Windows 10: Taskbar Volume will not open with left click
Discus and support Taskbar Volume will not open with left click in Windows 10 Support to solve the problem; My volume control, calendar and network status on my windows 10 task-bar stopped working last week. I can still right click an choose open but I get... Discussion in 'Windows 10 Support' started by irblrb84, Apr 15, 2016.
Taskbar Volume will not open with left click - Similar Threads - Taskbar Volume open
Left click didn't open a foldier
in Windows 10 Network and SharingLeft click didn't open a foldier: Hi, okay so I opened a file called "files" and then I tried opening "games" that was inside that foldier and when I did try opening it using left click I need to click only once it opened properites of that file. This fixed when I closed foldier and opened it. Is this a bug,... -
in Windows 10 GamingLeft click didn't open a foldier: Hi, okay so I opened a file called "files" and then I tried opening "games" that was inside that foldier and when I did try opening it using left click I need to click only once it opened properites of that file. This fixed when I closed foldier and opened it. Is this a bug,... -
in Windows 10 Software and AppsLeft click didn't open a foldier: Hi, okay so I opened a file called "files" and then I tried opening "games" that was inside that foldier and when I did try opening it using left click I need to click only once it opened properites of that file. This fixed when I closed foldier and opened it. Is this a bug,... -
Left clicking Volume icon not working
in Windows 10 Ask InsiderLeft clicking Volume icon not working: When I try left clicking the volume icon on my taskbar it doesn’t work. Right clicking the apps on my taskbar doesn’t work either. I can left click my apps and open them, but I can’t left click my icons on the right side of the taskbar. I tried to restart my windows explorer... -
Can't left click items in Taskbar
in Windows 10 Ask InsiderCan't left click items in Taskbar: Hello everyone, first time posting here. First thanks in advance for any help. So I am having an issue with my laptop (MSi GT73EVR 7RE) and I can't find a solution. I simply can't click on the items in my taskbar, like the Windows menu, search, or the notification area.... -
Cannot left click on taskbar icons.
in Windows 10 Network and SharingCannot left click on taskbar icons.: Hello there, I am having an issue, and it has been going on for about 2 months now. I cannot left click on the taskbar icons that are located next to the clock (eg. Wi-Fi, Sound, Clock). And along with that, I cannot right click on any of my programs that I have added to... -
Items on desktop will not open on left click
in Windows 10 CustomizationItems on desktop will not open on left click: Items on desktop will not open on left click, must right click and select OPEN. Same probl;em on multiple PCs, began all at once on all PCs. Same problems on Windows Live Mail --- clicking on an email will not open it. Also on other apps, for example, trying to open a file... -
Items pinned to Explorer on Taskbar no longer open with left click
in Windows 10 SupportItems pinned to Explorer on Taskbar no longer open with left click: Just did a clean install of W10 Pro X64 on my recently inherited PC and have discovered that folders I have pinned to Explorer on the Taskbar can no longer be opened with left click. Have to use right click and the Open. This did work normally when I cloned the system from... -
Unable to left click on almost anything at the taskbar
in Windows 10 SupportUnable to left click on almost anything at the taskbar: Hello, I know that this might be an old issue, but I tried some of the solutions mentioned earlier this year here and on other websites but none worked for me.. Is there a new fix for this issue? Thanks, 56445
cant left click volume taskbar
,Taskbar Volume will not open with left click
