Windows 10: Xbox one wireless adapter's sound cuts off in "power saver" power plan.
Discus and support Xbox one wireless adapter's sound cuts off in "power saver" power plan. in Windows 10 Software and Apps to solve the problem; So im watching a video or reproducing sound on my pc, then for whatever reason I clic Stop, or Pause. 30 seconds later, I can't resume playback. The... Discussion in 'Windows 10 Software and Apps' started by Rodrigo_bko, Nov 10, 2021.
  1. Xbox one wireless adapter's sound cuts off in "power saver" power plan.
    So im watching a video or reproducing sound on my pc, then for whatever reason I clic Stop, or Pause. 30 seconds later, I can't resume playback. The video keeps paused and my sound devices crashes. The only way to solve this is unpluging the 3,5 jack from the controller, so the system switches to other audio device, video automatically resumes playback, and connect the jack again so the system switches back to xbox one controller audio. This only happens in Power Saver power plan. Not in Ryzen Balanced or any other one.-Controller and adapter firmware are up to date.-Windows up to date.-Devi
  2. Windows 10 1709 - Get back Power saver power plan
    You can get the Power Saver power plan back by doing the following:
    1. Open Windows Mobility Center1.
    2. On the Battery Status part, you can see the charge (%) of the battery, as well as a dropdown menu with the current power plan selected.
    3. Click the dropdown menu to see the other power plans.
    4. Select your power plan. (In your case, you're likely to select the Power Saver power plan)
    5. That's it! If you go to Control Panel > Hardware and Sound > Power Options, you can see your selected power plan.
    1 You can open Windows Mobility Center either by right-clicking the battery icon on the system tray and clicking the Windows Mobility Center option, or by simply launching it directly by searching for it.
    Lloyd Dominic, Nov 11, 2021
  3. John Fer Win User
    Power plan?
    Upon checking, it seems that there's nothing wrong with your system. It is usual that you have to double-click your mouse before your monitor wakes up.
    For the meantime, we suggest changing the power plan by following the steps below:
    • Press Windows key + S.
    • Type in Power Settings.
    • On the pop-up window, choose Additional power settings.
    • Select High performance.
    After changing the power plan, we suggest that you monitor the changes made and check if that will work for you.
    Get back to us if you need further help.
    John Fer, Nov 11, 2021
  4. Ṣmeed Win User
    Ṣmeed, Nov 11, 2021
  1. Xbox one wireless adapter's sound cuts off in "power saver" power plan. - Similar Threads - Xbox wireless adapter's
  2. Xbox Wireless Adapter, controller powers off as soon as it connects to the adapter
    Xbox Wireless Adapter, controller powers off as soon as it connects to the adapter: Xbox Support said I should contact PC support for this topic. I am trying to connect my Xbox Series controller to PC using the Xbox Wireless Adapter for Windows 10. I am having an issue where on every power cycle of my PC, I can connect the controller once and it be just...
  3. Xbox Wireless Adapter, controller powers off as soon as it connects to the adapter
  4. Power plan changing to 'Power saver' automatically
    Power plan changing to 'Power saver' automatically: Hi,I recently came across a problem with my performance on my laptop. In the end, I discovered that the power plans on my laptop Windows 10 are messed up real good.On every start or restart, every time I plug and unplug the charger, the Windows power plan is set to 'Power...
  5. Power plan changing to 'Power saver' automatically
  6. Power plan changing to 'Power saver' automatically
  7. Xbox one wireless adapter's sound cuts off in "power saver" power plan.
    Xbox one wireless adapter's sound cuts off in "power saver" power plan.: So im watching a video or reproducing sound on my pc, then for whatever reason I clic Stop, or Pause. 30 seconds later, I can't resume playback. The video keeps paused and my sound devices crashes. The only way to solve this is unpluging the 3,5 jack from the controller, so...
  8. Xbox one wireless adapter's sound cuts off in "power saver" power plan.
  9. Power Plan keeps on shifting to Power Saver Every time
    Power Plan keeps on shifting to Power Saver Every time: In my Asus TUF FX505DY, whenever I turn on the laptop or put it on a charge or wake it up after sleep, the power plan changes to Power Saver. I have tried everything from cmd to registry to Clean Boot to even reinstalling windows, but none of them worked. I updated Windows,...
  10. Laptop balanced power plan or power saver
    Laptop balanced power plan or power saver: My laptop vents has no dust and foreign matters, also i have cooling pad. But when cpu going to 100% caused by update, maintenance, etc, it can hurt my 6 years laptop. Since the temperature can be mesured in 3rd patry app called core temp it rise about 75% when heavy load,...
