Windows 10: Stuck in diagnostic mode, PIN # not accepted, please help
Discus and support Stuck in diagnostic mode, PIN # not accepted, please help in Windows 10 Support to solve the problem; I had no issues with my computer prior. I simply was following some online suggestions for ways to reduce lag in an online game we like to play. The... Discussion in 'Windows 10 Support' started by thytaysmom, Dec 3, 2017.
Stuck in diagnostic mode, PIN # not accepted, please help - Similar Threads - Stuck diagnostic mode
Windows 10 stuck on Diagnostic Mode, tried safe mode and it won’t accept my password
in Windows 10 Software and AppsWindows 10 stuck on Diagnostic Mode, tried safe mode and it won’t accept my password: Alright to make it short, yesterday I tried diagnostic startup since I was having some problems with my PC, and now I’m stuck on it since I can’t enter a PIN. I’ve read every solution saying to “recover PC” or “restore previous configuration”, everything in safe mode, but... -
in Windows Hello & LockscreenWindows 10 stuck on Diagnostic Mode, tried safe mode and it won’t accept my password: Alright to make it short, yesterday I tried diagnostic startup since I was having some problems with my PC, and now I’m stuck on it since I can’t enter a PIN. I’ve read every solution saying to “recover PC” or “restore previous configuration”, everything in safe mode, but... -
in Windows 10 GamingWindows 10 stuck on Diagnostic Mode, tried safe mode and it won’t accept my password: Alright to make it short, yesterday I tried diagnostic startup since I was having some problems with my PC, and now I’m stuck on it since I can’t enter a PIN. I’ve read every solution saying to “recover PC” or “restore previous configuration”, everything in safe mode, but... -
Stuck in Diagnostic Mode
in Windows 10 SupportStuck in Diagnostic Mode: Running latest version of Win 10 Pro updated to latest. I used msconfig to boot into diagnostic mode to fix a printer problem. When Windows opened it said my Pin was not usable and that I should use my password. I haven't used the password in a long time and have forgotten... -
Pin & Password not accepted after msconfig diagnostic startup
in User Accounts and Family SafetyPin & Password not accepted after msconfig diagnostic startup: Using a Shift-Restart I can get into the recovery menus and even login to the command prompt using the same password that doesn't work at GUI boot. Is there a way from the command prompt to set it to what msconfig calls a normal boot? Thanks! 179157 -
Diagnostic Mode - Pin isn’t available
in Windows Hello & LockscreenDiagnostic Mode - Pin isn’t available: So I went into msconfig and changed to boot in diagnostics mode and clicked restart. Now I cant get into windows, im only seeing this screen:[IMG] Selecting “Set up my pin” does nothing. There are no options for other login methods or anything. Repair didnt do anything... -
Something happened and your pin is not available - stuck in Msconfig diagnostic mode
in Windows 10 Ask InsiderSomething happened and your pin is not available - stuck in Msconfig diagnostic mode: Any fix? submitted by /u/ben_aloha [link] [comments] https://www.reddit.com/r/Windows10/comments/kbmiig/something_happened_and_your_pin_is_not_available/ -
Stuck in Utility mode, please help
in Windows 10 Ask InsiderStuck in Utility mode, please help: Hey everyone, i downloaded what i thought was a program to download twitch videos, the moment i click on download the pc goes to blue screen and it says "your pc ran into a problem and needs to restart" So i waited, but i noticed that it got stuck in 100% for a while, so i... -
Stuck in safe mode windows 10 and PIN not accept
in Windows 10 Installation and UpgradeStuck in safe mode windows 10 and PIN not accept: Please follow this method for stuck out from safe mode where PIN is not accepting. Type bcdedit /deletevalue {current} safeboot and hit enter Key.[ATTACH]...
