Windows 10: Why my laptop often die/lost power when I set my Maximum Power State to 100% on Power...
Discus and support Why my laptop often die/lost power when I set my Maximum Power State to 100% on Power... in Windows 10 Gaming to solve the problem; My laptop has been dying randomly and will reboot itself up these past 2 months. I suppose this is due to overheating as I noticed that when I have a... Discussion in 'Windows 10 Gaming' started by Momo Rei, Oct 6, 2024.
  1. Momo Rei Win User
    My laptop has been dying randomly and will reboot itself up these past 2 months. I suppose this is due to overheating as I noticed that when I have a cooling pad + cool room/aircon, the crashing would appear less often means that it still appear like once a day or once in 3 days compared to the normal where my laptop would crash 2-4 times in 10mins-1hr interval. To find more fix, I stumbled about setting the Maximum Processor State to 99% to disable Turbo Boost and reduce my CPU temperature. Setting it to 99% has been working and I've been sticking into it until I get my laptop cleaned and re
  2. Why is the default maximum processor power state of power saver 100%?
    It doesn't make sense that power saver maximum processor state becomes 100%, same as balanced scheme.
    I find this is a bug because it wasn't the case when I first installed Windows 10.
    bmxjumperc, Oct 6, 2024
  3. Why is the default maximum processor power state of power saver 100%?
    When you restore the settings to default in Windows 10 the maximum power state would be 100%. Refer to the link below for more information:
    Windows help and learning
    Note: Applies to Windows 10 as well.
    Andria Maria Mendez, Oct 6, 2024
  4. Why my laptop often die/lost power when I set my Maximum Power State to 100% on Power...
    CPU stuck at maximum power state
    I'm running Windows 10 on my laptop with an Intel i7-4810MQ.
    My issue is that the CPU stays at the maximum processor state regardless of actual usage of the computer and percentage the setting
    is set at. For example, if I set the maximum state to 100%, the CPU will idle on the desktop at 100%, 3.25GHz, 95°C. Obviously I don't want my PC running at this all the time.
    The only exception is if I set the maximum processor state to a really low setting like 1%. At that point, the CPU stays at 28%, or 0.76 GHz because the CPU can't clock below that.
    Is there a way I can set the maximum to 100% so it clocks up when I game or watch 60fps video, while still running cool and quiet when idling? I feel like that's what it should be doing right now, but it's
    stuck at the maximum.
    I should also note that the High Performance and Balanced power plan both run at 100% all the time. Also, changing the GPU's Power Plan does not affect this.
    Here's a shot of my advanced CPU settings in my Prema Mod BIOS:
    Why my laptop often die/lost power when I set my Maximum Power State to 100% on Power... 7e7d1431-6bd7-47b0-9957-ba918d46f512.jpg
    charlocharlie, Oct 6, 2024
  1. Why my laptop often die/lost power when I set my Maximum Power State to 100% on Power... - Similar Threads - Why laptop often
  2. Why my laptop often die/lost power when I set my Maximum Power State to 100% on Power...
    Why my laptop often die/lost power when I set my Maximum Power State to 100% on Power...: My laptop has been dying randomly and will reboot itself up these past 2 months. I suppose this is due to overheating as I noticed that when I have a cooling pad + cool room/aircon, the crashing would appear less often means that it still appear like once a day or once in 3...
  3. My laptop crash or freeze when i set processor power management 100%
    My laptop crash or freeze when i set processor power management 100%: when i put my processor power management to 100% my laptop randomly crash sometimes blue screen, but when i put it on 95-99% it runs perfectly fine, but the performance is downed.the first time my laptop did this i thought my laptop was overheating so i changed the thermal...
  4. My laptop crash or freeze when i set processor power management 100%
  5. My laptop freeze randomly when I set Maximum Processor State at 100%
    My laptop freeze randomly when I set Maximum Processor State at 100%: Hi guys, as the title, my laptop freeze randomly and stop working I must force shutdown and reset the laptop whenever I set Maximum Processcor State at 100%If I set it down to 99%, my laptop works well but the performance is downed significantly.For example: - When I set it...
  6. My laptop freeze randomly when I set Maximum Processor State at 100%
  7. My laptop freeze randomly when I set Maximum Processor State at 100%
  8. Advanced Power Plan Setting "Maximum Processor state" and "Minimum processor state" not...
    Advanced Power Plan Setting "Maximum Processor state" and "Minimum processor state" not...: SPECS: Win 10 (obv) i7 10700F 16GB 3000mhz 1660 Super So I used to set my processor states to prevent overheating, as my processor runs at 4.6 ghz, and only a few games can get it beyond what I like in terms of temp (80c+ or 176f+), as it generally rests around 80c/174f...
  9. Maximum and Minimum Processor State missing in Power management settings
    Maximum and Minimum Processor State missing in Power management settings: I tried the command prompt fix, downloading the registry file and running it and both didn't work to bring back those 2 options.I am running on Windows 10 20H2 version. Pls help asap...
  10. Laptop Lost Power
    Laptop Lost Power: Hi I was using my Laptop, Dell Vostro 1000, and it shut down. I pushed the power button and nothing happened, so I did the following: Checked the wall outlet. Removed the battery and tried to power it up with the power adapter. Replaced the power adapter. Tried to power...
