Windows 10: WiFi setting disappearing taskbar not responding and other parts of my system like sound
Discus and support WiFi setting disappearing taskbar not responding and other parts of my system like sound in Windows 10 Network and Sharing to solve the problem; What can I do to fix this?... Discussion in 'Windows 10 Network and Sharing' started by Blessing Davidson, May 28, 2024.
  1. WiFi setting disappearing taskbar not responding and other parts of my system like sound
  2. David-M. Win User
    Hi. I'm David, and I'm happy to help you.
    Since you are having problems in multiple parts of the system, I'm afraid you have corrupted system files. Corrupted system files can cause system services to suddenly stop working. Sometimes, the services start working again or not at all, requiring a system restart.
    Before suggesting a procedure to fix this, please clarify the following:
    What is the current version and "OS Build" of your Windows 10?
    - Press "Windows + R", type winver, and click OK.
    If you prefer, send a screenshot. Use the shortcut "Windows + Shift + S" to use the screenshot tool.
    Be sure to censor your email address if it appears. The Microsoft Community is public.
    I await your reply. Click on the "Reply" button below my reply.
    David-M., May 28, 2024
  3. Yaqub K Win User
    System Icons on taskbar
    Thank you for posting on Microsoft Communities.
    Are you referring to the clock system icon on the taskbar?
    If so, I suggest you to follow the steps mentioned below:
    • Click on the search bar on the taskbar.
    • Type system icons.
    • Under Turn System Icons ON or OFF, turn On the Clock and check with the issue.
    Hope it helps.
    Yaqub K, May 28, 2024
  4. Xylee Del Win User
    Windows 10 Taskbar icons missing/ not responding!
    Hello Pasindu,
    Windows 10 may have encountered a system file corruption that caused this taskbar issue. For us to assist you with this, kindly answer the following questions:
    • Have you made any recent changes to your computer prior to this issue?
    • What is the current build and version of your Windows 10? To check, type in
      winver on the search bar and press Enter.
    Meanwhile, we suggest that restart the Windows Explorer.exe to refresh your taskbar functionality by following the steps below:
    • Open Task Manager
      by right clicking the taskbar.
    • Click More details at the bottom to expand the Task Manager window.
    • Under the Processes tab, look for Windows Explorer.
    • After selecting the Windows Explorer, click the Restart
      button at the bottom.
    • It may take a few seconds and things like your taskbar and Start menu may disappear momentarily, but when it restarts, things should behave better and you can exit Task Manager.
    We'll be waiting for your reply.
    Xylee Del, May 28, 2024
  1. WiFi setting disappearing taskbar not responding and other parts of my system like sound - Similar Threads - WiFi setting disappearing
  2. WiFi setting disappearing taskbar not responding and other parts of my system like sound
    WiFi setting disappearing taskbar not responding and other parts of my system like sound: What can I do to fix this? https://answers.microsoft.com/en-us/windows/forum/all/wifi-setting-disappearing-taskbar-not-responding/23f1d31a-7d1a-4aed-bbb3-a08d06547098
  3. WiFi setting disappearing taskbar not responding and other parts of my system like sound
  4. System Sounds Disappear !!!
    System Sounds Disappear !!!: Hello, why do my system sounds disappear? Sounds when I connect or disconnect a USB flash drive or sounds for errors and such. There is sound. The sound card is working, they are enabled in the settings. I tried turning them off and on again but the effect is zero. I only fix...
  5. System Sounds Disappear !!!
  6. My system sound disappeared
    My system sound disappeared: Hi i was just playing video games but suddenly my laptop sound got completely vanished i didn't delete or manage any drivers and i only update my pc if its necessary, i went to check my sound drivers and everything was okay even troubleshooting said that its okay But my...
  7. My system sound disappeared
  8. My system sound disappeared
  9. Disappearing system sounds
    Disappearing system sounds: Hello, several times now it happens to me that my system sounds disappear. The system is Windows 11. Only the sounds are missing when I plug in the USB drive, when I empty the trash or when some notification appears in the taskbar. Otherwise, there is sound, I solve the...
  10. Disappearing system sounds
