Windows 10: System interrupts - fresh install problem (Stop if disable Audio contr
Discus and support System interrupts - fresh install problem (Stop if disable Audio contr in Windows 10 Drivers and Hardware to solve the problem; Hello, at first, sorry for my english. I noticed this problem after my WIN 10 was ugpraded to the latest "Creators update". I though it should be... Discussion in 'Windows 10 Drivers and Hardware' started by Kaper, Apr 19, 2017.
System interrupts - fresh install problem (Stop if disable Audio contr - Similar Threads - System interrupts fresh
Audio issues with fresh install
in Windows 10 Drivers and HardwareAudio issues with fresh install: Fresh install of windows 10. I only get audio to work when i uninstall my audio drivers and restart. However, if I shut down without uninstalling drivers I get no audio on my next startup. It shows that sound is playing in the volume mixer, but there is no output. Usually... -
in Windows 10 GamingAudio issues with fresh install: Fresh install of windows 10. I only get audio to work when i uninstall my audio drivers and restart. However, if I shut down without uninstalling drivers I get no audio on my next startup. It shows that sound is playing in the volume mixer, but there is no output. Usually... -
in Windows 10 Software and AppsAudio issues with fresh install: Fresh install of windows 10. I only get audio to work when i uninstall my audio drivers and restart. However, if I shut down without uninstalling drivers I get no audio on my next startup. It shows that sound is playing in the volume mixer, but there is no output. Usually... -
System interrupts
in Windows 10 Software and AppsSystem interrupts: I'm facing some issues with my hp pavilion. Recently when i tried opening my edge browser it crashed 3 times which never happened before. So i looked up in my task manager and found out that System interrupts are using up 100% or sometimes 80% of my cpu. I don't know what's... -
system interrupts
in Windows 10 Drivers and Hardwaresystem interrupts: My computer often freezes on start up. This time when I checked to task manager I found that system interrupts was utilising 100% of my Intel i7 processor. I am running Windows 10 home with all updates in place. Ram is 12. According to task manager it is not a good idea... -
Fresh Install Problems
in Windows 10 Installation and UpgradeFresh Install Problems: Hi there. I'm noticing some random issues after a fresh install of Windows 10 on my laptop. I used the "Media Creation Tool" to create an installation via USB. Afterwards I installed updated drivers pre-downloaded via Dells website, then installed any updates Windows had.... -
System Interrupts
in Windows 10 BSOD Crashes and DebuggingSystem Interrupts: So I have a Asus VivoBook x541u with the following specs(initial) specs: Intel core i7-7500u 2.7 Ghz (boosted to 3.5 Ghz) 1 TB HDD 6 GB DDR4 RAM Nvidia Geforce GT 920 MX 2 GB Windows 10 64 bit Home Edition Recently I have upgraded my ram from 6 GB to 12 GB and removed... -
System Interrupts - Problem or Symptom?
in Windows 10 SupportSystem Interrupts - Problem or Symptom?: See if anyone has ideas on this... My Windows 10 Home (1803) has been experiencing download problems. I pretty much always use Chrome. Sometimes the download will complete without a hitch. Other times the whole system will grind to a halt - even task manager is slow to... -
How to disable the contr+click to follow hyperlinks?
in Windows 10 CustomizationHow to disable the contr+click to follow hyperlinks?: It is really hard to press control and click when I want to follow the link. I’ve used my PC for 5 years and have never met such issue. It had been so easy before I installed Windows 10. How can I turn off this time consuming function?...
