Windows 10: What audio driver can work on intel celenon 1.10 in order for my pc to produce sound
Discus and support What audio driver can work on intel celenon 1.10 in order for my pc to produce sound in Windows 10 Drivers and Hardware to solve the problem; My pc keeps bumping into blue screen of death when I am trying to install audio driver. Which audio driver is required for my pc to produce sound.*... Discussion in 'Windows 10 Drivers and Hardware' started by Abdlazheez Boston, Sep 16, 2024.
  1. What audio driver can work on intel celenon 1.10 in order for my pc to produce sound
    My pc keeps bumping into blue screen of death when I am trying to install audio driver. Which audio driver is required for my pc to produce sound.* Changed to a question
  2. JoeBoyka Win User
    The Ultimate Realtek HD Audio Driver Mod for Windows 10
    Everything is working *Smile What audio driver can work on intel celenon 1.10 in order for my pc to produce sound :)
    JoeBoyka, Sep 16, 2024
  3. Jayce Win User
    Everyone that post ids, need just do these steps and you will be good. I kinda tired of keep on uploading the inf. file
    1.Go Open up device manager
    2. Go under sound,video, and game controllers
    3. Find Realtek High Definition Audio
    4. Right click and hit update driver
    5. Browse my computer for driver software
    6. Let me pick from a list of available drivers on my computer
    7. Click Have Disk and hit browse
    8. Click on the Realtek HD Audio mod folder and look for win64
    9. Click on the HDXRT4 and click ok,
    10. Click Next and Yes
    additional if you want dts audio and others, install it now before next step.
    After it is done, restart the PC
    You should be good then and also make sure before doing these steps that you have driver enforcement disabled.
    Jayce, Sep 16, 2024
  4. Jayce Win User
    I had the realtek error when using the installer, so I did these step and It Worked
    Jayce, Sep 16, 2024
  1. What audio driver can work on intel celenon 1.10 in order for my pc to produce sound - Similar Threads - audio driver intel
  2. What audio driver can work on intel celenon 1.10 in order for my pc to produce sound
    What audio driver can work on intel celenon 1.10 in order for my pc to produce sound: My pc keeps bumping into blue screen of death when I am trying to install audio driver. Which audio driver is required for my pc to produce sound.* Changed to a question...
  3. What audio driver can work on intel celenon 1.10 in order for my pc to produce sound
  4. what audio driver can work on intel celenon 1.10 inorder for my pc to produce sound
    what audio driver can work on intel celenon 1.10 inorder for my pc to produce sound: My pc keeps bumping into blue screen of death when I am trying to install audio driver. Which audio driver is required for my pc to produce sound....
  5. what audio driver can work on intel celenon 1.10 inorder for my pc to produce sound
  6. what audio driver can work on intel celenon 1.10 inorder for my pc to produce sound
  7. Audio Volume is only producing 1-2%
    Audio Volume is only producing 1-2%: I have an audiobox with a microphone set up on my computer. In all of my applications, like Zoom, Berrycast and other video streaming or recording software, it seems to work fine. But when I try to use the camera or voice recorder on the PC, it is very quiet. When I go into...
  8. Audio driver issue, not producing any sounds
    Audio driver issue, not producing any sounds: I bought a new headphones and wants to try the quality of it. I have the headphones connected but it won't produce any sounds, I also switch back to speaker and it won't produce anything either. Please help....
  9. Audio driver issue, not producing any sounds
  10. Audio driver issue, not producing any sounds
