Windows 10: Strange sound quality when using BT headphone with built-in microphone.
Discus and support Strange sound quality when using BT headphone with built-in microphone. in Windows 10 Software and Apps to solve the problem; I bought a BT Headphone and it has a good sound quality. But there's a problem; when I try to use it on windows 11 with the built-in mic, the sound... Discussion in 'Windows 10 Software and Apps' started by GabrielSiolari, Jul 24, 2023.
  1. Strange sound quality when using BT headphone with built-in microphone.
    I bought a BT Headphone and it has a good sound quality. But there's a problem; when I try to use it on windows 11 with the built-in mic, the sound quality drops drastically, so I can't use the microphone, I've got to disable it and use the notebook mic. The drivers are updated.
  2. yahanna Win User
    Sound Distortion w/ BT Headphones When I Move BT Mouse -- Help
    I got a BT dongle. When I listen to music through BT headphones and move my mouse at the same time I hear distortion. When I dont move my mouse theres no distortion.
    I got Realtek installed and its drivers updated. Thare are 2 options in the MS sound panel for headphones. One for BT headphones stereo and an other for BT non-stereo headphones. I enabled the one for stereo because it sounds better. But I hear distortion with the BT mouse. When I switch to the BT non-stereo option theres no distortion when I move my mouse but sound quality is bad.
    What do you suggest to hear BT stereo perfectly with no distortion when I move my mouse?
    yahanna, Jul 24, 2023
  3. SupaCrow Win User
    Headphone with built in microphone uses as Microphone, not Headphone
    Okay, so I have an Asus laptop with Windows 10. I am using an Ultimate Ears Headphone with built in microphone. The problem is that i want to use the headphone part, but all the the laptop registers is the microphone.
    Strange sound quality when using BT headphone with built-in microphone. 33176d1485954905t-headphone-built-microphone-uses-microphone-not-headphone-microfone-scraps.png
    How can I change this, as i cannot watch videos without disturbing others.
    SupaCrow, Jul 24, 2023
  4. cemy Win User
    BT headphone no mic on win10pro
    hello, I've tried to use BT headphone on windows10. But when speaker works mic stops. when mic works speaker stops.
    There is two options in my sounds settings stereo and handsfree. Stereo has no mic option. Handsfree has but bad sounds quality on speaker. I want to use mic with good speaker.
    What did I tried to solve
    1- Reset all BT services
    2- uncheck Handsfree on headphones preficens
    3- Set manually speaker and microphone devices
    none of it works..
    Any thoughts?
    Strange sound quality when using BT headphone with built-in microphone. 275187d1587225793t-bt-headphone-no-mic-win10pro-e.png
    Strange sound quality when using BT headphone with built-in microphone. 275188d1587225793t-bt-headphone-no-mic-win10pro-d.png
    Strange sound quality when using BT headphone with built-in microphone. 275189d1587225793t-bt-headphone-no-mic-win10pro-c.png
    Strange sound quality when using BT headphone with built-in microphone. 275190d1587225793t-bt-headphone-no-mic-win10pro-b.png
    Strange sound quality when using BT headphone with built-in microphone. 275191d1587225793t-bt-headphone-no-mic-win10pro-.png
    Strange sound quality when using BT headphone with built-in microphone. 275192d1587225817t-bt-headphone-no-mic-win10pro-g.jpg
    Strange sound quality when using BT headphone with built-in microphone. 275193d1587225817t-bt-headphone-no-mic-win10pro-f.png
  1. Strange sound quality when using BT headphone with built-in microphone. - Similar Threads - Strange sound quality
  2. bt connect headphones but no sound
    bt connect headphones but no sound: I see my headphone connected via BT but no sound comes.It is strange that if I use the built in recorder then I can hear the sounds.But as soon as I close recorder than the head phones are mute.I already removed and installed again all BT drivers.I run trouble...
  3. bt connect headphones but no sound
  4. BT headphones looses quality when using mic?
    BT headphones looses quality when using mic?: Whenever I use my galaxy buds 2 pro with my w11 pc it works great, but when an app uses the microphone of my buds all my audio is suddenly way louder and looses quality too....
  5. BT headphones looses quality when using mic?
  6. AirPods Pro Sound Quality Bad When Using Microphone.
    AirPods Pro Sound Quality Bad When Using Microphone.: My AirPods Pro 2nd Generation sound good when I am using them normally. However, when I start using the microphone, the sound quality degrades significantly. For example, when I am playing a game and using the microphone to talk to others, the sound quality is bad but when I...
  7. AirPods Pro Sound Quality Bad When Using Microphone.
  8. Strange sound quality when using BT headphone with built-in microphone.
    Strange sound quality when using BT headphone with built-in microphone.: I bought a BT Headphone and it has a good sound quality. But there's a problem; when I try to use it on windows 11 with the built-in mic, the sound quality drops drastically, so I can't use the microphone, I've got to disable it and use the notebook mic. The drivers are...
  9. Sound quality of headphones
    Sound quality of headphones: After a long while I'm finally fed up with whatever is happening and I want to get to the bottom of it. For the longest time, the headphone sound quality of my headphones have been fairly subpar. When I first got my computer, my headphones had binaural audio and generally...
  10. Headphone with built in microphone uses as Microphone, not Headphone
    Headphone with built in microphone uses as Microphone, not Headphone: Okay, so I have an Asus laptop with Windows 10. I am using an Ultimate Ears Headphone with built in microphone. The problem is that i want to use the headphone part, but all the the laptop registers is the microphone. [img] How can I change this, as i cannot watch videos...
