Windows 10: There is a battery issue when i plug in the battery there seems a orange led light and...
Discus and support There is a battery issue when i plug in the battery there seems a orange led light and... in Windows 10 Gaming to solve the problem; There is a battery issue when i plug in the battery there seems a orange led light and after few seconds led white light is coming please suggest me my... Discussion in 'Windows 10 Gaming' started by santosh kumar13, Feb 22, 2024.
  1. There is a battery issue when i plug in the battery there seems a orange led light and...
    There is a battery issue when i plug in the battery there seems a orange led light and after few seconds led white light is coming please suggest me my system details are below OS Name Microsoft Windows 11 Home Single Language Version 10.0.22631 Build 22631 Other OS Description Not Available OS Manufacturer Microsoft CorporationSystem Name YUVANBHUVAN System Manufacturer HP System Model HP Laptop 15-da0xxx System Type x64-based PC System SKU 4ZD78PA#ACJ Processor IntelR PentiumR Silver N5000 CPU @ 1.10GHz, 1101 Mhz, 4 Cores, 4 Logical Processors BIOS Version/Date Insyde F.36, 03-02-20
  2. ICIT2LOL Win User
    Orange battery light on laptop
    I have an Asus RGO G750JM laptop which is showing me an orange light showing next to the power light.
    I have renewed the battery but no go any any ideas appreciated*Rolleyes.
    NB machine does run on power adaptor only and even when it is unplugged so I am at a loss as to why the battery is not showing any signs of charging.
    ICIT2LOL, Feb 22, 2024
  3. Battery light is blinking orange
    I have a Windows 10 and the battery light is blinking orange even though I have it plugged in, and it says that it's at 100% even though it is not.
    Original subject: Battery
    Moved from: Windows / Windows 10 / Power on or off a device
    AlexandraJones, Feb 22, 2024
  4. There is a battery issue when i plug in the battery there seems a orange led light and...
    Step 1
    1. Shutdown your laptop.
    2. Remove the battery.
    4. Power on the laptop
    There is a battery issue when i plug in the battery there seems a orange led light and... pbDp4sx.png
    7. Shutdown the laptop.
    8. Insert the battery.
    9. Power on the laptop.
    Step 2
    1. Shutdown the laptop.
    Step 3
    FreeBooter, Feb 22, 2024
  1. There is a battery issue when i plug in the battery there seems a orange led light and... - Similar Threads - battery issue plug
  2. Battery icon is showing at 90% charging plugged in but indicator light is blinking orange
    Battery icon is showing at 90% charging plugged in but indicator light is blinking orange: Hi there, hello!I have the following problem: My Laptop tells me the battery is fully charged 100% and it also recognizes that the charger is plugged in, but the indicator light is blinking orange, as if the battery was very low. The laptop is plugged in the whole time. As...
  3. Battery icon is showing at 90% charging plugged in but indicator light is blinking orange
  4. The battery is at 99% but the LED indicator shows solid orange light, even when plugged in.
    The battery is at 99% but the LED indicator shows solid orange light, even when plugged in.: Hello, I hope you can help me, I recently bought an Asus Tuf gaming a15 laptop, and it works very well, my concern is that the battery LED indicator shows a static orange light, I know that that light means that the device is below 95% battery, but it shows that it has 99%,...
  5. The battery is at 99% but the LED indicator shows solid orange light, even when plugged in.
  6. There is a battery issue when i plug in the battery there seems a orange led light and...
    There is a battery issue when i plug in the battery there seems a orange led light and...: There is a battery issue when i plug in the battery there seems a orange led light and after few seconds led white light is coming please suggest me my system details are below OS Name Microsoft Windows 11 Home Single Language Version 10.0.22631 Build 22631 Other OS...
  7. Battery is at 100% but indicator light is blinking orange
    Battery is at 100% but indicator light is blinking orange: Hi there, hello!I have the following problem: My Laptop tells me the battery is fully charged 100%, but the indicator light is blinking orange, as if the battery was very low. The laptop is plugged in the whole time. As soon as I unplug the charger, the laptop immediately...
  8. Battery is at 100% but indicator light is blinking orange
  9. Battery fully charged but orange LED is blinking
    Battery fully charged but orange LED is blinking: My Dell M4800 battery fully charged but the orange LED is blinking. https://answers.microsoft.com/en-us/windows/forum/all/battery-fully-charged-but-orange-led-is-blinking/94ba2e16-74e1-4088-a47b-590a7a2f6720
  10. Orange battery light on laptop
    Orange battery light on laptop: I have an Asus RGO G750JM laptop which is showing me an orange light showing next to the power light. I have renewed the battery but no go any any ideas appreciated*Rolleyes. NB machine does run on power adaptor only and even when it is unplugged so I am at a loss as to why...
