135 GB left on the drive I want to install it on. I click install, then I check my storage, and 50 left roughly 86 GB, the size of the game, gone, and I say that's normal it did that with every single game. But then, after it finished 1 GB I check my storage by accident and it's 49! I say maybe I did some calculations wrong and wait for another 100 MB to download, and sure enough, 48.9 GB, soo the store is consuming space even after it allocated space for the game!
    Please help!
    Thanks in advance.
  2. DaveM121 Win User
    external storage chip (SDHC card in asus laptop)
    Hi llammp
    If you are downloading that game form the Microsoft Store:
    Open the Settings App (Gear icon on your Start Menu)
    Go to System - Storage - Choose where new content is saved
    Set 'New Apps will be saved to' that storage chip
    The game should then install onto that chip in a new folder called WindowsApps
    DaveM121, Feb 29, 2020
  3. When using MS Minesweeper and select a game I get " A saved game was found in the cloud storage location. Which game would you like to use? " use local
    Hi Jimbo0,
    Having a corrupted game file is one of the potential reasons why you are getting this error: "A saved game was found in the cloud storage location. Which game would you like to use?" when playing the game Microsoft Minesweeper. To help you resolve this
    concern, I need to collect more information. Kindly answer the questions below:
    • When did the issue start?
    • Are you experiencing this concern with all of your games?
    • Have you made any changes on your computer prior to this concern?
    • What are the troubleshooting steps you have done so far?
    • Have you tried uninstalling and reinstalling the affected game?
    In the meantime, I suggest that you perform the troubleshooting steps below:
    Step 1: Run the troubleshooter for Windows apps using the link below. This can help remove problems with an app from Microsoft Store.
    Click here
    Step 2: Check for updates for apps and games from Windows Store. Kindly click the link below to proceed:
    Step 3: Delete Temporary files. This will help delete temporary files that have been stored on your computer.
    1. Click Start and click Settings.
    2. Select System.
    3. Select Storage.
    4. Select This PC.
    5. Click Temporary files.
    6. Choose Temporary files.
    7. Click Remove files.
    Step 4: Reset the game from the Settings menu.
    2. Select System.
    3. Select Apps and features.
    4. Find the game and click Advanced options.
    5. Click Reset. You need to restart your computer to let the changes take effect.
    Kindly update us with the results, so that we can assist you further.
    Wilfred Mac, Feb 29, 2020
  4. Store scoops up storage for a game, then starts to chip off of the rest!
    Not started Asphalt 8
    Thanks for the update. To further isolate this concern, we would like to know if your computer only freezes when accessing the game Asphalt 8.
    For additional troubleshooting steps, I suggest that you perform the troubleshooting steps below:
    Step 1: Check for updates for apps and games from Windows Store. Kindly click the link below to proceed:
    Step 2: Delete Temporary files. This will help delete temporary files that have been stored on your computer.
    2. Select System.
    3. Select Storage.
    4. Select This PC.
    Step 3: Reset the game from the Settings menu.
    2. Select System.
    Kindly update us with the results.
  1. Store scoops up storage for a game, then starts to chip off of the rest! - Similar Threads - Store scoops storage
  2. PC Monitor Shuts off when starting up games.
    PC Monitor Shuts off when starting up games.: I’ve had my PC for over a year now and it’s been working great. But the other day I started up one of the only games I play and after around 5 minutes my screen and sound shut off. When I say the screen shut off it went black but I could tell it was still on. It was like a...
  3. Monitors switching off during game start up
    Monitors switching off during game start up: I have an alienware pc and have 3 monitors connected on it. When I start a game 3 of them will turn off but only 2 will turn on. I have aurora 6 and a gtx 1070. Please help!...
  4. Monitors switching off during game start up
  5. Monitors switching off during game start up
  6. Monitors Switching Off During Game Start-up
    Monitors Switching Off During Game Start-up: So I have an Alienware Aurora R6 with a GTX 1070. I have 3 monitors plugged into the graphics card and recently whenever I go to start a game, all the monitors turn off but only 2 turn back on and the games will not load.Does anyone know what I can do?...
  7. Monitors Switching Off During Game Start-up
  8. Monitors Switching Off During Game Start-up
  9. Internet shuts off whenever I start up a game
    Internet shuts off whenever I start up a game: So I just upgraded to Win10 from win7 a few days ago and I have noticed whenever I start up a game the internet disconnects and I can NOT reconnect. This happens with Borderlands 3 on the Epic games store and the Outerworlds on the Xbox cliet for PC. When this happens my...
  10. external storage chip
    external storage chip: how do I activate it, I have it in and when I look at my storage I see it but I dont know how to use it and since my laptop doesn't have much storage on this thing and I got a chip for sims4...
