Windows 10: Windows 10 system doesn't work after not using system for 30 minutes with power plugged in.
Discus and support Windows 10 system doesn't work after not using system for 30 minutes with power plugged in. in Windows 10 Performance & Maintenance to solve the problem; Hi! Since I have updated my BIOS and the drivers, my HP i5 8th Gen Pavillion Notebook has started working faster but nowadays it goes blank and only... Discussion in 'Windows 10 Performance & Maintenance' started by Utkarsh_2205, Jul 27, 2021.
  1. Windows 10 system doesn't work after not using system for 30 minutes with power plugged in.
    Hi! Since I have updated my BIOS and the drivers, my HP i5 8th Gen Pavillion Notebook has started working faster but nowadays it goes blank and only the power button worksit doesn't blink but remains on when I don't use it for 30 minutes with power plugged in. I have checked the advanced power settings and all but no luck. Can I get a proper solution? Thanks in advance.
  2. BetoLP Win User
    Thanks again!!
    - - - Updated - - -
    Windows 10 system doesn't work after not using system for 30 minutes with power plugged in. [​IMG]
    BetoLP, Jul 27, 2021
  3. Gino Des Win User
    System Reboots after about 5 minutes of inactivity
    Hi Allen,
    Let's try to isolate the cause of the issue. We suggest that you follow the methods below:
    Method 1: Run the Power Troubleshooter to find and fix problems with your computer's power settings. Check your power settings if your computer is set to sleep or hibernate after 5 minutes of inactivity. To run the troubleshooter, follow
    the steps below:
    • Click Start.
    • On the search bar, type Troubleshooting, and click on
      Troubleshooting
      from the results.
    • Click on System and Security.
    • Under Power, click on Power.
    Method 2: Use the System File Checker tool to repair missing or corrupted system files. For steps on how to run the System File Checker tool, check the following link:
    Method 3: Check if all the devices on your computer have the latest driver. Refer to this link for steps on how to update drivers:
    Update drivers in Windows 10
    Let us know how it goes for us to assist you further.
    Gino Des, Jul 27, 2021
  4. TJC4 Win User
    Power Settings say sleep @ 30 min but computer sleeps @ 2.5 minutes
    I've tried posting this before but the one and only reply I got from MSFT was not helpful and then MSFT stopped replying to thread so I'm creating a new post...
    Here's Original Post:
    Problem started occurring since upgrading to Windows 10. Same machine running Windows 8 had no issues.
    My computer isn't supposed to sleep for 15 (battery) or 30 minutes (plugged in). But it sleeps after approximately 2.5 minutes. I just tested twice while plugged in. One test I timed at 2 min 32 sec and one at 2 min 33 sec.
    Huge pain in the **** as I have a very strong password and I'm accidentally locked out of my computer approx 100x / day.
    Below are my power settings:
    System > Power & Sleep Settings: instruct both the screen to turn off and the computer to sleep at 15 minutes when on battery and 30 minutes when plugged in.
    Control Panel > Hardware and Sound > Power Options > Edit Plan Settings: also instruct both the screen to turn off and the computer to sleep at 15 minutes when on battery and 30 minutes when plugged in.
    Control Panel > Hardware and Sound > Power Options: I'm running the default "Balanced (recommended)" power plan, not a custom power plan.
    You can
    see the bad advice I got in response here
    I tried running the Power Troubleshooter as suggested but that didn't work.
    I clicked the "How to create and delete a power plan" link but could not access the content as MSFT detected I was running Windows 10 and the link was to Windows 8 content so I was redirected to some Windows 10 content homepage (nothing related to power
    - just general Windows 10 stuff).
    Similarly the "Clean Boot" link provided had nothing regarding Windows 10.
    I'M RUNNING WINDOWS 10. NO MORE WINDOWS 8 ADVICE, PLEASE.
  1. Windows 10 system doesn't work after not using system for 30 minutes with power plugged in. - Similar Threads - system doesn't using
  2. My WiFi doesn't work after 20-30 minutes of use
    My WiFi doesn't work after 20-30 minutes of use: I have an issue with the WiFi. When I turn on my laptop and navigate in the browser, my WiFi stops working after 20–30 minutes of use, and when this problem happens, the WiFi on all the devices in my home stops working. It wasn't two days ago, and I've tried all the...
  3. My WiFi doesn't work after 20-30 minutes of use
  4. System Firmware Update running for 30 minutes
    System Firmware Update running for 30 minutes: I got a notification for system firmware update. Now it has been going on for about half an hour. how much times does it take to complete? Has the update failed?...
  5. System Firmware Update running for 30 minutes
  6. System crash shutdowns roughly after each 30 minutes
    System crash shutdowns roughly after each 30 minutes: I have a core-i3 4th gen laptop. It has started crac=shing for no apparent reason. I have checked the cooling system and also replaced the fan also replaced the keyboard, hard drive, RAM but no improvement. Below is the event log of last crash shutdown. If anyone can help it...
  7. System locks automatically on plugging in Power
    System locks automatically on plugging in Power: Hi, My laptop is HP CC-129tx ; Since long time ago my PC locks up automatically when I Plugged in Power without any message; Kindly suggest what could be the problem in this case....
  8. BSOD every 30 minutes to an hour System Service Exception
    BSOD every 30 minutes to an hour System Service Exception: Hi! So for the past 6 hours or so, my laptop which has an i5, 12GB RAM, and Windows 10 Home has been getting the BSOD. It all started when I was browsing on Chrome when it crashed all of a sudden. I can use the laptop for an hour or so, but afterwards it'll just crash without...
  9. [notebook] system restarts after sleep if power cable is plugged in
    [notebook] system restarts after sleep if power cable is plugged in: Hi, On my notebook (Acer Travelmate 4730), if the power cable is plugged in, the system always restarts automatically after it is woken up from sleep. whether the battery is removed or not. No such a problem if un-plugged. That happened after a certain Win10 update which I...
  10. System process always uses 30% CPU.
    System process always uses 30% CPU.: Hello All, For some reason the CPU usage by System process is always at 30%. It never goes down, Even if I reboot the system the usage will stay normal some time and then the system Process will start using the CPU at 30% again. My laptop Model is HP OMEN CE073TX OS -...
