Windows 10: Strange sound quality when using BT headphone with built-in microphone.
Discus and support Strange sound quality when using BT headphone with built-in microphone. in Windows 10 Gaming to solve the problem; I bought a BT Headphone and it has a good sound quality. But there's a problem; when I try to use it on windows 11 with the built-in mic, the sound... Discussion in 'Windows 10 Gaming' started by GabrielSiolari, Jul 24, 2023.
Strange sound quality when using BT headphone with built-in microphone. - Similar Threads - Strange sound quality
bt connect headphones but no sound
in Windows 10 Gamingbt connect headphones but no sound: I see my headphone connected via BT but no sound comes.It is strange that if I use the built in recorder then I can hear the sounds.But as soon as I close recorder than the head phones are mute.I already removed and installed again all BT drivers.I run trouble... -
in Windows 10 Software and Appsbt connect headphones but no sound: I see my headphone connected via BT but no sound comes.It is strange that if I use the built in recorder then I can hear the sounds.But as soon as I close recorder than the head phones are mute.I already removed and installed again all BT drivers.I run trouble... -
BT headphones looses quality when using mic?
in Windows 10 GamingBT headphones looses quality when using mic?: Whenever I use my galaxy buds 2 pro with my w11 pc it works great, but when an app uses the microphone of my buds all my audio is suddenly way louder and looses quality too.... -
in Windows 10 Software and AppsBT headphones looses quality when using mic?: Whenever I use my galaxy buds 2 pro with my w11 pc it works great, but when an app uses the microphone of my buds all my audio is suddenly way louder and looses quality too.... -
AirPods Pro Sound Quality Bad When Using Microphone.
in Windows 10 GamingAirPods Pro Sound Quality Bad When Using Microphone.: My AirPods Pro 2nd Generation sound good when I am using them normally. However, when I start using the microphone, the sound quality degrades significantly. For example, when I am playing a game and using the microphone to talk to others, the sound quality is bad but when I... -
in Windows 10 Software and AppsAirPods Pro Sound Quality Bad When Using Microphone.: My AirPods Pro 2nd Generation sound good when I am using them normally. However, when I start using the microphone, the sound quality degrades significantly. For example, when I am playing a game and using the microphone to talk to others, the sound quality is bad but when I... -
in Windows 10 Software and AppsStrange sound quality when using BT headphone with built-in microphone.: I bought a BT Headphone and it has a good sound quality. But there's a problem; when I try to use it on windows 11 with the built-in mic, the sound quality drops drastically, so I can't use the microphone, I've got to disable it and use the notebook mic. The drivers are... -
Sound quality of headphones
in Windows 10 BSOD Crashes and DebuggingSound quality of headphones: After a long while I'm finally fed up with whatever is happening and I want to get to the bottom of it. For the longest time, the headphone sound quality of my headphones have been fairly subpar. When I first got my computer, my headphones had binaural audio and generally... -
Headphone with built in microphone uses as Microphone, not Headphone
in Windows 10 SupportHeadphone with built in microphone uses as Microphone, not Headphone: Okay, so I have an Asus laptop with Windows 10. I am using an Ultimate Ears Headphone with built in microphone. The problem is that i want to use the headphone part, but all the the laptop registers is the microphone. [img] How can I change this, as i cannot watch videos...
