Windows 10: System reverts to default power settings on reboot.
Discus and support System reverts to default power settings on reboot. in Windows 10 Support to solve the problem; Hi, I run a HTPC in my front room and this hosts all my media, so other devices on the network can access it. Due to this, I need to prevent the... Discussion in 'Windows 10 Support' started by RossL, Mar 30, 2018.
System reverts to default power settings on reboot. - Similar Threads - System reverts default
Screen Turn Off Power Setting reverts to default on restart but does not change on power...
in Windows 10 Software and AppsScreen Turn Off Power Setting reverts to default on restart but does not change on power...: The VIDEOIDLE setting changes to default 0x00000384 15 min. whenever I reboot the system. It stays at 0x00000000 Never - my preferred setting when I power off and power on system or return from sleep mode. The Power mode is performance. Windows 11 Home build 22000.556. This... -
in Windows 10 GamingScreen Turn Off Power Setting reverts to default on restart but does not change on power...: The VIDEOIDLE setting changes to default 0x00000384 15 min. whenever I reboot the system. It stays at 0x00000000 Never - my preferred setting when I power off and power on system or return from sleep mode. The Power mode is performance. Windows 11 Home build 22000.556. This... -
Monitor settings constantly reverting to default
in Windows 10 GamingMonitor settings constantly reverting to default: Hi there. First-time poster. I just got a new laptop for work Dell Precision 5560 that is connected to two monitors Dell P2419H via two display port cables to a Dell Thunderbolt Dock WD19TBS. NVIDIA T1200.Under the display settings, I am able to add both screens to my set-up... -
in Windows 10 Software and AppsMonitor settings constantly reverting to default: Hi there. First-time poster. I just got a new laptop for work Dell Precision 5560 that is connected to two monitors Dell P2419H via two display port cables to a Dell Thunderbolt Dock WD19TBS. NVIDIA T1200.Under the display settings, I am able to add both screens to my set-up... -
in Windows 10 Drivers and HardwareMonitor settings constantly reverting to default: Hi there. First-time poster. I just got a new laptop for work Dell Precision 5560 that is connected to two monitors Dell P2419H via two display port cables to a Dell Thunderbolt Dock WD19TBS. NVIDIA T1200.Under the display settings, I am able to add both screens to my set-up... -
Mouse Cursor Reverts to Default on Reboot
in Windows 10 Drivers and HardwareMouse Cursor Reverts to Default on Reboot: I have recently purchased a new hp pavilion laptop, Model Number: HP 15-cs3055wm I have customized it with a cursor scheme that I absolutely love, however, anytime I turn the device off and back on the cursor scheme reverts back to default. When I go back into the... -
Custom Text Settings Reverting To Default.
in Windows 10 CustomizationCustom Text Settings Reverting To Default.: Following clean install I set the 'Icons' text to size 11 and bold. This was fine all day yesterday and through a few shutdowns and restarts. Today and those settings have reverted to default, but not only that, the options to change them back again are greyed out as can be... -
Registry Settings Revert after Reboot
in Windows 10 CustomizationRegistry Settings Revert after Reboot: Because the advanced appearance settings in win10 were omitted I manually tweaked the registry. After log off or reboot they (the registry) assume the default state. Now I'm pretty desperate and in fragile mental condition. But I'm here now and know that You'll came up with a... -
sound settings revert to defaults
in Windows 10 Supportsound settings revert to defaults: I've set the audio settings and saved them SEVERAL times. I know how to do it correctly. Windows 10 will not save my settings. They revert to the defaults. When I select any of my saved schemes, every sound is the default. AARRGGHH!! *Mad 29207
group policy settings reverting after sleep mode
,power and sleep setting revert back to default after restarting
