Windows 10: System Power Report: UNKNOWN [NONE] entity occupies huge amount of battery drain
Discus and support System Power Report: UNKNOWN [NONE] entity occupies huge amount of battery drain in Windows 10 BSOD Crashes and Debugging to solve the problem; Hi guys, I recently bought a used Surface Laptop and have been testing it. The System Power Report indicated that during my active sessions on... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by shakatran, Oct 9, 2018.
System Power Report: UNKNOWN [NONE] entity occupies huge amount of battery drain - Similar Threads - System Power Report
The Unknown[None] in report of "Powercfg /spr"
in Windows 10 GamingThe Unknown[None] in report of "Powercfg /spr": Hello Every body: I found a issue when I push most of process into EcoQos, The "Unknown[None]" will high than not use EcoQos. I don't know what the reason of this, Please help me. Thank you!!... -
in Windows 10 Software and AppsThe Unknown[None] in report of "Powercfg /spr": Hello Every body: I found a issue when I push most of process into EcoQos, The "Unknown[None]" will high than not use EcoQos. I don't know what the reason of this, Please help me. Thank you!!... -
Power drain from battery
in Windows 10 Software and AppsPower drain from battery: Hi everyone,I found out about 6 months ago, that battery on my Asus Zephyrus G14 rapidly drain if I don't do windows updates from approx. 5 hours to only about 1 hour 10 minutes. I had this issue on win10 and even now when I upgraded to the win11. Temperature is pretty high... -
in Windows 10 GamingPower drain from battery: Hi everyone,I found out about 6 months ago, that battery on my Asus Zephyrus G14 rapidly drain if I don't do windows updates from approx. 5 hours to only about 1 hour 10 minutes. I had this issue on win10 and even now when I upgraded to the win11. Temperature is pretty high... -
Windows 'system and reserved' taking up a huge amount of space in an unknown location
in Windows 10 Network and SharingWindows 'system and reserved' taking up a huge amount of space in an unknown location: I tried to install a large game, and I realized my computer was running out of space. When went to the Storage Settings, I saw that 145 GB of my Local Disk C I only have Disk was being used up out of 167 GB. When I clicked on show more categories, 86.4 GB was being used up by... -
Battery report at 153%, different from system battery indicator, battery drain to 0%,...
in Windows 10 Ask InsiderBattery report at 153%, different from system battery indicator, battery drain to 0%,...: I have the following issue: The laptop discharges during sleep down to 0%. This is below the 5% threshold at which it shuts down automatically when being used. In summary, the laptop drains much energy during sleep at night time. To understand this, the following was done:... -
Battery Draining Quickly - Ran Battery Health Report
in Windows 10 Performance & MaintenanceBattery Draining Quickly - Ran Battery Health Report: In the past 1 - 1.5 weeks I have noticed that my battery is draining much quicker than it used to. I have a Dell XPS 13 that I bought new in July 2018. My battery, up until a week or so ago, was lasting anywhere from 5-8 hours depending on how much I used it throughout the... -
Fast Battery Power Draining
in Windows 10 Performance & MaintenanceFast Battery Power Draining: Hello, I have a problem with my PC involving my battery. I found out what the problem was, but not how to solve it. Here is what I did: On command prompt with administrator privileges, I typed: powercfg/energy. Next, once I had and read the report, I understood the... -
SYSTEM is consuming huge amount of data on internet
in Windows 10 Network and SharingSYSTEM is consuming huge amount of data on internet: Good Afternoon! Recently, I bought a second hand laptop with Windows 10 pre-installed to it. Here are some details regarding my OS: Edition: Windows 10 Enterprise Version: 1703 OS Build: 15063.11 System Type: 64-bit operating system, x64-based processor I noticed however,...
sleepstudy Unknown
,sleep report abnormal shutdown
,unknown [none] battery drain
,- unknown [none] sleepstudy,
- windows aleep study power estimation shows unknown,
- battery showing unknown powercfg,
- sleep study power estimation unknown,
- powercfg /sleepstudy report shows unknown [none] appid primary source battery drain,
- windows sleepstudy unknown appid,
- unknown (none) powerfg,
- app id unknown none sleepstudy,
- windows 10 drain unknown [none],
- system power report activity battery drain
