Windows 10: Why my laptop often die/lost power when I set my Maximum Power State to 100% on Power...
Discus and support Why my laptop often die/lost power when I set my Maximum Power State to 100% on Power... in Windows 10 Software and Apps to solve the problem; My laptop has been dying randomly and will reboot itself up these past 2 months. I suppose this is due to overheating as I noticed that when I have a... Discussion in 'Windows 10 Software and Apps' started by Momo Rei, Oct 6, 2024.
Why my laptop often die/lost power when I set my Maximum Power State to 100% on Power... - Similar Threads - Why laptop often
in Windows 10 GamingWhy my laptop often die/lost power when I set my Maximum Power State to 100% on Power...: My laptop has been dying randomly and will reboot itself up these past 2 months. I suppose this is due to overheating as I noticed that when I have a cooling pad + cool room/aircon, the crashing would appear less often means that it still appear like once a day or once in 3... -
My laptop crash or freeze when i set processor power management 100%
in Windows 10 GamingMy laptop crash or freeze when i set processor power management 100%: when i put my processor power management to 100% my laptop randomly crash sometimes blue screen, but when i put it on 95-99% it runs perfectly fine, but the performance is downed.the first time my laptop did this i thought my laptop was overheating so i changed the thermal... -
in Windows 10 Software and AppsMy laptop crash or freeze when i set processor power management 100%: when i put my processor power management to 100% my laptop randomly crash sometimes blue screen, but when i put it on 95-99% it runs perfectly fine, but the performance is downed.the first time my laptop did this i thought my laptop was overheating so i changed the thermal... -
My laptop freeze randomly when I set Maximum Processor State at 100%
in Windows 10 BSOD Crashes and DebuggingMy laptop freeze randomly when I set Maximum Processor State at 100%: Hi guys, as the title, my laptop freeze randomly and stop working I must force shutdown and reset the laptop whenever I set Maximum Processcor State at 100%If I set it down to 99%, my laptop works well but the performance is downed significantly.For example: - When I set it... -
in Windows 10 GamingMy laptop freeze randomly when I set Maximum Processor State at 100%: Hi guys, as the title, my laptop freeze randomly and stop working I must force shutdown and reset the laptop whenever I set Maximum Processcor State at 100%If I set it down to 99%, my laptop works well but the performance is downed significantly.For example: - When I set it... -
in Windows 10 Software and AppsMy laptop freeze randomly when I set Maximum Processor State at 100%: Hi guys, as the title, my laptop freeze randomly and stop working I must force shutdown and reset the laptop whenever I set Maximum Processcor State at 100%If I set it down to 99%, my laptop works well but the performance is downed significantly.For example: - When I set it... -
Advanced Power Plan Setting "Maximum Processor state" and "Minimum processor state" not...
in Windows 10 Ask InsiderAdvanced Power Plan Setting "Maximum Processor state" and "Minimum processor state" not...: SPECS: Win 10 (obv) i7 10700F 16GB 3000mhz 1660 Super So I used to set my processor states to prevent overheating, as my processor runs at 4.6 ghz, and only a few games can get it beyond what I like in terms of temp (80c+ or 176f+), as it generally rests around 80c/174f... -
Maximum and Minimum Processor State missing in Power management settings
in Windows 10 GamingMaximum and Minimum Processor State missing in Power management settings: I tried the command prompt fix, downloading the registry file and running it and both didn't work to bring back those 2 options.I am running on Windows 10 20H2 version. Pls help asap... -
Laptop Lost Power
in Windows 10 Drivers and HardwareLaptop Lost Power: Hi I was using my Laptop, Dell Vostro 1000, and it shut down. I pushed the power button and nothing happened, so I did the following: Checked the wall outlet. Removed the battery and tried to power it up with the power adapter. Replaced the power adapter. Tried to power...
