Windows 10: Taskbar right-click menu and system tray icons delay
Discus and support Taskbar right-click menu and system tray icons delay in Windows 10 Support to solve the problem; Hello, recently my system has developed a weird issue. Right-clicking on the taskbar on any open applications that I have stops working quite often... Discussion in 'Windows 10 Support' started by zil, Aug 22, 2017.
Taskbar right-click menu and system tray icons delay - Similar Threads - Taskbar right click
Windows 11 System Tray Security Icon. No Context Menu when right click.
in Windows 10 GamingWindows 11 System Tray Security Icon. No Context Menu when right click.: Hello. I have Windows 11 Ver.22H2. Not sure if this problem happened after an update or not but the Windows security Icon in the system tray will no longer show the context menu when I right click on it. All other icons in the system try work fine no problem getting the... -
in Windows 10 Software and AppsWindows 11 System Tray Security Icon. No Context Menu when right click.: Hello. I have Windows 11 Ver.22H2. Not sure if this problem happened after an update or not but the Windows security Icon in the system tray will no longer show the context menu when I right click on it. All other icons in the system try work fine no problem getting the... -
Right click menu doesn't show up in taskbar icon
in Windows 10 CustomizationRight click menu doesn't show up in taskbar icon: Hey. So basically, I can't view the right click menu that pops up whenever you right click on a taskbar icon I can on the desktop and file explorer though. I don't know if this is related but I recently updated my Windows too.... -
Keyboard shortcut to "right click" taskbar/system tray items
in Windows 10 CustomizationKeyboard shortcut to "right click" taskbar/system tray items: Community: I'm aware of the keyboard shortcuts to access the TaskbarWin-T and System TrayWin-B. I can then navigate the items on those bars using arrow keys. From there, is there an option to "right click" the selected item? For instance, using Win-T I navigate to... -
Right Click menu for taskbar broken
in Windows 10 CustomizationRight Click menu for taskbar broken: Hello dear All, After updating windows to 1909 from 1803 my right menu is brocken When I try to click the actions in the right click menu I always have this message for every program: [ATTACH] The same behavior in the start menu Many thanks, Iacob... -
Right-click menu doesn't come up for taskbar icons ... ???
in Windows 10 SupportRight-click menu doesn't come up for taskbar icons ... ???: Seems like in Windows 10 with the latest cumulative updates (as of 9/14/19 yesterday), I can't right-click on my taskbar icons and have the right-click menu come up (the one that allows for the pinning or unpinning of icons). I uninstalled the updates, and this functionality... -
Delay in Right Click
in Windows 10 BSOD Crashes and DebuggingDelay in Right Click: Hi all, I am facing a problem in Right Click in mouse. Whenever I make a right click on blank space in Desktop or in File browser in order to "Refresh" or to create "New Folder" or any other purpose, it takes quite a bit of time (3 seconds) for the menu to pop-up. I don't... -
Right Click Taskbar Menu
in Windows 10 CustomizationRight Click Taskbar Menu: Not sure if possible but can you add to this menu? 27413 -
Taskbar: Can't right click app icons & can't left click system icons
in Windows 10 SupportTaskbar: Can't right click app icons & can't left click system icons: Hi, After doing a lot of tweaking, I've came across a very weird problem at taskbar. When I right click pinned apps on taskbar nothing happens. But left click works. When I left click system icons like volume and network, nothing happens. But right click works....
windows 10 taskbar system icons dont respond to click
,PAUSE WHEN RIGHT CLICKING ON TASKBAR ICONS
