Windows 10: The power will not turn on and will not start unless the battery and AC adapter are removed...
Discus and support The power will not turn on and will not start unless the battery and AC adapter are removed... in Windows 10 Performance & Maintenance to solve the problem; Nice to meet you all.I am using a Windows 10 Home 21H1 laptop.About a month ago, even if I pressed the power button in hibernation or shutdown state,... Discussion in 'Windows 10 Performance & Maintenance' started by Ku To, Oct 4, 2021.
The power will not turn on and will not start unless the battery and AC adapter are removed... - Similar Threads - power turn start
AC Adapter and ACPI Compliant Control Method Battery
in Windows 10 Software and AppsAC Adapter and ACPI Compliant Control Method Battery: Hello,I'm having an issue with my Surface Pro, where the laptop needs to be plugged into a charger to stay on. The battery stays at 0% while plugged in and turns off if I unplug it.I've looked in my Device Manager for my ACPI Compliant Control Method Battery, to restart it,... -
How to use AC Power Adapter instead of battery
in Windows 10 GamingHow to use AC Power Adapter instead of battery: Hi,I have the *ASUS TUF F15 2021* I want to use this laptop while using the AC Power Adapter because it performs better than Battery mode while using the battery*So, is there a way to do that without decreasing the battery's lifespan?*... -
in Windows 10 Software and AppsHow to use AC Power Adapter instead of battery: Hi,I have the *ASUS TUF F15 2021* I want to use this laptop while using the AC Power Adapter because it performs better than Battery mode while using the battery*So, is there a way to do that without decreasing the battery's lifespan?*... -
Asus Zenbook. Microsoft AC adapter. Battery issue
in Windows 10 Drivers and HardwareAsus Zenbook. Microsoft AC adapter. Battery issue: Hi guys. I just bought Asus Zenbook and a few days ago I took the cable out and it stopped working. The laptop works only when it is plugged in.In Device Manager in batteries I saw only Microsoft ACPI, so I don't see Microsoft AC Adapter.Any advise on how to fix it? Thank... -
AC adapter and battery issue
in Windows 10 BSOD Crashes and DebuggingAC adapter and battery issue: Why does my computer say low battery when it is plugged in and if I unplug the AC adapter the battery has a full charge? When the message appears the programs run slow. If I unplug the adapter for about 5 minutes said is a 0% charge, after that the battery is full. The... -
AC adapter and battery not detected or recognized
in Windows 10 Performance & MaintenanceAC adapter and battery not detected or recognized: When starting the laptop the screen displays this " AC power not recognized and battery not charging". The jack plug was changed and instaled a new battery and the problem continues. what can I do to fix the issue?... -
ac adapter warning message; battery will not charge
in Windows 10 Performance & Maintenanceac adapter warning message; battery will not charge: Need a fix for ac adapter warning as the battery will not charge. Says to use a 45 w adapter, but that's what I have. Any suggestions? https://answers.microsoft.com/en-us/windows/forum/all/ac-adapter-warning-message-battery-will-not-charge/7e3d3e2b-37bd-48a8-abcf-a70096d1c4c9 -
ac adapter for battery charger not charging
in Windows 10 Drivers and Hardwareac adapter for battery charger not charging: my dell insprion 5551 ac adapter isn't charging by battery and I have tried all the suggestions that dell provided and still nothing. my battery is at 10%. I not had a problem till I remember month or 2 ago I reset my pc but ac adapter didn't get notice till month ago. when I... -
AC Adapter or Faulty Battery?
in Windows 10 Drivers and HardwareAC Adapter or Faulty Battery?: Hi there! Well, after what it seem to be like my triumph against sudden reboots (probably I just needed to fasten some screws to get all in order) I have a little doubt, since always, I noticed that my laptop battery tends to "discharge" when I do extensive tasks, name it...
