Windows 10: Wifi adapter slow on battery power, but no setting to change in Power Plan
Discus and support Wifi adapter slow on battery power, but no setting to change in Power Plan in Windows 10 Software and Apps to solve the problem; I have a Dell Latitude running Windows 11 proWhen connected and battery fully charged I can get 300-600 Mbps download speeds,On battery or when... Discussion in 'Windows 10 Software and Apps' started by MymsMan, Apr 13, 2025.
  1. MymsMan Win User
    I have a Dell Latitude running Windows 11 proWhen connected and battery fully charged I can get 300-600 Mbps download speeds,On battery or when charging speed slows to 30-40 Mbps.I have looked for settings to change wifi adapter power options but there is no setting for the adapter under Power Plan -> Advanced power settings How do I change the adapter power options on this computer?
  2. John Fer Win User
    Power plan?
    Upon checking, it seems that there's nothing wrong with your system. It is usual that you have to double-click your mouse before your monitor wakes up.
    For the meantime, we suggest changing the power plan by following the steps below:
    • Press Windows key + S.
    • Type in Power Settings.
    • On the pop-up window, choose Additional power settings.
    • Select High performance.
    After changing the power plan, we suggest that you monitor the changes made and check if that will work for you.
    Get back to us if you need further help.
    John Fer, Apr 13, 2025
  3. Geethu B Win User
    Power plans automatically changing
    Hi Jonah,
    Thank you for contacting Microsoft Community. I understand that you have an issue with power plans.
    I will surely help you to fix this issue.
    This issue could have occurred due to incorrect Power settings. Try the steps listed here:
    Method 1:
    Let’s run the power troubleshooter and check if that helps.
    a. Press Windows key on the keyboard.
    b. In the search box, type Troubleshooting and press
    Enter.
    c. Click on ‘System and Security’ and click on ‘Power’ click on next to run the troubleshooter.
    Method 2:
    If the issue persists, I suggest you to
    restore the power plans to default and check if it helps.
    Step 1: Reset and restore the power plans to default:
    • Right-click on
      Start button
      and click on Command Prompt (Admin).
    • In the command prompt, type powercfg –restoredefaultschemes
      and hit Enter.
    • Exit command prompt.
    Note: This would reset the power plan settings to default. Any customized power plans are would be removed.
    Step 2:
    Once the power plan is reset to default, you may create a
    new power plan
    and customize the same according to your needs.
    Refer to the link:
    Power plans: Frequently asked questions
    Windows help and learning
    Note: Applies to Windows 10.
    Hope this information helps. Reply to the post with an updated status of the issue so that we can assist you further.
    Geethu B, Apr 13, 2025
  4. Wifi adapter slow on battery power, but no setting to change in Power Plan
    There is no option of "power management" in configure internet adapter
    Hi joudalchahrour,
    Try changing the power plan for the wireless network adapter:
    Type powercfg.cpl in the search box then proceed by following the next steps.
    1-In Power Options click on Change plan settings.
    2-On the next page click on Change advanced power settings.
    3-On the next page expand Wireless Adapter Settings, then expand Power Saving Mode.
    4-In Battery powered and Mains powered, select Maximum performance.
    franco d'esaro, Apr 13, 2025
  1. Wifi adapter slow on battery power, but no setting to change in Power Plan - Similar Threads - Wifi adapter slow
  2. Wifi adapter slow on battery power, but no setting to change in Power Plan
    Wifi adapter slow on battery power, but no setting to change in Power Plan: I have a Dell Latitude running Windows 11 proWhen connected and battery fully charged I can get 300-600 Mbps download speeds,On battery or when charging speed slows to 30-40 Mbps.I have looked for settings to change wifi adapter power options but there is no setting for the...
  3. "Power & battery" settings seem to contradikt "Plan Settings"
    "Power & battery" settings seem to contradikt "Plan Settings": Hi,Why are the setting in the two windoes below contradicting each other?BR,Henrik https://answers.microsoft.com/en-us/windows/forum/all/power-battery-settings-seem-to-contradikt-plan/7782a5a9-685c-43b2-8229-ba13e7a168a6
  4. "Power & battery" settings seem to contradikt "Plan Settings"
  5. How to set up a power plan for a laptop with no battery
    How to set up a power plan for a laptop with no battery: I have the "no battery present" problem I've done everything and now have ordered a new battery. Apparently, when I unplug the computer it does a hard reboot: Acer loading circle, then Windows screen, then login screen. When I merely shut the laptop lid, in the short term it...
  6. How to set up a power plan for a laptop with no battery
  7. How to set up a power plan for a laptop with no battery
  8. Power plan settings
    Power plan settings: Hello, i have a problem with adding high performance plan to my laptop Asus ZenBook 2020. As i don't see high or ultimate performance power plans nowhere in Power option panel, even under the arrow. I though i'd add one. First i went to the lower power option panel and...
  9. Power Plan: how to change brightness on battery / plugged in?
    Power Plan: how to change brightness on battery / plugged in?: The latest (about a week ago?) windows 10 update seems to have removed some features from the Control Panel > Hardware and Sound > Power Options page and the pages underneath it. Specifically, under Change Plan Settings it seems they removed the ability to set a different...
  10. power plan is changing
    power plan is changing: My laptop is set to never sleep. However, sometimes it actually goes to sleep. But the issue is that when it awakes, Windows changes my power plan. Any assistance is appreciated....
